Sponsored by The Tire Rack
Old 11-15-2006, 05:26 PM   #1
icosaca
My Ride: BMW AA blown 325 ci
wheels, tire suggestion advice for the track please
ok guys.
so when i installed m3 front fenders on my car, front wheels didnt stick out much, so i installed half inch spacers in the front... it looks cool, but when i take it to the track, it understeers, due to tue front being wider i guess...
now i decided to do a wide body on the rear, to be able to bring my rear tires out also to be even with the front, or maybe even wider.
my question is, should i use spacers??? should i buy something like 11 inch wide wheels, ????
what to do
thanks guys
jorge saca
icosaca is offline   Reply With Quote
Old 11-16-2006, 12:54 AM   #2
hosagod
My Ride: Facelift Ci
Is it M3 wide fenders or wider? You should be fine with 11s in the back as long as the offset is appropriate. Put up some wheels and their specs and I can tell you if it will work.
hosagod is offline   Reply With Quote
Old 11-16-2006, 09:35 AM   #3
icosaca
thing is, for now, im trying to go the cheap route, and just get spacers for the rear....
do you think that will damage bushings, or afect performance???
jorge saca
i called tire rack yesterday, and they dont have any 19*11 wheels for my car...
jorge saca
Old 11-16-2006, 11:57 PM   #4
hosagod
I don't see any problems with spacers.
Old 11-17-2006, 11:01 AM   #5
icosaca
yeah, i think ill go with spacers for now, and save up a pit for some new wheels later.
jorge saca
Old 11-17-2006, 06:11 PM   #6
TheModCity
Past Site Sponsor
TheModCity's Avatar
My Ride: E46 M3 & C6
Send a message via AIM to TheModCity Send a message via MSN to TheModCity Send a message via Yahoo to TheModCity
jorge saca
TheModCity is offline   Reply With Quote
Old 11-17-2006, 08:40 PM   #7
Triflowm5+M3
Gear up, shut up!
My Ride: 2005 'Yota 4runner
Send a message via AIM to Triflowm5+M3
More info is needed....
What size are you currently running both front and rear...what sizes do you plan on running later on (including diameter). How much track work do you really expect to see.
19" Rcompound rubber isnt exactly easy to find...18" has more options. Running wider and wider rubber is only going to add to understeer and heavier steering.
Truth be told, I think I thrive under a lack of accountability[/SIZE]
Triflowm5+M3 is offline   Reply With Quote
