Thread Tools Search this Thread Rating: Thread Rating: 76 votes, 4.79 average. Display Modes
Old 07-10-2009, 12:11 AM   #1
willsbma
My Ride: 99 323i
How to bleed your cooling system
Okay, so a lot of us here know how to properly bleed/fill our cooling system, but it's a terribly painstaking thing to write the whole procedure out every time someone needs help with it. Here is the right way to fill your cooling system.
Before you go crazy trying to fix an overheating car, make sure that your cooling system is in good shape.
For example:
Is your thermostat working properly?
Is the water pump spinning freely with no lateral motion or grinding noises?
Are your hoses in good shape, not bulging or cracking at the connections?
Is your expansion tank/radiator leaking from a small crack that you can't easily see?
Is your expansion tank cap old and maybe leaking or not letting pressure escape?
These are all eventual problems that our cooling systems suffer from.
If all the components check out and you still have problems, you most likely have air in your cooling system. Plumbers refer to this as "Air-bound."
The same thing happens in home heating systems. If you have baseboard heating in your house then you might have felt the heat on the left side and right side but not in the middle. Air can block the flow of water and cause cold spots. The same thing happens when air is trapped in your engine.
Here is the procedure for filling your cooling system to eliminate the possibility of air causing a blockage, and leading to an overheated (read: destroyed) motor:
Start with the engine cold!
Remove the small black bleed screw from the elbow that connects to the expansion tank.
Remove the coolant filler cap
Turn the ignition on but do not start the engine
Turn the climate control to the highest temperature and put the fan on the lowest setting
Slowly pour coolant into the expansion tank until coolant runs out of the bleed screw hole
keep pouring coolant until you no longer see any air bubbles in the coolant coming out of the bleed screw hole
Replace the bleed screw and check the coolant level in the expansion tank
Replace the expansion tank cap and start the motor
Allow the car to idle until normal operating temperature is reached
Watch carefully to make sure the temperature gauge doesn't rise above 12:00
If the gauge starts to move past 12:00 shut the car off immediately, let it cool and start over
After a few minutes of idling at normal temp it is safe to assume there is a minimal amount of air in the system. Take the car for a quick test drive, carefully watching the temperature. If all is well congrats, you have completed your task, if not, you may still have air in the system. Shut it down, allow it to cool and try again.
Hope this helps out.
Sticky?...
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 07-10-2009, 01:29 AM   #2
Darkoz
My Ride: E46 325Ci
I've seen this mentioned a couple of times, how does this help when adding fluid?
Darkoz is offline   Reply With Quote
Old 07-10-2009, 02:40 AM   #3
paraklas
My Ride: ESS TS2 320ci
Heater valve opens hence coolant flows through the heater core too
Old 07-10-2009, 03:01 AM   #4
Darkoz
My Ride: E46 325Ci
I see, thanks for clearing that up.
Old 07-10-2009, 10:45 AM   #5
hummer
My Ride: 2001 330CI
I would like to add the following:
Car should be on level ground.
If the system has been drained, it will take several fillings and some waiting for all the air to come out! Pour coolant in until it runs out the bleed hole. Stop and wait because the level will slowly drop as air rises to the high point and comes out. Keep adding coolant until the level at the bleed screw stops dropping. Now you have a properly bled system! I did not have to add more coolant after the drive.
Old 07-10-2009, 04:57 PM   #6
DBear
My Ride: 2001 325i w/SportsPk
I would emphasize pouring the coolant in 'SLOWLY'. Doing so will eliminate the need for frequent bleeding of the system.
DBear is offline   Reply With Quote
Old 07-13-2009, 04:04 PM   #7
willsbma
My Ride: 99 323i
Bump for more opinions
Old 10-01-2009, 11:46 AM   #8
pstrizz
My Ride: '02 325i 5psd. sport
I think I have air in my system, because of girgling, the temp is fine though...
when the car is cold should the hoses be full of coolant? I can open the bleed screw and squeeze either of the hoses and air comes out, but no fluid. anyone know if that is normal?
pstrizz is offline   Reply With Quote
Old 10-01-2009, 01:02 PM   #9
jmayn
My Ride: 04 325Ci
This is an excellent post. My low coolant level light keeps coming on then going off. I think when I filled it initially, i didn't bleed the system properly. I have looked a few times to check for leaks and *knock on wood* nothing so far. I'm thinking I can do this and it'll be solved. My temp gauge never goes above normal so that is good. Thanks for the info.
jmayn is offline   Reply With Quote
Old 10-01-2009, 02:37 PM   #10
FatBimmer
My Ride: was e46
Thanks!
I was gonna comment on the expansion tank thread but didnt get the chance.
Anyways, I think when the procedure is not done correctly, the system gets over-pressurized. Guess what happens... exploding expansion tank. The excess pressure has to go somewhere. Something's gotta give. And that's the poor old expansion tank.
Not all expansion tanks explode so dont blame the expansion tank being of poor quality. Instead THINK of how and why the engine cooling system gets over presssurized in the first place.
FatBimmer is offline   Reply With Quote
Old 10-01-2009, 02:47 PM   #11
David F
My Ride: 323i, 740iL, 633CSi
If you are having trouble with the expansion tank even accepting enough coolant, then start the engine and briefly rev it to 5000rpms. This forces the air past the air bleed hole in the thermostat; thereby, allowing you to add coolant.
