Old 10-24-2006, 12:31 AM   #1
valenti
My Ride: Rated M
2001 Xenon Cutoff
i noticed that compared to almost every other car out there with xenons, even regular halogen projectors on Mazda3's, my cutoff line is very sloppy. Is there any way i can make it sharper ? mazda frickin 3 has a nicer cutoff and thats BS.. btw i drive an 01 330ci non-bixenon.
valenti is offline   Reply With Quote
Old 10-24-2006, 06:55 PM   #2
BMW Loe
My Ride: is dirty
One way is to purchase an ECE lense or an ECE E46 projector from www.hidplanet.com . Information on E46 projectors can be found here www.hidplanet.com/forums/ but you must register to use it. ECE lense are clear in the center but fresnal on the outer edges so it will make your horizontal cutoff pretty sharp.(DOT like the one on your car, uses a fresnal lense which is why its fuzzy) Another idea is to swap to a clear lense from another vehicle with halogen projectors with the same focal point (its a trial an error actually). Bending the cutoff shield doesn't do much for the single xenon units, they are already almost flushed with the bowl.
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection
04 M3 sold
03 330Ci sold
BMW Loe is offline   Reply With Quote
Old 10-24-2006, 07:00 PM   #3
valenti
My Ride: Rated M
how come the xenons on 03+ e46 have a sharper cutoff then ?
Old 10-24-2006, 08:11 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You are probably noticing the difference in housings with the upgrade to bixenons in 02+ cars.
Old 10-24-2006, 08:40 PM   #5
BMW Loe
My Ride: is dirty
Bixenon's have a frosty lense and not a Fresnal lense. Also, the cutoff position, bowl shape, and size of the lense comes into effect. Bosch Bi-xenon's are still fuzzy in their cutoff compared to the likes of Stanley or Stanley/hybrid projectors used in the TSX, TL (fresnal), and S2000. P46's have a sharper cutoff (though less light spread) than either the Bosch singles or Bosch Bi-xenons.
ZKW (vs. Bosch on others) bi-xenon's IIRC only came on 2004 330Xi's, these are the sharpest E46 projectors available because they use a clear lense.
E92 335i 6spd
04 M3 sold
03 330Ci sold
Old 11-05-2006, 01:34 AM   #6
PYRITE
My Ride: 1965 Ford Mustang
How hard is the swap to:
http://www.hidplanet.com/bosch.html
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 11-05-2006, 03:56 AM   #7
colombacho
My Ride: 325i
I would like to get the cut off effect that you see on the S2k. also on these hidplanet ones i hate that z pattern. any other ones without the Z cut off pattern?
and sorry for the thread jacking.
colombacho is offline   Reply With Quote
Old 11-08-2006, 11:39 AM   #8
colombacho
My Ride: 325i
TTT, not my thread but still interested
Old 11-11-2006, 05:00 PM   #9
BMW Loe
My Ride: is dirty
The only way to get a cutoff like S2000's is to modify and make your own shield. A lense swap requires you to open up the entire headlight from inside and a good set of steady hands.
Here is my cutoff with my own shields
http://sio.midco.net/loe1/beamshotm.jpg
E92 335i 6spd
04 M3 sold
03 330Ci sold
Old 11-11-2006, 06:16 PM   #10
PYRITE
SEX, how much to modify mine if I mail them to ya. Send me a PM
PYRITE IS SOLD!!
Old 11-11-2006, 07:36 PM   #11
BMW Loe
My Ride: is dirty
http://forum.e46fanatics.com/showthr...ghlight=cutoff
The directions are for P46's. OEM units use TORX screws so you'll need a set. I don't want to be held liable for anything, this process is VERY hard to get perfect, you'll more than likely break some peices (though non visible peices and it will still be fully functional).
Picture of beam shot at the bottom is the old shot. I since changed to a DO-type shield instead of the Euro-type shield.
E92 335i 6spd
04 M3 sold
03 330Ci sold
Old 11-13-2006, 06:45 PM   #12
BMW Loe
My Ride: is dirty
FYI, I might be selling mine if I don't break it open first when I get my new pair of OEM ones and modify it.
My 5000K HID's are more blue than my friends 6000K bulbs from 100yrds away because of the blue band of color above my cutoff, but I still have the funtionality of 5000K bulbs illuminated white-ish/yellow; he has a stock DOT OEM single xenons w/ non color shifted bulbs and his illuminated slightly white/blue on the road which is arguable harder to see things in detail.
E92 335i 6spd
04 M3 sold
03 330Ci sold
