Rating:
Display Modes |
#1 |
Parking Brake DIY
Does anyone know of a DIY to tighten up the parking break. I have done a search for it but cant find anything on tightening up the parking break.
#2 | |
The harder way is to jack up back of car, remove one wheel bolt, and stick a screwdriver into hold to turn adjuster. Here are the steps involved: 1) pull ebrake boot and loosen both bolts all the way 2) jack up rear wheel (or whole rear of car to do both wheels) 3) remove wheel bolt 4) turn wheel so removed bolt is 65 degrees off centerline (towards back of car) 5) turn adjuster all the way until you can't move wheel 6) back adjuster off 10 clicks 7) reintall wheel bolt 8) pull ebrake two clicks 9) tighten nuts until the wheels barely turn, with some resistance 10) reinstall ebrake boot Here's a picture with the wheel and rotor removed: ![]()
(0OO \ (||||)(||||) / OO0)
2000 323Ci, sport package, Shark Injector, AEM short ram CAI, UUC EVO3 SSK, 3.46 differential, Rogue pulleys, clears, USA-Spec iPod interface |
#3 |
this is great. i need to tighten it up too.
#4 |
If you are not the first owner, make sure your parking brake shoes aren't worn off. Gently pull up on the ebrake while driving slowly (DO NOT RELEASE THE LATCH BUTTON) If it squeals and scratches like metal on metal, probably time for new shoes, and or resurfacing the rotor drums.
The console way is easier, but jack up the car and put it in neutral to make sure that they both stop rotating at the same click. |
#5 |
mine used to go up until it hit the underportion of the arm rest!! i lowered it to about 6-7 clicks. thanks for the write up on this.
#6 |
Regional Sponsor
My Ride: 2000 E46 with 254K
Who is working on your these are supposed to be adjusted at every inspection service?
#7 | |
I understand everything but this. Do i move the teethed adjuster 'down' or 'up' with flathead screwdriver? |
#8 | |
Post back and let us know which was is which.
#9 |
On the right wheel - down and towards the front to tighten (expand the shoes).
On the left wheel - up and towards the back to tighten. |
#10 |
great diy!!!!
#11 |
Banned
So i tried to do this except without the picture awhile back. I accidentally popped a spring out of place which now randomly jumps around in the drum. How can i open it up so i can either remove it all together or put it back in place?
#12 |
I did mine this past weekend. Didn't bother messing around with rear drums. I just tightened the nuts under the ebrake.
#13 | |
Good luck.
#14 |
My Ride: 325xit 5spd, E39 M5
subscribing
high miles or go home
#15 |
good luck finding the clicking thing by using the holes like in the pic....they are a ***** to find...eaiser to just remove the rotor...move the clicking thing and put rotors back and keep repeating until adjusted correctly
#16 |
270,000km DIYs done: -Front Control Arms Oil Filter housing gasket -SS Brake Lines -Rotors & Brakes -Overhauled cooling system (waterpump, thermostat, radiator, hoses, etc) -Silver gauge cluster -DICE ipod integration -60 LED angel eyes -Crankcase ventilation valve -Front Hub bearings -next will be rear bearings ![]() |
#17 |
#18 |
Just did this today, and I ran out of thread on the driver's side adjuster (behind the disc).
Looks like I need new shoes. 3 clicks lock the wheels from going foreward, but the driver's side will still spin in reverse. |
#19 |
so I want to get this straight..if I do the adjustment from the inside the car/eboot..I have to tighten the right screw towards the front (seating in drivers seat) and the left to the back of the car (seating on drivers seat)..does the ebrake have to be engaged while doing this?
#20 | |
Righty tighty, lefty loosey lol. Make sure you tighten each side evenly. Lifting up the e-brake just makes the screws more easily accessible. |