David F is offline   Reply With Quote
Old 10-01-2009, 03:57 PM   #12
BMW04E46
My Ride: 2004 325Ci SMG
when the engine is cold, isn't the termostat closed, so how can the fluid flow? or does it open once you turn the heater on?
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-(
2002 530i Sport
1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-)
2007 Yamaha VX Cruiser (WaveRunner)
see my garage for pics
How a Rogue IKON should look on a M-Tech II Coupe
http://forum.e46fanatics.com/showthread.php?t=537372
BMW04E46 is offline   Reply With Quote
Old 10-02-2009, 10:56 AM   #13
hummer
My Ride: 2001 330CI
You need to fill and bleed the system as described above!
Old 10-02-2009, 10:59 AM   #14
hummer
My Ride: 2001 330CI
Originally Posted by FatBimmer View Post
Thanks!
The cap on the expansion tank is the pressure control device! 13-14 psi normally.
Old 07-21-2010, 01:47 PM   #15
jvidamins
My Ride: 2000 328i Manual
Here's the problem I'm running into. My expansion tank is already full. I open the bleeder screw, there's no water or air coming out. Heater's on high, fan on low, ignition at position 2. Yet, I'm getting to the red every time I drive, faster when AC is on. Then after a while, my AC stops blowing cold air and I have to shut it down. I'm hoping it's just air in there, but I'm not sure how to bleed if the expansion tank show full on the dipstick and no air or water is coming out of the bleed screw. Do I overfill the expansion tank until water comes out the bleed screw??? Or do I run the engine with heat full blast and open the bleeder screw??? A little help please.
jvidamins is offline   Reply With Quote
Old 07-21-2010, 02:59 PM   #16
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You're getting to the red every time I drive, faster with AC on?
JV,
You should not be driving the car and should know, if you've done any cooling work, that when it gets to red you shut it off and get it fixed...towed if necessary. You've done it repeatedly. Stop doing that...you know there's a risk of head gasket/head failure? $1500-2500.
Anyway, my advice is to read a lot of cooling threads, and then, prolly try the instructions exactly above...not sure you've done that...
Also, what were you doing to then need to bleed the system? Maybe that'll give us a hint.
My advice, follow proper bleeding procedure...if that doesn't work, follow the advice of someone really smart who can help you with bleeding while running...
Have you only used OE fluid...miles...other work done....etc?
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 07-21-2010, 03:27 PM   #17
jvidamins
JV,
Doug
I only tried bleeding because my temp gauge has been going between the 3/4 mark and the start of red zone the past couple days when driving with AC on. It hasn't actually gone into the red, but right at the edge. Not good either way. The first time I noticed it was when my AC went from good and cold to instantly pushing out lukewarm air. So I shut it off. Today after bleeding using your instructions, I took it for a test drive and temp was fine for the first mile (dead center) with AC on max. Then I accelerated fairly hard and within seconds it was up to the 3/4 mark. I shut the AC off and turned heat to full blast and temp went back down to dead center. AC back on, temp back up. I replaced the coolant and electric aux fan about a month ago with OE. Car has 170k and I just purchased it a couple months ago. Hoses look fine. Expansion tank is fine. No leaking fluid on driveway. Fluid level is full. No weird water pump bearing whining or noises. Is there a way to test and see if it's water pump? How do you know if it's your thermostat?
Old 07-21-2010, 03:48 PM   #18
dmax
dmax's Avatar
Thermostat is prolly tied with water pump as cause, but therm has to be replaced and at that point...don't know cost of WPs, but not having to go into cooling system again...priceless!
Also, not to be mean...but bet that's an original radiator too...$140 buys you a new one...maybe bracket for it...a few hoses, even those that look fine. The heater/engine cooling hoses are original...with 170K...only one is a pitb, and I gave up on it, but will get it next time system is open. Look at your rad really closely...you'll find picks of a failed one right here today.
Just saying, they're machines and cooling system is really important...I make no money saying this, you know, just hate to see bmws stranded or read about cracked heads.
...and add coolant in a.m. when it's cool...and I usually need to add a cup the first morning after a bleeding and maybe an oz or two the day after.
Oh, and you bled following my instructions or Wills, above? I reviewed them and think they're fine, but let it be on Will's head if he forgot something! LOL Anyway, it's Will's thread, so out of courtesy to him, think you ought to follow his instructions...also avail here in some thread from the original TIS...search bleeding/TIS something will likely come up too.
Some of my friends here bleed with engine on...but they know what they're doing...jury is still out on you! LOL Just be careful!
HTH
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 09-19-2010, 10:54 AM   #19
beauch3
My Ride: BMW 325
Here's is my problem. I replaced expansion tank, water pump, belts, thermostat and one of the hoses. I followed the procedure for bleeding but continue to have problems with the coolant light being on all the time. I replaced the sensor and it didn't make a difference. The car runs fine. Temperature doesn't go over mid point. I just hate having warning lights on. Any advice would be appreciated.
beauch3 is offline   Reply With Quote
Old 09-19-2010, 01:42 PM   #20
BimmersGarage
My Ride: E46 330i
@beauch3
Question:
Is your ET generic or BMW brand?
Because some generic tanks have an slight issue of the magnet within that's not lined up properly causing it to trigger the low coolant light.
BimmersGarage is offline   Reply With Quote
