Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 09-08-2010, 02:11 PM   #401
pyrocrickett
My Ride: 2004 330i ZHP
Originally Posted by jammykam View Post
[snip] . . . think I tracked it down to it being the girlfriend so I got a new one, lol
From what I hear those can go bad often & without warning!
'04 ///ZHP sedan 6MT
pyrocrickett is offline   Reply With Quote
Old 09-08-2010, 05:53 PM   #402
demens
My Ride: 325ci
I am quite the idiot it turns out.
Playing around with the circuit i noticed that the sound improves with the increase of capacitance. I got as high as 1000uf. but the point at which the difference was noticeable was just 0.1uf...i knew something had to be up with the caps i bought, and yes, it turns out i bought 220pf which is 0.00022uf. Ordered new parts today. Feel pretty stupid.
Btw, is 0.22uf really the ideal? It was working perfectly fine at 22uf. Like i said, even 1000uf works, it just takes about 60 sec to turn on. I'm using a home made charger which belonged to a different phone and it adds a bit of static when connected (more then another charger i tested), so maybe higher cap would be better for me???
demens is offline   Reply With Quote
Old 09-08-2010, 09:45 PM   #403
pyrocrickett
0.22 uF is what's in the OEM cable, but I guess go as high as you'd like
Old 09-19-2010, 08:24 PM   #404
Darth Maul
My Ride: 330CI
I just got a stereo wire from a local store and it has a blue, white, and yellow wire. Which is which and where should I plug in everything?
BMW 330CI
Darth Maul is offline   Reply With Quote
Old 09-19-2010, 08:33 PM   #405
sillieidiot
My Ride: '06 AW 330ci
doesn't matter, you designate which is which.
Old 09-19-2010, 08:37 PM   #406
Darth Maul
My Ride: 330CI
Are you serious, how so? Doesn't it matter what the ground is from the stereo headphones?
BMW 330CI
Old 09-19-2010, 08:38 PM   #407
Darth Maul
My Ride: 330CI
and what the left and right are?
BMW 330CI
Old 09-19-2010, 09:00 PM   #408
Andy2108
My Ride: SpecE46 & E46 M3
wires are wires. connect them to whatever you wish, just dont make blue on one side ground and on the other one of the signal lines.
De gustibus non est disputandum.
Old 09-19-2010, 09:07 PM   #409
sillieidiot
lol to make it easier for you. i'll make them up for you.
blue is left
yellow is right
white is ground
good luck.
Old 09-19-2010, 09:11 PM   #410
Andy2108
blue is left
yellow is right
white is ground
good luck.
lol you did that kinda backwards from the "professional" way to do it... i think...
black (blue) is left
red (yellow) is right
white? (white) is ground..
but it totally depends on who your asking. Electitions and home theater / audio engineers do it differently lol
what matters more is that you keep it consistent ...
Old 09-19-2010, 09:15 PM   #411
Darth Maul
My Ride: 330CI
So this doesn't matter?
I'm not sure if picking whatever I want for my stereo is wise, I don't want to connect the tip to ground and ground to left, etc....if you guys know what I mean...
BMW 330CI
Old 09-19-2010, 09:21 PM   #412
sillieidiot
lol yea iono i just picked it randomly. wasn't really thinking too hard about it.
Old 09-19-2010, 09:21 PM   #413
Andy2108
did you even read the thread?
This pick is from the first post
the random wires inside that arent in a second rubber tube thing are ground... the ones that are individual wires are signal wires.
Old 09-19-2010, 09:23 PM   #414
sillieidiot
wait, so let me get this straight. when you said you picked up stereo wires, you meant that you picked up a stereo aux cable with those colors?
or do you mean, you just bought the wires themselves only?
we're assuming the latter.
Old 09-19-2010, 09:24 PM   #415
Darth Maul
My Ride: 330CI
that picture didn't show up, I noticed there was one picture that wasn't showing up but I didn't think too much about it.
BMW 330CI
Old 09-19-2010, 09:31 PM   #416
Darth Maul
My Ride: 330CI
Actually now I can see that picture, and on my stereo headphones, all 3 wires are wrapped individually, so it's kinda tough to decipher which is ground, left/right. I unraveled the other end I didn't use and saw that blue is the lowest (ground), yellow is middle (right), and white is tip (left).
BMW 330CI
Old 09-19-2010, 09:31 PM   #417
Darth Maul
My Ride: 330CI
Just guessing but I guess that's what I'll go with and see if it works.
BMW 330CI
Old 09-19-2010, 09:35 PM   #418
sillieidiot
if you have a voltmeter, just check for continuity from the plug and the ends of each wire. you can look up the plug diagram for it to tell you which is which. would be the best way i guess
Old 09-19-2010, 09:42 PM   #419
Darth Maul
My Ride: 330CI
BTW, I but an stereo aux cable with a male on both ends.
BMW 330CI
Old 09-19-2010, 09:45 PM   #420
sillieidiot
i see, well then the wires would matter lol do what i said in previous post and you should be good.
bmw aux in, diy aux input, input cable
