Sponsored by The Tire Rack
Old 11-21-2006, 07:19 PM   #1
JD1058
My Ride: BMW 2002 330Ci 5pd
Wheel Vibration
My front wheel vibrates at speed of 60 to 100km/hr but it is worst when i am braking. I went to the dealer today and they told me it that caliper was the problem and they rebuilt them but i still have to problem. Does any one have the same problem?
JD1058 is offline   Reply With Quote
Old 11-21-2006, 09:13 PM   #2
eric@spp
Past Site Sponsor
Wheel Wobble
What kind of wheels are on the car?
If aftermarket...sounds like you may need hubcentric rings
If stock...sounds like you need a proper balancing.
Let me know which of the above. Its usually a simple fix not involving rebuilding a caliper
eric @ spp
www.supremepowerparts.com
eric@spp is offline   Reply With Quote
Old 11-21-2006, 10:54 PM   #3
SWINFORD
///PIITB
SWINFORD's Avatar
My Ride: Low Life Marie
Send a message via AIM to SWINFORD Send a message via MSN to SWINFORD
You need to reword your question a little.Not to be a prick its just hard to understand the last half
Swinford-Hypnotyzd : Dirty South-Swinny
| Hypnotyzd FB |Tischer BMW|
SWINFORD is offline   Reply With Quote
Old 11-21-2006, 11:31 PM   #4
JD1058
i used to have aftermarket wheels for summer but now i do have oem wheels for winter. The vibration happened with aftermarket ones also with oem ones.
ANd dealer told me that it was a front caliper problem that's making vibration and to fix it they told me that i have to either change to a new one or rebulild them. TO save some costs, i decided to rebuild them. But once i got my car back with capliper rebuilt, vibration was not disappealed.
Old 11-22-2006, 01:07 AM   #5
white46
My Ride: e46 323ci
if it is worse during braking, then please check your rotors. it may be warped.
and if that is not the problem, then please check control arm and bushing.
white46 is offline   Reply With Quote
Old 11-22-2006, 08:49 AM   #6
JD1058
THanks guys
