Sponsored by The Tire Rack
Old 11-13-2006, 03:07 AM   #1
Coldduk
My Ride: 2003 325Ci Hartge Cp
Send a message via AIM to Coldduk Send a message via MSN to Coldduk Send a message via Yahoo to Coldduk
Correct Tire pressure 35 and 45 profile
I know I should know this but with $200 tires I want to be sure. The tires say max psi 50lbs but the yshould run between 32-35 psi right? Thanks guys.
Hartge Wheels, Emblems, Interior, CF Interior Trim, IKON exhaust, CF grill, Drilled & Slotted Rotors, Euro-Spec M3 bumper with CF Spoiler lip & struts, Hartge rear apron...
Coldduk is offline   Reply With Quote
Old 11-13-2006, 03:32 AM   #2
Rachel9731
My Ride: 2004 325i
In the owner's manual, it says that for factory approved tires it should be 30 psi for the front and 35 psi for the rear.
Rachel9731 is offline   Reply With Quote
Old 11-13-2006, 08:39 AM   #3
mpappas
My Ride: 2001 320i
when you open your drivers door it has the tire sizes and whether its a winter or summer tire and the pressures for the front and back, I believe for 15" it says 29psi for front and 32 for the back, just check it out either there and in the owners manual as said already
mpappas is offline   Reply With Quote
Old 11-13-2006, 08:42 AM   #4
Prembird
My Ride: 2002 M3 ACS SMG
If you really wanna find out... Go get a crayon or grease pen and draw a line across each tire... Inflate to 35 psi and drive it for a bit... If the line wears off evenly then there yea go.. If the center wears out first let air out... If the outside wears off first then inflate...
Do that till you get even wear and you will have the correct air pressure for each tire...
There are 3 goals when modding a car.
Cheap, Reliable, and Fast.
Now the down side. You only get to pick 2
Prembird is offline   Reply With Quote
Old 11-14-2006, 07:55 PM   #5
Mikaly
My Ride: TiAG 323i on 19s
Brilliant.
Mikaly is offline   Reply With Quote
Old 11-16-2006, 01:17 AM   #6
hosagod
My Ride: Facelift Ci
Very cool! Thanks for that...
And yes, 32-35 is ideal.
hosagod is offline   Reply With Quote
