Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
Old 02-23-2009, 01:30 AM   #41
00bmw323
My Ride: 00 323/91 integra RS
Will be doing this in a couple of days! any other info that i need??
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 02-23-2009, 02:51 AM   #42
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
torque specs would be nice..
well written DIY
Orz
BMWintoxication is offline   Reply With Quote
Old 06-05-2009, 03:30 AM   #43
DOB2009
My Ride: 325i
Originally Posted by artgod33 View Post
When you have the the brakes apart could you paint the calipers?
I hate seeing "open face" aftermarket rims on a car with stock brakes underneath.
And a full set of brembo's can run as much as a 95 Jeep Wrangler!
Would you suggest high heat paint? Gloss? Matt?
I was going to use black high heat paint, caliper paint is expensive.
DOB2009 is offline   Reply With Quote
Old 06-23-2009, 02:36 PM   #44
bmwguy330
My Ride: 2001 bmw 330ci
Send a message via MSN to bmwguy330
can you reuse the spring? or do you need to buy a new one? thanks
bmwguy330 is offline   Reply With Quote
Old 06-25-2009, 11:20 AM   #45
Wreckless
My Ride: E60 528xi
So is it okay to only put the front on jack stands (will only be doing front brakes) and leave the rear on the ground? or do I have to put the whole car on stands?
Wreckless is offline   Reply With Quote
Old 06-25-2009, 11:33 AM   #46
M-Spec Tuner
My Ride: 325i
That's the way I did it. Had no problems... Just have your parking brake engaged though. Good luck!
'03 325i...Just getting started!
M-Spec Tuner is offline   Reply With Quote
Old 08-01-2009, 12:40 AM   #47
easyIsle
My Ride: 02 330i
Post parts
I'm getting the wear indicator squeak in the rear so 'tis Brakejob time for me.
I'm wondering where you guys are buying your parts?
Making sure to get every part I'll need..
* New front and rear rotors
* New front and rear brake pads
* New front and rear brake wear sensors
* New e-brake shoes
* New brake disc retaining bolts
586.75 on pelican.
I'm Looking to get quality parts for most reasonable price, obviously. Tomorrow sometime I will cross ref the parts with tischer for lowest price, but i Would appreciate any other inputs on sources?
Thank you
easyIsle is offline   Reply With Quote
Old 08-06-2009, 09:02 AM   #48
skang330
My Ride: 2005 E46 330ci
Send a message via AIM to skang330
Nice DIY!
skang330 is offline   Reply With Quote
Old 09-11-2009, 06:10 PM   #49
jwhite2538
My Ride: 2002 323 xi
try
http://www.bavauto.com/shop.asp
jwhite2538 is offline   Reply With Quote
Old 09-15-2009, 02:39 PM   #50
phatchunk99
My Ride: '04 330Ci
I'm getting ready to change out the front rotors and brakes in a couple of days. At this time, I'm not planning on flushing the brake fluid. As I've read in quite a few places that moisture should be kept away from this fluid because it would potentially cause corrosion on the brake pistons. However, I've also read in places during the rotor/pad installation process to unscrew the cap on the brake fluid reservoir, which to me would allow moisture to go into the reservoir. Am I correct?
phatchunk99 is offline   Reply With Quote
Old 09-15-2009, 09:00 PM   #51
02alpinebimmer
My Ride: Not a BMW:(
Im not a pro but have done this on another vehicle in the past. For the first question, Moisture is not good but i really don't see moisture getting into your system if you just do the job and close it up right after-wards. Its also good to replace the fluid because it gets dirt, debris,and the fluid its self becomes burnt from everyday use. For the second, as long as the system is bled properly, there shouldn't be any issues at all if it's open or not.
I can read/reset airbag lights. (01 and up)
I can read/reset engine codes. (87 and up)
PM ME
-Steve OK-
02alpinebimmer is offline   Reply With Quote
Old 02-16-2010, 05:10 PM   #52
4g63GSX
My Ride: 07 RRS 03 325 94 GSX
Wanted to post the torque specs I found in another thread (thanks frogg):
Originally Posted by frogg320 View Post
From the Good Book:
caliper to brake pad carrier mounting bolts: 22 ft-lbs.
brake rotor to hub mounting screw: 12 ft-lbs.
pad carrier to front steering arm: 81 ft-lbs. (what a pain!)
and, for completeness:
pad carrier to rear trailing arm: 48 ft-lbs. (rear brakes only!)
-J
4g63GSX is offline   Reply With Quote
Old 02-20-2010, 12:12 PM   #53
4g63GSX
Just did rotors and pads and as an FYI I did not have to take apart the caliper with the 2 allen bolts listed below:
Originally Posted by 5speedsteve View Post
2 Small Allen Keys (the outer caliper to inner caliper)
I took the pads out like such:
Take the pads out of the caliper and slide two pieces apart (stationary section and sliding section)
But I did not take the allen bolts off to take the caliper apart like the OP:
Take the two Allen bolts off
I just put both pads back into the caliper and then mounted it back up.
Old 03-15-2010, 08:51 PM   #54
calialx1
My Ride: FL 330i, 3000GT
Thanks for writing this, really helped me out today as I was doing my rears. Something i learned, if your fluid is near the max mark you might want to put a rag under the reservoir because some fluid will spill when you compress the calipers.
calialx1 is offline   Reply With Quote
Old 04-15-2010, 07:39 AM   #55
lkstaack
My Ride: 04 330iZHP, 05 325iT
The DIY should have indicated applying anti-squeal to the rear of the brake pads and grease to the metal surfaces that come in contact with each other.
Brake squeal is generally caused by the vibration of brake pads. Anti-squeal provides a soft material that absorbes these vibrations as well as an adhesive that binds the pads to the brake piston.
Metal parts like the caliper dowels and the brake pad edges that mate with other metal parts should have grease applied to them to prevent wearing and ease of operation.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 05-24-2010, 04:20 AM   #56
M Shark
My Ride: '04 M3
Is this DIY also the same for Brembo BBk's?
_____________________________________________
M Shark is offline   Reply With Quote
Old 05-24-2010, 05:34 AM   #57
M-Spec Tuner
My Ride: 325i
It should be. The only extra step is the installation of the caliper relocation bracket.
Old 05-25-2010, 12:42 PM   #58
ddnmkun
My Ride: 03 E46 M3
Found this 3 diy video on youtube, they are all good demonstrations!!
[SIGPIC][/SIGPIC]
ddnmkun is offline   Reply With Quote
Old 05-25-2010, 12:51 PM   #59
M3FlyMe
My Ride: ///Mm Good
Send a message via AIM to M3FlyMe
Did mine two weeks ago with new cool carbon pads! It was super easy and I saved mad dough!
M3FlyMe is offline   Reply With Quote
Old 06-18-2010, 08:38 AM   #60
BMW04E46
My Ride: 2004 325Ci SMG
Great write up!
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-(
2002 530i Sport
1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-)
2007 Yamaha VX Cruiser (WaveRunner)
see my garage for pics
How a Rogue IKON should look on a M-Tech II Coupe
http://forum.e46fanatics.com/showthread.php?t=537372
BMW04E46 is offline   Reply With Quote
