Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 10-13-2008, 09:28 PM   #181
bobcat
My Ride: e92 & e46
Just 2 questions -
1.
Back on p5 of this thread Tom mentioned the only way to eliminate the group loop problem was with the gli (ie. when i plug the iphone charger into the cigarette lighter to charge, aux doesn't worK); Is it possible to ground the diy aux cable to somewhere else to charge and play via aux at the same time?
2.
Since I'm using the iPhone, with the diy aux cable, all phone calls are now played via the car stereo speakers, but microphone of the phone itself is still being used (which can be inconvienient since the phone is hidden inside the sunglasses compartment); Is it possible (and how) to tap into the oem microphone above the rear view mirror (I'm assuming it'll have to be done with the harness hidden inside the centre console?)?
bobcat is offline   Reply With Quote
Old 10-14-2008, 11:28 AM   #182
toffa
My Ride: 320ci
Send a message via MSN to toffa
Originally Posted by Leon_s View Post
Do you have more info or pics of where the resistor should be installed?
Does it work?
This is the picture I made during the realization of my cable.
At the moment I'm using it
toffa is offline   Reply With Quote
Old 10-14-2008, 08:17 PM   #183
andryxa
My Ride: 2002 m3 vert- Sold
k i tried doing this today and when take out the stereo i cant take out the plug. i lift it up and then what do i do?
the links to the other sites didnt really help me. once i lift the main plug with a screw driver do i just pull it off or how does that work?
andryxa is offline   Reply With Quote
Old 10-15-2008, 01:28 AM   #184
rorschach
My Ride: '01 318i
Pull it up very hard and the whole connector will pop off.
rorschach is offline   Reply With Quote
Old 10-15-2008, 04:13 AM   #185
toffa
My Ride: 320ci
pull up!
Old 10-15-2008, 03:53 PM   #186
adrianpl
My Ride: 01 330ci
http://www.geekmatica.com/modules.ph...article&sid=23
adrianpl is offline   Reply With Quote
Old 11-08-2008, 01:02 AM   #187
Burger888
My Ride: 03 325i M Sport Pack
I completed this DIY today and its work superbly. I mounted a 3.5mm stereo jack socket at the back of the sunglasses case as described here http://forum.e46fanatics.com/showthread.php?t=547723.
Couple of observations from my experience
1) Mine worked fine with the straight cable without any capacitors or resistors. I used LED/switch wires from an old PC as suggested and just soldered 'em straight up to the 3.5'' jack. The AUX input is detected by the head unit as soon as your iPod is connected, this obviously provides a load that the head unit can detect.
2) Pulling the sunglasses holder out was impossible from the front! I read plenty of threads about how to get it out and I couldn't do it! I managed to get it out easily in the end by popping out the aircon control panel which allowed me to reach in behind and push the sunglasses holder out from the back. Worked a treat.
I gotta say, it sounds wicked!
Burger888 is offline   Reply With Quote
Old 01-14-2009, 08:58 PM   #188
kkeddy
My Ride: 325i
just did it today! AWSOME diy. thanks saved 100$ (in canada) the kit is mad expensive. lol. the
the deck needs to reeive signal from both LEFT AND RIGHT in order to have the aux mode if anyones questioning about aux mode.
kkeddy.
03 325i
2010 Civic SI
2001 m3
kkeddy is offline   Reply With Quote
Old 01-29-2009, 12:17 AM   #189
blackbeam05
My Ride: 2004 325i
i know this is a stupid question but can someone lead me to where i can find this pc cord or something similar please? also...maybe this link will help me and you find the part..thanks
http://www.google.com/products?hl=en...+pin&scoring=p
blackbeam05 is offline   Reply With Quote
Old 02-01-2009, 03:51 PM   #190
blackbeam05
My Ride: 2004 325i
anyone??..please...
Old 02-01-2009, 04:41 PM   #191
kkeddy
My Ride: 325i
its a really small plug that connects to the led indicator/power/reset switch to the motherboard
kkeddy.
03 325i
2010 Civic SI
2001 m3
Old 02-14-2009, 10:42 AM   #192
Atlas
My Ride: 320i
Send a message via ICQ to Atlas
Would something like this (http://cgi.ebay.com.au/Ground-Loop-I...3A1|240%3A1318) work to allow charging from the cigarette lighter whilst using AUX input?
Atlas is offline   Reply With Quote
Old 02-28-2009, 08:18 PM   #193
jdmtyteeeyo
My Ride: 2004 325ci
Send a message via AIM to jdmtyteeeyo
hmmm i did this and i am having a whistling noise comming from my speakers whever i plug it in .. and when i switch songs it makes a weird noise too... thinking its a bad connection???
jdmtyteeeyo is offline   Reply With Quote
Old 04-13-2009, 02:08 PM   #194
elbutio
My Ride: 05 320D and 99 323
Hi folks, followed this post today and made a cable exactly as described. I have connected it to my BMW business cd/radio but can't get it to work, it won't enter aux mode. I have the mode button and my car is an 05 320d so a later model Business cd that also plays mp3 cds.
Do i need to install resistors for this to work?? Any help or information would be greatly appreciated.
elbutio is offline   Reply With Quote
Old 04-13-2009, 02:35 PM   #195
rorschach
My Ride: '01 318i
It will only enable AUX if you have a working music player connected.
Old 04-13-2009, 03:53 PM   #196
elbutio
Thanks for the reply -forgot to say my mp3 player was connected, also tried laptop via headphone socket to be sure.
If any use my cd player says BMWRCD109-04 on the top.
Old 04-16-2009, 03:35 AM   #197
JacksonY
My Ride: BMW 330Ci (2004 E46)
I have a 2004 330Ci, my car has OEM CD Changer... can I still do this since it seems to use different pins?
2004 BMW 330Ci - Sapphire Metalic Black
http://www.conceptfury.com/
JacksonY is offline   Reply With Quote
Old 04-16-2009, 08:56 AM   #198
--Ice--
My Ride: E46 320Td Compact
Any ideas?
Without the resistor and condensors aux worked about 5sec and then changed back to radio.
Ok, then i bought resistor and condensors, added them to the cable and.... Nothing!
What's wrong, i'm starting to loose my mind.
For testing i have an mp3 and cd player.
--Ice-- is offline   Reply With Quote
Old 04-16-2009, 12:51 PM   #199
--Ice--
Everything's ok now. I connected the condensors wrong.
Thanks for the DIY
Old 04-19-2009, 02:22 AM   #200
guest041115
Banned User
SV 20-02 41
FUUUUUUUUUUU
guest041115 is offline   Reply With Quote
bmw aux in, diy aux input, input cable
