Old 06-12-2012, 02:36 PM   #201
serdar255
My Ride: '01 325ci / '90 325i
You along with LAFENGAS inspired me to do a similar project. Thank You
Want a handmade shift knob or custom vinyl stickers? PM me
I'm sixteen and like cars with three pedals.
My ever small company... www.facebook.com/StgFabricationAndMolds
serdar255 is offline   Reply With Quote
Old 06-13-2012, 11:47 AM   #202
jammykam
My Ride: 2003 330Ci Step Vert
Does anyone have any links to a Linux based CarPC which integrates with iBus?
I've found the following which I need to read through...
http://projects.tevs.eu/OpenBM
Anyone have any others? My Raspberry Pi should be delivered this week so hoping to hook this up to the stock nav unit (via RCA inputs, this is taken care of) and also to iBus so can use steering wheel and radio controls (hoping this will work - did some research many years and it *should* be possible - I has a USB connector board already)
thanks
jammykam is offline   Reply With Quote
Old 06-13-2012, 07:45 PM   #203
Kstrooch
My Ride: 325ci
Holy **** nice work!
Kstrooch is offline   Reply With Quote
Old 06-13-2012, 07:57 PM   #204
epistaxis2008
My Ride: 2002 330ci
Wooooooow!!! What OS is that? (User interface for all sources).... Pretty cool.
Sent from my PG86100 using Bimmer App
epistaxis2008 is online now   Reply With Quote
Old 06-23-2012, 12:17 AM   #205
ayashifx55
My Ride: M3 01
This was a great project by in the days .. today , you can just buy a netbook , hook it up at the back , remove LCd and sell on ebay. Use another external HDMI to hook on another LCD , wireless mouse + wireless keyboard + hdmi cable + usb or bluetooth GPS receiver
ayashifx55 is offline   Reply With Quote
Old 06-23-2012, 03:17 AM   #206
Toxx
My Ride: 2000 323i
Wtf did I just read
Toxx is offline   Reply With Quote
Old 06-23-2012, 05:58 AM   #207
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
Might as well put a laser printer on the dash
http://www.argyrides.eu/makeyourownsig.jpg
paraklas is online now   Reply With Quote
Old 07-17-2012, 11:46 AM   #208
ChampionC
My Ride: 318Ci Convertible
Originally Posted by paraklas View Post
The screen is simply amazing. Pictures in daylight and under direct sunlight:
Does the same Bezel work fine with really any touch screen ? I assume you do not have any need for access to the buttons which are along the bottom of the screen frame ? Or do you remove the screen from the manufacturers frame and mount onto the back of the Bezel ?
Thanks and well done on a fine job. I have a Raspberry Pi arriving in a few weeks and the Pi seems like the perfect device for a project such as this although support for the OS could be difficult until more people get access to Pi's
ChampionC is offline   Reply With Quote
Old 07-17-2012, 11:46 PM   #209
paraklas
paraklas's Avatar
I have used this bezel with the Xenarc, Lilliput and Inelmatic 7" LCD. A good body shop can paint it whatever color you like. I prefer matte black or gloss black. On all of them, I removed the frame for proper fit. Xenarc and Inelmatic also offer their products as "frameless" versions, so removing the frame afterwards doesn't impact functionality. I use a thin strip of foam at the perimeter of the bezel LCD area so that the screen sits on an even, cushioned surface. Before installing the screen, I also apply a hard screen protector as well. All screens come with an infrared remote control (hence the holes on the bezel bottom) so all functionality is there.
For Xenarc, I disconnected the PCB with the buttons completely
For Lilliput, I had to enable the auto power on when VGA signal is received, then tucked the PCB with the buttons behind the bezel on the right side
For Inelmatic, the button PCB is still connected and tucked behind the bezel bottom as I ordered the remote-less version. I have used the buttons one time only to adjust the brightness.
Due to each screen having different layout on the back, you may need to fabricate a bracket or two to properly secure it, not something complex. The bezel I have comes with 2 mounting brackets, and a big steel cover for the rear part of the screen. For the inelmatic, I used the rear steel cover as a heatsink as well, as it touches the screen's IC in combination with some heatsink adhesive pads (like the ones we used to cool VGA memory)
Old 07-20-2012, 10:58 AM   #210
ChampionC
Thanks for that, that makes more sense now removing the housing.
I'm having a re-think of the Raspberry Pi idea given the arrival of the Android based APC
Old 08-23-2012, 04:42 AM   #211
paraklas
paraklas's Avatar
Today I just finished another Car-PC upgrade:
M4 DC-DC Power supply installed in external housing
http://www.mini-box.com/M4-ATX?sc=8&category=981
OCZ Vertex 120GB SSD Installed, Windows XP SP3 with Centrafuse 4.1
Short video demonstrating resuming from hibernation:
Full restart cycle takes around 25seconds, most of the delay in BIOS
Video was taken on my office screen hence the resolution is a bit off.
