Old 10-09-2006, 03:33 PM   #1
nevin
My Ride: 08 AA m3
Can someone link me to a GOOD DIY for DDE's
This is driving me INSAINE...I need a good solid DIY for Predator Chromium's before it gets dark.
What do the brown wires connect too? The white or the gray?
I also don't know what the ground wire is. Is it the black one coming from the relay or the red one coming from the fuse? Once i know what the ground wire is whats the other one???
Umnitza's pictures show them mounting the relay in the compartment that is empty. Is this right or should i bolt the relay to the bolt under the positive terminal?
I did this before with a different set of DDE's but ended up blowing something and no one could figure out what the problem was. Sooo if this happens again i'm going to flip out.
I suck at speling!
Originally Posted by Bim Growl View Post
Get out of the pool. It's adult swim time, and you are in way over your head...
nevin is offline   Reply With Quote
Old 10-09-2006, 04:23 PM   #2
nevin
My Ride: 08 AA m3
got'em...
I suck at speling!
Old 10-09-2006, 05:26 PM   #3
nevin
My Ride: 08 AA m3
How do i get to the footwell light?
I suck at speling!
Old 10-10-2006, 03:43 AM   #4
n3985
My Ride: E92 soon?
The "easiest" way is to cut a tiny hole in the rubber boot by the passenger firewall, feed the wire through, take out passenger footwell light, and tap into the light's red wire for power.
n3985 is offline   Reply With Quote
