Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 10-17-2006, 10:44 PM   #21
FalconGuy
My Ride: 2003 325Ci
Send a message via AIM to FalconGuy
my hyd failed twice in 2 years, mech was good for 3. I would like a reverse DIY. I have a new mech sitting waiting for the time to do it...
Some improvement, 250 versus 29 bucks with a drop in reliabilty. do yourself a favor just like waterpumps never buy OEM
FalconGuy is offline   Reply With Quote
Old 09-19-2007, 11:58 AM   #22
Deep Blue
Banned
My Ride: M52TUB28
I know this post is a few years later but GREAT DIY Alex!
Deep Blue is offline   Reply With Quote
Old 10-02-2008, 10:10 AM   #23
pclaveau
My Ride: 33OCI 2001
Hydraulic Tensioner 330CI 2001 M54 5spd
Great Pics and DYI, but I am a little slow...
How do you release the pressure on the hydraulic tensioner to remove belt?
Thank you.
pclaveau is offline   Reply With Quote
Old 10-05-2008, 05:18 PM   #24
Grayout
My Ride: 2001 325Ci
I've got a mechanical tensioner for my AC system and a hydraulic tensioner for my drive belt system. Is this unusual? It also appears both the alternator and tensioner pulley bearings have gone bad. I need to replace both before they start to fail.
Grayout is offline   Reply With Quote
Old 01-11-2009, 03:22 AM   #25
00bmw323
My Ride: 00 323/91 integra RS
Could i use the Same bolts from the Old mechanical tenstioner to mount the new one? or do i need different bolts??
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 02-28-2009, 04:07 AM   #26
Lbert
My Ride: 325i
Yes, they are different bolts. An internet reseller now sells the hydraulic unit as a kit but you may need to get the bolts from the dealer.
Lbert is offline   Reply With Quote
Old 03-05-2009, 10:37 PM   #27
SWINFORD
///PIITB
SWINFORD's Avatar
My Ride: Low Life Marie
Send a message via AIM to SWINFORD Send a message via MSN to SWINFORD
Im doing this in the morning
Swinford-Hypnotyzd : Dirty South-Swinny
| Hypnotyzd FB |Tischer BMW|
SWINFORD is offline   Reply With Quote
Old 07-29-2009, 03:49 PM   #28
GUNIT
My Ride: 2011 328i
Do you know where they sell this "kit" or whole unit?
GUNIT is offline   Reply With Quote
Old 07-29-2009, 09:27 PM   #29
Lbert
My Ride: 325i
http://www.rmeuropean.com
Old 08-24-2009, 09:27 AM   #30
SweTurbo
Big Pimpin'
My Ride: 323i -98
Does the hydralic pull the belt the same way ?
I noticed that you have an extra belt-guider next to the waterpump.
Mine does not have this.
Old 09-10-2009, 10:06 AM   #31
nite-stalker
My Ride: 325Ci
http://www.autohausaz.com/search/pro...ner%20Assembly
whole conversion for ~$100
nite-stalker is offline   Reply With Quote
Old 11-28-2009, 05:32 PM   #32
BreakfastBurrito
My Ride: ///GT3 RSR
I have the same question, help? I dont see enough room to fit a screwdriver or something to push it down with.
Thanks.
BreakfastBurrito is offline   Reply With Quote
Old 11-28-2009, 07:29 PM   #33
xjunmoonx
My Ride: BLOODY MARY
is it better to go oem or go with autohausaz.com?
DTM-SPEC, SPP, BavX, Elite Autobody, VMR, EAS, Eurodyne, Khoalty, JP Autosound
Progress Thread
xjunmoonx is offline   Reply With Quote
Old 12-13-2009, 03:51 PM   #34
genuity
My Ride: 2001 330iS
Does anyone know the torque specs for these items? I cannot seem to find it in the Bentley
genuity is offline   Reply With Quote
Old 12-13-2009, 08:40 PM   #35
genuity
My Ride: 2001 330iS
Why buy incomplete kits when you can get it with nearly everything you need with genuine parts, plus a 2 year/unlimited mileage warranty valid at any US BMW dealership!
http://www.trademotion.com/partlocat...catalogid=4462
Anyone know the torque specs? Bueller?
Old 12-25-2009, 10:50 PM   #36
kyle808
My Ride: 00 328CI
when i swapped out my mechanical out for the hydraulic I didn't torque it to any specs, just gauged with my arm. I don't think you have to worry too much about the correct torque. I've had no issues with the hydraulic tensioner for over 2 years. good luck.
"I'm gonna die! Jesus, Allah, Buddha - I love you all!
-Homer Simpson
kyle808 is offline   Reply With Quote
Old 03-21-2010, 05:22 PM   #37
twosticks
My Ride: 1999 Audi A4
hydraulic tensioner torque specs?
It would be much appreciated if someone out there could post torque specs for the hydraulic tensioner bolts. Thanks.
twosticks is offline   Reply With Quote
Old 04-30-2010, 06:19 PM   #38
genuity
My Ride: 2001 330iS
I'll answer it myself for those looking in the future...
Originally Posted by golforcars325i View Post
Tensioner is 18 ft. lbs. (24 nm)
Idler Pully is 33 ft. lbs (45 nm)
It was found here:
http://forum.e46fanatics.com/showthread.php?t=464996
Thanks golforcars325i
Old 10-07-2010, 11:58 AM   #39
Fry-man22
My Ride: 2003 BMW 330i Sport
Thanks for the DIY - just wanted to mention one potential inaccuracy. In regards to the placement of the wave washer at the top of the cylinder the picture - this contradicts RealOEM and the assembly of the tensioner I just received.
The wave washer (#14 on the realOEM digram) is apparently supposed to go on the shorter mounting bolt that connects the tensioner bracket to the engine.
The bolt at the top of the cylinder is supposed to be paired with a flat washer #12. I would assume the flat washer provides the rubber bushing in the cylinder mount more support, the wave washer will probably allow the bushing to creep over it and I would guess possibly shorten the life of the assembly.
Pic of the one I received from AutohauzAZ attached.
I also found a link to a BMW bulletin on the retrofit.
http://www.bmwtis.com/tsb/bulletins/...p/B110403g.htm
ID:	378674   Click image for larger version
ID:	378675   Click image for larger version
Fry-man22 is offline   Reply With Quote
Old 10-07-2010, 12:05 PM   #40
genuity
My Ride: 2001 330iS
^ I did it the way you did after seeing the diagram on realoem.
It already came assembled and I dissembled it when seeing the write up on this , but after realizing that the part arrived correct in the first place, now it left me to guess on what torque spec to use when putting it back together
