Sponsored by BAVSOUND
Old 11-13-2002, 09:37 AM   #1
marc_i_brown
ground point
is there any reason to NOT ground my amp at the same point the stock HK amps ground to? i would still be using the main HK amp. if i should not do that, where do have you been grounding your amps?
thanks,
marc
marc_i_brown is offline   Reply With Quote
Old 11-15-2002, 01:54 AM   #2
johnhab
My Ride: '02 330xi
Send a message via AIM to johnhab Send a message via Yahoo to johnhab
As long as you ground all your new gear to the same spot, I don't believe you'll get a ground loop. I just grounded my new amp to the ground block on the passenger trunk wall, which is opposite to the trunk wall where the HK is, and have had no problem.
Better picture coming!
johnhab is offline   Reply With Quote
