Front wheel bearing maintenance? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-17-2006, 04:11 PM   #1
Apollo10
My Ride: 00 e46
Hi everyone,
Since there's no real maintenance schedule for the front wheel bearings, I'm curious if anyone has periodically removed the outer cap and injected grease into the bearing sidewalls as preventative maintenance.
Granted you probably can only used either a synthetic spray grease or a needle gun to get into the tight clearance, but wondering if it's worth the trouble?
Considering how many people have replaced them, anything to lengthen their life is welcome.
Apollo10 is offline   Reply With Quote
Old 11-18-2006, 04:35 AM   #2
ian_clyde
whoo da daddy...
ian_clyde's Avatar
My Ride: 1999 318i SE
Send a message via MSN to ian_clyde
i just replaced the bearing as they will wear anyway even with more grease.....just not a quickly..
.....i want to die sleeping like my grandfather...not screaming and shouting like the passengers in his car.....
ian_clyde is offline   Reply With Quote
Old 11-18-2006, 03:18 PM   #3
Apollo10
My Ride: 00 e46
At what mileage did you replace them?
Sponsored Links
Advertisement
Old 11-18-2006, 11:17 PM   #4
LI_BIMMER
LI_BIMMER's Avatar
My Ride: 2000 - i, 2003 X5
My bearings were replaced about 8 weeks ago on both sides of the front at 49,200 miles. I now have 50,010 and no issues, although I am now wondering about the rears.
2000 3xx i & 2003 X5 - Forgot the model, I debadged it.
LI_BIMMER is offline   Reply With Quote
Old 11-19-2006, 07:28 AM   #5
ian_clyde
whoo da daddy...
ian_clyde's Avatar
i have 98k at the minute...and going strong...replaced about 2k ago along with front control arms and bushings, and new rotors and pads all round
Old 11-19-2006, 04:37 PM   #6
///M3-QTR
My Ride: IR M3
I just replaced mine on my 01 M3 with ~82,000 KM .
///M3-QTR is offline   Reply With Quote
Old 11-19-2006, 07:55 PM   #7
teamdfl
Slow in, slower out
My Ride: 325it
Front and rear wheel bearings don't need any maintenance. When they start making noise, replace them. You might get extra life out of the new ones if you pop out the seals, clean out the factory grease, and load them up with a good synthetic grease such as Red Line CV-2 prior to installation.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 12-12-2006, 12:32 AM   #8
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
Bingo.
The bearings are sealed so there is no point in greasing them.
That said, I just replaced one this weekend and I'm surprised how much moisture/rust got into the bearings. Cheap crap.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 12-12-2006, 08:23 PM   #9
james2538
My Ride: Sold
How hard is it to DIY front wheel bearings?
james2538 is offline   Reply With Quote
Old 12-12-2006, 09:03 PM   #10
Geo31
Ironman
Mine was easy. I did not need to use a puller to remove the bearing/hub assembly nor the inner race when it separated from the assembly, although it separated at the end of the stub axle.
Putting the new assembly on I just warmed up the assembly so it slid right on the stub axle.
If either the assembly or the inner race were problematic, it would have been a bit more of a pain, but probably not much more with the pullers on-hand.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 12-12-2006, 09:41 PM   #11
james2538
My Ride: Sold
Alright Thanks!
Old 12-13-2006, 03:12 PM   #12
Lbert
My Ride: 325i
As I suspect my front wheel bearings may be worn. I did not realize they could go bad as eary as 50k miles. I just got a 2001 325i with a noisy front wheel. I first taught it might be the just a noisy tire. You would hear the rolling noise around 10 to 20 miles per hour. When you guys changed your front wheel bearings, did you need a wheel alignment afterwards?
Lbert is offline   Reply With Quote
Old 12-13-2006, 08:07 PM   #13
Geo31
Ironman
No. There is nothing that can change the geometry. Go for it.
The front bearings on these cars suck donkey. My RF went at about 65k miles and the LF at about 75k miles.
The biggest issue to beware of is the inner race hanging up on the stub axle. Mine did, but only at the very end and I was easily able to pop it off w/o drama. But, others have had issues. Looks like it shouldn't be too bad if you actually have the pullers on-hand.
If you have trouble installing the new bearing, I had great luck heating it in the oven (pre-heat to 200 degrees) for 10 minutes.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 01-10-2007, 05:17 AM   #14
RRE
My Ride: E46 320D
Exclamation
Does anybody have the torque settings for the axle-retaining nut? I read 210 ft./lbs, can anybody confirm that?
Thanks in advance
RRE is offline   Reply With Quote
Old 01-10-2007, 08:30 AM   #15
CC737
My Ride: 06 M3
according to Bentley.
-Rear wheel drive cars-
Front Suspension page 310-29
Collar nut to stub axle 290Nm (214 ft-lbs)
hope that helps
CC737 is offline   Reply With Quote
Old 01-10-2007, 09:28 AM   #16
RRE
My Ride: E46 320D
Old 01-10-2007, 09:42 AM   #17
deletedpenguin
deletedpenguin's Avatar
My Ride: is gone!
I'm assuming mine will be going soon.
Stefan | American by birth, Swedish by heritage, Australian by choice.
My current photo galleries.
deletedpenguin is offline   Reply With Quote
Old 01-10-2007, 01:33 PM   #18
PreppyR6
My Ride: shines like justice
What are symptoms of the fronts going out. I dont know if mine have ever been replaced and i have 115k mi
PreppyR6 is offline   Reply With Quote
Old 01-10-2007, 01:50 PM   #19
tolys bimmer
My Ride: 323i/328i
so what is the size nut? i tried replacing mine and i cant find the sucket size that fits because its huge. i was thingking 24mm but i might be wrong.
tolys bimmer is offline   Reply With Quote
Old 01-10-2007, 03:23 PM   #20
teamdfl
Slow in, slower out
My Ride: 325it
The front bearing retaining nut requires a thin wall 46mm socket. Some thicker wall impact sockets will not fit. In a pinch, you can use a 1-13/16" regular (non-impact) socket in 3/4" drive which might be available at your local Sears. Don't forget to get the appropriate drive adapter for your tools and torque wrench. Also, the new nut should be torqued to 216 ft-lbs if I remember correctly. Make sure your torque wrench can be set that high.
