Rating:
Display Modes |
#101 |
thanks for quick reply, and no, not just for 1 wire less but for the clear sound, but if the aux is crystal clear, then I will go for that
, thanksthe mac mini is more simple for me to buy, is powerfull, very small, and its not so bulky as you say, I study it, first I wanted to fit it in the glovebox, but your ideea to put it under the passenger seat is excelent. I will look forward to what you said and hope I will find the right place ![]() later edit: Mac mini is 2 inch tall and 6.5 inch square anodized aluminum enclosure Last edited by tupeu; 01-01-2009 at 05:08 PM. |
#102 |
centrafuse what version is it?
#103 |
Hi im interested in doing something similar to this, the only thing I am confused about is how you connected the PC to the battery & ignition. Is this something to do with the steering wheel adapter? I dont have a remote control steering wheel so i am unsure if i need this adapter or not. Thanks
#104 |
I am using a specific power supply for automotive use.
Takes 3 inputs: Constant 12v (fused straight feed from battery) Switched 12v (This is for the ON/OFF Signal. Connect to ignition 12v or to Headunit's switched 12v output if you want the carpc to shut down when you turn off the radio, or straight feed from battery with a switch so that the pc turns on whenever you want.) Personally, I use the headunit's 12v switched output AND a switch to have all the options available to me. Ground: Connect at chassis using the shortest cable possible. The PSU apart from the power cables, also connects to the motherboard's ON/OFF pins. This is where you can define through windows what to do when the power button (switched 12v) is pressed. I have it to hibernate ![]() The PSU has jumpers on it where you define the countdown time to shutdown, if there's an amp present to prevent a "pop" sound when it turns on etc.
#105 |
Ok thanks I understand now.
I have done some research into the BMW -> ISO converter, is this the correct pin layout for the ISO plugs (connectors A and B): http://www.isham-research.co.uk/quat...85/isopin.html |
#106 |
Is the amp and radio really necessary? Could the system not be connected up to the current sound system?
Excellent job btw! Now to replicate that in my car! Where'd u get the lil keyboard? |
#107 | |
As you see, I didn't go to expensive aftermarket headunits for the project. The Alpine cost around $170 from ebay and it plays mp3, has ipod input, can be split, is more powerfull than OEM (in case you don't want an amp), has the interface to work with the steering wheel (additional $40), etc etc. An alternative solution is to use a PCI radio card and an amp and get rid of the headunit completely
#108 | |
Wouldn't mind buying a decent headunit, I'd just have my doubts about finding space. I'd like to keep the center console as is. But could possible hook it up under the driver/passenger seat? |
#109 |
Yup you can hook it there or if you are good with fabricating stuff (and no smoker) you can put the radio faceplate in the ashtray compartment. I would have gone that route but I prefered the centre console (more like McLaren F1 style). The Euro versions E46s have the secret compartment on the left of the steering wheel below the LCM which is also 1-DIN width / Depth, meaning you can mount the headunit there as well!!!!
#110 |
What OBDII software did you use?
#111 |
Centrafuse has an OBDII plug-in which works with the cheap ELM327 hardware interface easily found on ebay
#112 |
wow.
#113 |
Sweet Jesus! Unbelievable DIY, You work for NASA or something? One question, I see in all your photos of the software that the Engine Sensors information all show "N/A" Is it possible to actually show some of that information, is this something separate you need to hookup, etc.... Also, think you should find someone that can do the cosmetic work/alterations, just to save you that time, and open a shop, I'd be first one in your door.
LSBMmmm3
#114 |
Crazy. Just a little jealous and by little I mean alot!
02 330i Sport+Premium
-18" Staggered LTW D-Force EmPower Wheels -Clear Signals/Markers -Tint -StopTech Stage 2 Brakes -K&N Full Intake |
#115 |
The engine sensors say N/a because the time that I took the photo I did not have the OBDII module installed. A $40 OBDII hardware from ebay using the ELM327 chip will work with the system. It can be permanently plugged in the OBDII port.
#116 |
for internet could you use a internet air card like from sprint,verizon ect.?
#117 |
genius you are either
A) someone with way too much time on your hands B) a virgin but ur are udoubtedly a legend ,, and it should be stickied as the best mod ever |
#118 | ||
Currently struggling with setting up the company's new Oracle database & servers. Maybe I'll put a rack inside my trunk too ![]() Without a doubt this project took a while to complete but it has been running for 3 years with a 5 year old 60GB Fujitsu 2.5" hard disk, everyday, summer+winter. I did change the motherboard though to a faster one from Intel with a 1.8GHz celeron CPU. I might consider using a motherboard with an Intel Dual Atom CPU, which supposely uses less power and is more efficient than my current celeron. The 7" xenarc TFT shows some signs of age such as reduced brightness and a couple of dead pixels but nothing to make me throw $700 to get the new transflective LED version.
![]() Last edited by paraklas; 06-30-2009 at 03:08 PM. |
#119 |
Might be an ignorant question, but is there any way to get fm/am without having a separate tuner? Would be cool to just have the touchscreen up front...and be able to access the tuner via the touchscreen.
Mike
Want nitrous? Talk to the Wizard of Nos. http://www.noswizard.com/
#120 |
Too many wires for me, but nice setup!
| Tags |
| carpc, carputer |