Old 08-30-2012, 05:27 AM   #212
Pho3NiX90
My Ride: E46 318i, E53 4.6IS
Wow, really great thread. Read everthing.
A question though, ordered all my part from ebay today. Do you think the elm327 bluetooth interface will work? Also, do you know where i will find the right hand drive climate control relocation unit?
Pho3NiX90 is offline   Reply With Quote
Old 08-30-2012, 05:36 AM   #213
Pho3NiX90
Alao, what other screen do you suggest? I cannot find the inelmatic 7"
Old 08-30-2012, 06:09 AM   #214
paraklas
paraklas's Avatar
ELM327 does work, tested.
Climate relocation unit from ebay.co.uk, quarry motors uk, or dealer
Lilliput, Xenarc and some others also make sunlight readable screens, see mp3car.com store what you can find
Old 08-30-2012, 07:15 AM   #215
Pho3NiX90
Great thanks. But was talking about the bluetooth version of odb, is it reliable. Was maybe thinking of taking of the plastic cover and connecting/soldering it in the back of the orriginal connector to make the odb completely hidden.
Old 08-31-2012, 11:52 PM   #216
gowhitehat
My Ride: E46 330xi
Originally Posted by Toxx View Post
Wtf did I just read
That just made my night.
Thanks.
gowhitehat is offline   Reply With Quote
Old 09-21-2012, 04:14 AM   #217
karis79
My Ride: E39 530D
thanks
I did some experiment with raspberry pi + OpenElec + XBMC + IBUS adapter and it seems to work quite well(some problems 12v->5v adapter causing usb to drop some times.. this did not happend wiht wall charger and powered usb hub).
I wrote a small linux C daemon which reads and decodes ibus and then uses uinput to inject key events to the system. That way this daemon can be used basically with any linux based sw(I think it should work also in android as a native component) which takes normal key presses. Because I wanted to keep the original navi,fm,computer etc working I wanted to use that similar way that the famous CarX used, i.e. hijacking TAPE or AUX state.
So in order to so, that daemon needed to also detect the state of the BM and you can tell it to inject key events only in certain state like TAPE or AUX. it also can handle the switching the video input only in certain state(using ibus adaptor ntsc). With those, you can hijack for example TAPE so that when you are in that mode, you see the video input from rasp and get the button presses sent to your app in rasp.
I did similar exercise few years ago with meego ivi & beagleboard but the problem with meego is that its designed for touch screen and controlling with keys was difficult. XBMC, being home theather sw, is designed to be able to control with remote control so mapping BMW wheel&boardmonitor buttons to those command should not be too difficult.
karis79 is offline   Reply With Quote
Old 09-30-2012, 05:13 PM   #218
jammykam
Hi Karis
Just read your message fully, I've moved to Canada for about a year so my car is now tucked into the garage
But that is brilliant. It's pretty much what I was looking to so as well. I'd be very interested in the daemon that you wrote. I don't know C unfortunately, I'm a C# developer though so should be able to follow the code at least! I'd be very keen to try/install the code, if possible. Do you have it hosted or available?
I didn't know the beagleboard had been around for that long... but I've looked at a couple of other altrnatives, mainly the Gooseberry but that does not have TV Out (only HDMI). But since I do not have my car with me here I'll have to wait a while till I can do something with it.
thanks
Kam
Old 10-02-2012, 06:42 AM   #219
karis79
My Ride: E39 530D
Hi Karis
thanks
Kam
Its not yet available but I'm going to put it somewhere(most likely to github) after I find just little bit more time to fine tune and clean it up.. the key is the time . Its written with very basic C so its easy to follow.
I installed it in to OpenElec XBMC build by creating the scripts for my component and building it with these instructions: http://wiki.openelec.tv/index.php?ti...r_Raspberry_Pi. I can also share these scripts if you want to try it with openelec. (you might want to wait until turbo mode is included in openelec build: http://www.raspberrypi.org/archives/2008)
I had the beagleboard rev c which was introduced May 2009. I tried that at the beginning of 2011 so less than couple of years
Old 10-02-2012, 08:15 PM   #220
webdj
My Ride: e38
Hi. sorry for my english.
I have Raspberry Pi.
I want use Raspberry Pi in my BMW E38
I connect Paspi with video, audio and install xbmc, but i have problem with connect to car controls
i have ibus adapter.
can you share linux daemom?
webdj is offline   Reply With Quote
carpc, carputer
