Thread Tools Search this Thread Rating: Thread Rating: 47 votes, 5.00 average. Display Modes
Old 10-05-2012, 10:14 AM   #221
ChampionC
My Ride: 318Ci Convertible
Has anyone every moved the Climate Control Module without getting the BMW climate control relocation unit ?
It just seems to me that if i'm sure that I will never be undoing it, I can get my hacksaw out at the current unit and amend it to allow the climate control to slide in.
Any thoughts ?
ChampionC is offline   Reply With Quote
Old 11-04-2012, 06:54 PM   #222
jararak
My Ride: e39 530d
hi webdj
I have very simmilar configuration (except car --> e39). Which interface do you use? Ihave ressler's one. Also which version of OS did you use. For connection to car, did you use wires from CD changer?
jararak is offline   Reply With Quote
Old 11-04-2012, 09:12 PM   #223
haurelio
My Ride: 2001 bmw 325i
Any thoughts ?
It will slide in and there's very little movement to it.
Contact me if you need to unlock your phone.
Also can code your car
Old 11-11-2012, 02:26 PM   #224
karis79
My Ride: E39 530D
I have not have time(the usual, new baby coming, new job, etc ) to finalize this bmw ibus thing yet but I will share it as is. I started cleaning code etc but have not actually tested the code after those few changes but i think it should work. Mapping the button presses to actual linux key codes is still unfinished but if anyone has time to do it, or if anyone wants to map those again, then change the key_code(s) in headunit_buttons array at here https://github.com/karis79/bmw-ibus/...mw-ibus.c#L804.
I have uploaded my bmw-ibus linux daemon to github( https://github.com/karis79/bmw-ibus ) and also added there a patch that adds needed scripts to openelec so that bmw-ibus gets compiled in to openelec raspberry pi image. just follow instruction from http://wiki.openelec.tv/index.php?ti...r_Raspberry_Pi and after git clone step, patch https://github.com/downloads/karis79...nelec-rpi.diff and continue compilation.
If you want to try that with your laptop and see the key mappings etc then compile it:
git clone git://github.com/karis79/bmw-ibus.git
cd bmw-ibus
gcc -o bmw-ibus -Wall bmw-ibus.c
and start it:
./bmw-ibus -d /dev/ttyUSB0 -h AUX
this will hijack AUX(key events injected only when AUX selected)
edit:
I forgot to say that I have tested it in E39 2003 530D with 16:9 navi in english.
karis79 is offline   Reply With Quote
Old 11-15-2012, 10:57 AM   #225
ChampionC
Hi all,
I have started some preliminary work on my CarPC installation. I started looking at taking out the ashtray and glasses holder unit. I undid the two screws at the bottom but it would not pull out. It seemed to be caught at the top edge. OK, not what I expected so I decided to remove the radio to then see was it somehow connected to the underside of the Climate Control module, simple. Not quite, I could not figure out how to release the Climate Control module.
Any assistance gratefully received.
In addition, I have a PC which I plan to use - a Dell FX160 Thin Client. Height wise, it's perfect for the glove box but the glove box is not deep enough. Looking underneath, the panel behind the glove box seem like it's just covering up a load of space - apart from the location of the footwell light. So could I burst a hole out through the back of the glovebox to give me 2 extra inches of depth ?
Cormac
Old 11-15-2012, 12:23 PM   #226
M-Spec Tuner
My Ride: 325i
I think your main fuse panel is behind the glove box. So I would want to keep that clear for access. If it was to angle down some how I'm unsure if there is clearance also. Maybe best to remove the glove box and take some measurements. Good luck.
'03 325i...Just getting started!
M-Spec Tuner is offline   Reply With Quote
Old 11-16-2012, 10:26 AM   #227
BMW_Brecken
My Ride: E46 M3 coupe
Wow I feel like putting in a tablet for the head unit would have been 10000000000 times easier, but awesome electrical work!
BMW_Brecken is offline   Reply With Quote
Old 12-02-2012, 09:39 AM   #228
ChampionC
Just a quick update:-
I have now moved the Aircon control box down WITHOUT buying the relocation unit. I simply cut a notch of about 8mm out of the bottom side edges which allowed the aircon unit to side back in line with the console buttons. OK, so there's about a 2mm gap between the buttons and the aircon unit - about the same gap between the buttons and the Ashtray cover. All I finally had to do was make a small wedge to hold the aircon unit in place. The wedge is along the top edge and is hidden under the overhand of where the 2 Din opening will now be.
I have started making my own Bezel out of MDF. With the aircon unit now moved, it's time to start shaving the current cutout that I've done, down to size. It's currently about 2mm too wide. I over cut it since I did not fancy having to start again if I had under cut it !!
Old 02-18-2013, 11:46 AM   #229
ChampionC
Can anyone please tell me what the two wires (Brown & Yellow/Green - Brown & Blue/Red) behind the radio are feeding ? It seems an ideal place to tap off a 12v connection for my PC which I will locate in the glove box or in the passenger side footwell area.
Old 02-19-2013, 09:10 AM   #230
J LAU
My Ride: E46 / E82 / E89
you are crazy!
J LAU is offline   Reply With Quote
Old 02-19-2013, 12:29 PM   #231
ChampionC
Originally Posted by J LAU View Post
you are crazy!
Which part ?
Old 05-15-2013, 09:07 AM   #232
iyad0
My Ride: e46
great work hope i can find the parts here in palestine
iyad0 is offline   Reply With Quote
Old 05-15-2013, 05:05 PM   #233
iyad0
My Ride: e46
need centrafuse 4 cracked any help please?
Old 05-15-2013, 05:40 PM   #234
ChampionC
If you are not prepared to buy it, I can highly recommend Ride Runner - http://www.mp3car.com/road-runner/
Old 06-19-2013, 11:26 AM   #235
Drako06
My Ride: 330i
DIY: BMW E46 In-Car PC Project (Carputer)
Dedicated electrician!!!
Drako06 is offline   Reply With Quote
Old 03-02-2014, 06:02 AM   #236
paraklas
My Ride: ESS TS2 320ci
thread bump. My alpine headunit is not satisfactory anymore. It also does not like cold climate, when cold it does weird things by itself. I want to replace it with something more high-end, looking for something with the following characteristics:
- Has FM radio
- Has a detachable face that can be remotely placed without mods. I do not want to take things apart and solder
- Has ability to integrate with OEM steering wheel controls
- Has ability to output to amplifier
Does such thing exist?
Old 07-29-2015, 03:33 AM   #237
FurnicK
My Ride: BMW E46
All images is broke, can they be re-upped? I'm very interested in this :-D
Realoem is a life savior!
FurnicK is offline   Reply With Quote
carpc, carputer
