Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 08-25-2009, 10:18 AM   #261
valks
My Ride: 320D
Someone must be able to help myself and oil burner!
Has anyone managed this with a iPhone?
Networking superstore
Cheapest supplier around !
http://www.networkingsuperstore.co.uk
valks is offline   Reply With Quote
Old 08-25-2009, 07:44 PM   #262
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Try plugging something else in with a standard 3.5mm mini-jack output to establish if your AUX input works?
Then research if maybe there's something non-standard about these Apple devices?
Some devices for example might have multiple contacts inside the 3.5mm socket for remote control functions that a standard 3.5mm plug may short out?
My Nokia phone has an extra contact/band on it's headphone extension cord's 3.5mm plug for example to enable the remote control to work, luckily it still seems to work ok if you insert a standard 3.5mm plug.
tony325ci_51 is offline   Reply With Quote
Old 08-26-2009, 01:08 PM   #263
snowcatxx87
My Ride: 04 330CI
I can CONFRIM that my iPhone 3G-S works with my AUX input. (iPod/internet radio)
I do not have any resistors or anything on my aux input cable. I am going to be installing a GLI to my aux cable though, so I can power my iPhone while playing music from it. The TOMTOM app for iphone kills the battery. 30 minute trip, the battery is dead.
snowcatxx87 is offline   Reply With Quote
Old 08-27-2009, 11:08 AM   #264
SaN NizZLe
My Ride: 2000 328Ci
Can I do this DIY Mod if I have an older BMW business radio unit? The one without the MODE button??
Looking to do it on my 2000 328ci
SaN NizZLe is offline   Reply With Quote
Old 08-28-2009, 12:16 AM   #265
tony325ci_51
No, 2000 is too old, read the whole thread for info
Old 08-29-2009, 05:26 PM   #266
ab0234
My Ride: 330Ci
Aux input switching off.
I built the original cable in this thread and it worked fine with my iPod touch as long as it was plugged in. When I unpluged it the AUX would switch to the SAT radio which was OK with me until I bought a Griffin Autopilot for charging and play control. It wouldn't work at all. I couldn't switch to AUX. So today I read through all the stuff about the cable with the resistor and the two caps inline and I found on the original German page run through Google translate that this circuit is in the end of the OEM cable to trigger the AUX and isolate it from connected items to keep them from turning it off. So I built one and it works perfect with the Griffin Autopilot controller. So it should also work with the iPhone. The AUX is always available even without anything pluged in which is not what I had before. I didn't use a circuit board, just crimped then soldered everything inline then covered it all with heat shrink. So, all you need is two .22uf caps inline on the two signal wires and one 330K ohm resistor across the two signal wires on the radio side of the caps and that will trigger and isolate it.
ab0234 is offline   Reply With Quote
Old 08-31-2009, 09:48 AM   #267
'busa
'busa's Avatar
My Ride: E90 335i (sold)
I bought the capacitors, resistors, a stereo audio wire, and a plug. I had to buy a $6 resistor kit to get the 330k Ohm one, but whatever. Total is about $20, but at this point, I'm doing it more to get it done myself than to save a great deal as compared to the BMW Aux Kit.
Looking forward to doing this.
'busa is offline   Reply With Quote
Old 09-01-2009, 04:48 AM   #268
Magsy
My Ride: '04 M3 Coupe
Maybe something is different in the EU cars but I couldn't make it work. I am very experienced with electronics, I've built several amplifiers/dacs/power supplies etc but this DIY wouldn't work. I tried with and without the resistors and caps but at no point did I get AUX on the CD Player, even with a device connected.
In the end I bought the original cable and it worked first time. I have a 2004 M3. I have read at least one other with an EU car having the same problem so maybe something to look out for. The pin out on the BMW is the same but I was unable to mesure the resistance for some reason, it appeared pretty much open circuit.
Magsy is offline   Reply With Quote
Old 09-15-2009, 10:52 AM   #269
tony325ci_51
Mine's a UK Nov'04 model, business CD player (no autochanger).
Simply clipping a 300k resistor between pins 8 & 9 then switching on enabled the aux mode to appear when cycling with the "mode" button.
Old 09-15-2009, 03:22 PM   #270
snowcatxx87
My Ride: 04 330CI
I use my AUX in with iPhone 3G-S 32G everyday.
To charge, you need to install a Ground-Loop Isolator in the audio line.
