Old 07-21-2015, 08:16 AM   #1
skesque
My Ride: 318ci N46
Engine louder/vibration at 3000rpm after Valve Cover Gasket change
Hi,
My car has a N46 engine.
I changed the valve cover gasket last night and 2 valve cover studs sheared and snapped, flat to the head.
The car idles smoothly and there are no issues at all rpms in neutral.
However, in gears, there is a noticeable bassy/ heavy feel/ vibration from roughly 2900 to 3500 rpm.
Im pretty clueless what the the reason for this is. Would really appreciate your input.
skesque is offline   Reply With Quote
Old 07-21-2015, 09:19 AM   #2
Gus-CO
My Ride: 323ci
it is most probably leaking vacuum through the bolts that were not used. You're gonna need to take the remaining parts out and replace with new studs... Yes.... won't be fun.
Gus-CO is offline   Reply With Quote
Old 07-21-2015, 09:29 AM   #3
skesque
My Ride: 318ci N46
Thanks for the quick reply Gus-Co.
That what i was thinking too.
The studs (approx 5mm diameter) are pretty much flat to the head.
I feel like i would risk shearing the remaining studs as some were very hard go get on.
Would i be naive in trying to remove the 2 snapped studs by a 4mm screw extractor (drill bits) through the valve cover holes?
Old 07-21-2015, 09:43 AM   #4
Gus-CO
My Ride: 323ci
If you can clearly see the snapped studs, I see no problem. It's even better as the head is going to be protected from shavings.
Good luck and keep us posted!
Old 07-24-2015, 08:46 AM   #5
skesque
My Ride: 318ci N46
Hi Gus-Co,
After deliberating, i chose to book the car in at a local regular garage for them to extract the studs.
He said it would take half an hour and said although its high risk, they wouldn't damage the cylinder head.
Should i trust them? Specialist thread works are asking for too much money? Would the garage have insurance? I really can't afford for things to go wrong.
Thank you once again for your help
Old 07-24-2015, 09:38 AM   #6
Gus-CO
My Ride: 323ci
If it fails he just needs to put a helicoil in. Installing a helicoil is not harder than extracting the bolt and very low probability of going wrong.
About liability, I would barely trust a dealer in assuming any mistakes. An indy is totally hit & miss in my opinion. Again, there is little to go wrong. But there is always a chance.
Good luck!
Old 07-24-2015, 10:04 AM   #7
skesque
My Ride: 318ci N46
That's very true.
What about the potential of them damaging the valve cover, or worse the cylinder head, with the drill they use?
Would that not lead to a huge repair cost?
Old 07-24-2015, 10:13 AM   #8
Gus-CO
My Ride: 323ci
I can't envision anything going so bad that requires the head to be removed. So, short answer is no....
If the unlikely happens and the guy is able to damage it so much that it needs to be removed, fixing at a head shop will be less than $100. Labor to pull the head off though (with the necessary parts to be replaced involved) is about $2K.
Old 07-24-2015, 10:14 AM   #9
skesque
My Ride: 318ci N46
Thank you very much, much appreciated
Old 07-27-2015, 11:10 AM   #10
skesque
My Ride: 318ci N46
Hey, sorry to bother you again, but the car did not start today so i charged the battery using a battery charger. It started fine, but then after 10 minutes of running idle the EML light came on and the engine does not idle; it revs between 1-2k rpm by itself.
Any ideas what this could be? Coil? Sensor? Or the vacuum leak?
Old 07-27-2015, 11:19 AM   #11
Gus-CO
My Ride: 323ci
Get the code read at advance or any other auto parts... It still sounds as a vacuum leak.
A vacuum leak is almost always together with a EML light. The light trips when the short term fuel trim is too different than the long term, because a vacuum leak exists. Or because misfire is happening somewhere also because of too much air not accounted for, that got into the engine because of a vacuum leak.
Maybe before the leak was too small for the ECU to detect, and now it is substantial enough that it tripped the alarm.
Again, get the code checked to make sure it is vacuum related. if it is, you have nothing else to be concerned about....
If you use android, there is a cheap bluetooth scanner on ebay that works with an app called TORQUE. It gives you all basic information you need to solve most problems ECU related.
Old 07-27-2015, 11:25 AM   #12
skesque
My Ride: 318ci N46
Would the vacuum leak be the cause of the self-initiated revving?
Thanks for the help again, truly very helpful.
Old 07-27-2015, 11:32 AM   #13
Gus-CO
My Ride: 323ci
Not a problem! This is what the forum's for.
Self Revving is a characteristic of vacuum leaks, yes... if there is too much air entering the engine, it will inject more gas to burn that excess air. Otherwise the engine would run lean and potentially melt your pistons... If the leak is too big your engine would just accelerate to red line or shut off depending on how it is programmed (most likely it will shut off).
If the leak is small enough a little revving gets rid of the excess air momentarily, then it builds up again and the ECU sends more gas and cleans it, then it builds up again and the ECU accelerates to gt rid of it and so on......
Old 07-28-2015, 03:09 AM   #14
skesque
My Ride: 318ci N46
Is it possible for the garage to drill through the valve cover bolt into the water jacket? Im feeling fairly apprehensive
Old 07-28-2015, 08:35 AM   #15
Gus-CO
My Ride: 323ci
Be cool!
It's impossible to affect any passageways in the head. They are like 4" below that level.
Old 07-28-2015, 07:18 PM   #16
skesque
My Ride: 318ci N46
Haha thanks! Mechanic managed to get them out using a normal drill bit and extractors! All sorted. Now to address coolant leaks haha
Old 07-29-2015, 11:46 AM   #17
Gus-CO
My Ride: 323ci
Cool! Is EML light gone?
Don't fool around with coolant leaks.. I just had to redo my wife's 323 head. NOT fun...
Old 07-29-2015, 12:54 PM   #18
skesque
My Ride: 318ci N46
Yeah the EML went by itself 30 minutes after first appearing before repair, the air suction intake duct/cover wasn't on at that point so could it have been that?
I've had coolant issues since ive bought this car, it overheated once for 1 minute and i got it towed. Changed upper hose twice at garages, radiator once. There's a leak in the upper hose for the third time so i bought a febi-bilstein hose i'm going to put on. But a mechanic told me a month ago i have a leak in the back of the engine water housing but im skeptical of his diagnosis. For now im filling water everytime i use it and no issues as of yet. Any ideas?
Old 07-29-2015, 01:13 PM   #19
Gus-CO
My Ride: 323ci
How many miles?
I think it is really good practice to overhaul the whole system at 100Kish. I bought everything BEHR or OEM and did not regret. It is a 400+ investment on parts, but it is worth, especially if you are note taking the head apart if it overheats too much (like a blown pipe I had, stopped right away but with absolutely no coolant the damage was great). Taking the head apart will run you $450 if you do it by yourself, a shop will charge $2k,,,
Old 07-29-2015, 01:43 PM   #20
skesque
My Ride: 318ci N46
Over here it costs more in . Ill change the upper hose and see how bad the leak remains?
Is taking apart the head a repercussion of overheating the engine? Dont these aluminium engines completely fail/become useless if they overheat too long?
