Removing front turning lenses - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-22-2006, 01:38 PM   #1
el_haix
My Ride: 325I
So I should be able to put a screw driver in through the body panel hole to loosen the front turn signal lights. Problem is that, through that hole there isn't a screw, but an adjustment knob, like the one used to aim your headlights.
How do I take these puppies out?
Also, I've seen a the 'snap in' and 'screw in' housing on the JleviSW - does that mean mine are snap-in if there's no screw?
Thanks.
el_haix is offline   Reply With Quote
Old 10-22-2006, 01:45 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
If you have a 1999-2001 Sedan, you do not have screw in types. You have a push in type whereby you use a flat head through that hole to push down on a tab and slide out the clear.
If you have a 2002-2005 sedan, you have screw in style turn signals and need to insert a phillips head screw driver in that hole to loosen the screw and slide out the turn signal
Old 10-22-2006, 01:53 PM   #3
el_haix
My Ride: 325I
Thanks!
Perfect - that's the answer! Thanks!
So what are those adjustment knobs for just under the tabs?