Old 09-16-2009, 03:02 AM   #271
valks
My Ride: 320D
Ok here is what i had to do.....
I first plugged the leads into the HD and then into my Iphone....Aux would not show.
I then installed a 330k resistor and aux showed but as soon as i plugged the iphone in, it would switch off.
I then installed 2 x .22uf capacitors inline as advised by ab0234.
Now when i plug my iphone in everything is working great.
Problem solved for iphones.
Old 10-03-2009, 02:45 PM   #272
blue442
My Ride: 330ci
so badass.
ty very much.
i just did this today as a result of this thread.
using a treble boost on the iphone it makes the sound, sound so much better. it should hold me over for now
blue442 is offline   Reply With Quote
Old 10-12-2009, 11:15 AM   #273
Puffy
My Ride: BMW 318i
Hi I have been following this thread and have tried to get this working for my self but to no success I've bought a wire which does exactly what was shown in the DIY could some one please help me. I have a E46 2004 318 and live in the UK. My HU Software version is 46-03-540 if that helps. Thanks for any help in adance!!!
Puffy is offline   Reply With Quote
Old 10-13-2009, 12:12 AM   #274
Sean S
My Ride: 2001 325i
Hey I'm wondering if this will work with the following CD player:
http://forum.e46fanatics.com/showthr...=#post10729769
2002 325i
Alpine
Jan/02 build date.
SW/NO 41
HW/NO 43
I want to have an aux. input AND an ipod link with my headunit. I currently have the 2001 no-mode-button radio. What's the best way of going about this? Buying this deck for $100, then an ipod link as well (I-Simple or USA-Spec), or just getting some other interface with both an aux.-in and an ipod link to work with my current radio?
Sean S is offline   Reply With Quote
Old 10-14-2009, 05:19 PM   #275
piotrek636
My Ride: 2003 330Ci
Does anyone know what are all the hidden options for ?
if you hold the "m" button for 10 seconds, you can scroll through few things such as SW version etc like someone pointed out, you can change the values for each setting using the 1-6 buttons.
Does anyone know what all of them are ?
I was so far able to figure out that my stereo was in the USA mode so I switched it to Canada (dont think it matters much anyway)
EDIT: nevermind, I found it: http://www.bimmerboard.com/members/a...rvice_mode.pdf
piotrek636 is offline   Reply With Quote
Old 10-14-2009, 05:22 PM   #276
piotrek636
My Ride: 2003 330Ci
I believe you can, it will show CD1 instead of the AUX,
I think it just fools it to think it's a CD changer. ?
http://www.mindspring.com/~pmbenn/iPod/330i.htm
Old 11-03-2009, 03:09 PM   #277
zugellos
My Ride: '02 330i
So...is there a way for someone like myself who's:
- HU is an 03/02 with SW xx-xx-41
- Got no CD changer to even do the cable detailed in this thread http://forum.e46fanatics.com/showthread.php?t=427248
to have some sort of AUX capability without resorting to the BMW Kit, or DICE or whatever else there are which requires dishing out a good sum of money?
Please help...there's got to be someone out there whom might stumbled upon something that works for relatively cheap.
TIA!
zugellos is offline   Reply With Quote
Old 11-13-2009, 05:41 PM   #278
herbie
My Ride: is bone stock
hi, i am an e46 newbie. i have a 99 323i with the business cd player and a cd changer. will this set up work for my car?
thanks in advance
herbie is offline   Reply With Quote
Old 12-20-2009, 11:31 PM   #279
xbluedr4gonx
My Ride: 2.5L I6
I just finished this project, took me about 2-3 hours cause i never took apart anything inside my car. It was fun, i love these types of projects; cheap and effective!
Thank you!!!
xbluedr4gonx is offline   Reply With Quote
Old 12-22-2009, 08:52 AM   #280
saman2323
My Ride: BMW 318i e46
Smile Need help
Hi.
I need help with installing an aux-input on my bmw radio.
I have connected to pin 9, 8 and 4 but I can't switch to AUX mode.
I have also tried to connect a 300k Ohm resistor between pin 8 and 9.
What did I do wrong.
My radio:
CD53 E46
P/NO 65. 12-6 915 711
SW/NO 40
01 JULY
KW: 29/01
Please help!
Thanks!
saman2323 is offline   Reply With Quote
bmw aux in, diy aux input, input cable
