Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 10-26-2010, 12:45 AM   #41
mickey513
My Ride: e46
So the kit and hydraulic tensioner can be have for less then $100 at autohaus AZ?
http://www.autohausaz.com/search/pro...ner%20Assembly
I under it will need new belts but is anything else missing for the retrofit? Need to change my belts soon...
mickey513 is offline   Reply With Quote
Old 10-26-2010, 09:52 PM   #42
Pancho328i
My Ride: 328i
Man, I just finished changing the belt tensioner for the new hydraulic type. It wasn't that hard but it was expensive, $175 plus shipping. Local dealer wanted $250. Now I'm thinking I should have instead used a OEM mechanical (Ina) tensioner and save $150. Darn.
I'm one of those who insist on only using BMW branded parts, however something like this is worth considering.
Pancho328i
2000 328i Single Owner...me ;)
Pancho328i is offline   Reply With Quote
Old 10-26-2010, 10:31 PM   #43
Imola.ZHP
My Ride: Imola ZHP
Sorry for my ignorance, but is this the part that I recall hearing about awhile back that if it fails causes a catastrophic failure of the cooling system?
I'm getting together everything needed to do my 100k maintenance, not sure if this is what is needed or not. AFAIK mine is original at 93,000 miles...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 11-08-2010, 11:02 AM   #44
Nando779
My Ride: 2003 325Ci
I would like to know this as well. I am purchasing the the items and wonder if anyone who has purchased the the tensioner and kit from autohas can confirm it includes everything needed for the conversion.
Nando779 is offline   Reply With Quote
Old 09-26-2011, 11:32 PM   #45
TopazBlu02
My Ride: 330CI
Originally Posted by FalconGuy View Post
my hyd failed twice in 2 years, mech was good for 3. I would like a reverse DIY. I have a new mech sitting waiting for the time to do it...
Some improvement, 250 versus 29 bucks with a drop in reliabilty. do yourself a favor just like waterpumps never buy OEM
I purchased the wrong tensioner (mechanical) as I have hydrolic and I'm thinking about doing a reverse swap as well as I'm too lazy to return the mechanical tensioner. I inspected the tensioner and it looks like the only place where this could fail is the pulley so it doesn't bother me one bit that I'm going to an supposedly inferior design. So, do I need new bolts to install the mechanical tensioner?
TopazBlu02 is offline   Reply With Quote
Old 10-01-2011, 08:25 PM   #46
davidofva
My Ride: 2002 bmw 325i
Since the mechanical tensioner uses 2 bolts, and the hydraulic uses 3, would you assume that makes it stronger and less likely to fail or break off like the mechanical seems to? I say this because our 325 just sheared both bolts off. I am leaning to replacing with the hydraulic type. Has anyone with the hydraulic type had the bolts break?
davidofva is offline   Reply With Quote
Old 10-05-2011, 06:07 PM   #47
Andrew.Guajardo
My Ride: 2002 325i
No but i am also thinking of switching mine to a mechanical one as the hydraulic tensioner can no longer give room for me to install a new belt.
Andrew.Guajardo is offline   Reply With Quote
Old 07-10-2013, 09:14 AM   #48
paraklas
My Ride: ESS TS2 320ci
Thread revival. Changed my 11-year old mechanical tensioner with the hydraulic version. To be clear, 11 year old tensioner/body with 2 year old pulley, as I have been changing them every 2nd belt change.
I got the updated version from pelican parts along with the rest of the small bits and pieces required to make the conversion. The engine does sound and feel smoother, other than that, haven't noticed any difference. No issues with the belt, even with the additional bracket from ESS with 2 extra idler pullies
Old 07-11-2013, 03:57 PM   #49
Quenotte
My Ride: E46
Hi Paris,
I plan to retrofit hydraulic tensioner to my car next week.
Did you also install the deflection-idler pulley in your new setup?
Quenotte is offline   Reply With Quote
Old 07-12-2013, 03:38 AM   #50
paraklas
No, just the tensioner, as I do not have a deflection pulley installed.
Old 07-14-2013, 05:57 PM   #51
Quenotte
My Ride: E46
Hi,
Thank you for your answer
Do you have a 90A Valeo Alternator on your car?
I have this setup (90A Valeo) on my car with no deflection pulley as well.
Maybe deflection pulley is only with 120A alternators?
Old 07-15-2013, 07:45 AM   #52
paraklas
I have no idea to be honest, with the s/c setup it's a bit different as I have an additional bracket with 2 pullies that are used to guide the belt around the s/c pulley. I can't remember if I ever had a deflection pulley as factory, although realoem does list one for my engine
Old 07-15-2013, 07:57 AM   #53
Quenotte
My Ride: E46
Thank you Paris
I should receive hydraulic tensioner retrofit parts this week
Old 07-19-2013, 04:39 PM   #54
Quenotte
My Ride: E46
I just updated my mechanical tensioner with the new hydraulic one.
I tighten tensioner bolts to 21Nm.
Old 03-29-2014, 10:47 AM   #55
Oz Striker
My Ride: '00 330Ci, '07 350Z
Question
Hi, just wanted to check, did you install the idler/deflection pulley?
I'm starting to get sick of the little squeal of the mechanical tensioner, after only 10k miles! I'm sure its fine, but i sometimes feel its a ticking time bomb! Hence gonna convert to hydraulic, and my car never had idler/deflection pulley from factory.
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 05-21-2014, 03:41 AM   #56
Runaway_510
My Ride: BMW 2001 330i
Hey, Realoem has the part listed as discontinued would anyone by chance know where else to find the part?
Runaway_510 is offline   Reply With Quote
Old 05-21-2014, 04:07 AM   #57
Runaway_510
Stupid question did my research sorry to post here
