Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 06-02-2011, 01:10 PM   #481
Yungjizzle1121
My Ride: 03 325xi
Does anyone know where I can get that black clip piece that plugs into the radio where the pins are. I don't have an old CPU to use and I've tried every store I can think of
Sent from my iPhone using BimmerApp
Yungjizzle1121 is offline   Reply With Quote
Old 06-03-2011, 02:21 AM   #482
xecure
My Ride: 2002 325xi, 5MT Swap
so what is a possible solution for people with 09/02 or earlier radios?
** Too much for a sig - tim330i **
OMG LOOK AN E46!
xecure is offline   Reply With Quote
Old 06-03-2011, 06:57 AM   #483
loffa
My Ride: 2001 330ci
An IDE (PATA) HDD cable that is available at every computer store, will work as well. You just have to cut off the excess pins.
loffa is offline   Reply With Quote
Old 06-03-2011, 04:16 PM   #484
daewon774
My Ride: 2002 330xi
Works great, without cap and resistors!
I've been waiting to do this since I got my 2003 330xi a few weeks ago. Like everyone else I checked the manufacturing date on the HU and it seemed like I would be fine. I then checked my firmware and saw that "SV 14-03 40" came up on the screen. I know everyone says it should firmware 43+, but I went ahead and tried anyways.
My plan was to use the two caps and the resistor. Tried it, and I failed. Maybe it was my soldering skills, maybe I just didn't put it together right... I don't know. I took all that crap off and went without the caps and resistor. EVERYTHING WORKS OUT FINE. I'm running straight into my iPhone 4 and have no background noise.
Kudos to everyone on this thread for giving us this great DIY.
daewon774 is offline   Reply With Quote
Old 06-07-2011, 07:35 PM   #485
F0iL
My Ride: AW 03' 325i
Wow! I just did this after 8 years of owning my car and its by far my favorite diy! For those of you still using fm trasmitters, stop now! Do this ASAP its simple and very very effective! Thanks again for this simple diy.
F0iL is offline   Reply With Quote
Old 06-15-2011, 03:56 AM   #486
peter.210
My Ride: 318i 2001
ok ive read majority of the thread and worked out my business cd is not compatible due it being made in 2001. what are the other options apart from replacing the head unit.
i know this is available:
http://gromaudio.com/store/aux_adapt...nterface_.html
but are there any other alternatives???
thanks
peter.210 is offline   Reply With Quote
Old 07-26-2011, 02:52 PM   #487
yusufm786
My Ride: 318i
I did this mod and it's great - probably the cheapest functional mod out there. Made my cable using an old USB cable (for the shielding). Used the individual pin connectors on the one end from an old computers HDD and power light connections. on the other end used a panel mount 3.5mm stereo socket. Pic attached. Notice 1) my like-new console i thought while it's out, i may as well recondition it, so i sanded it down and sprayed a few coats of Rustoleum camouflage black - looks almost 100% OEM; and 2) the orange glow - i figured there's no point in having an aux socket if you cant find it. so at the opposite end, hidden under the draw is an orange LED the same colour as the OEM lighting, which powers on when the car's light are on. This not only lights up the socket, but all the items in the storage compartment as well, and it looks great. you can't really see the effect in the photo, because it was taken in the daytime. Overall, a very OEM look.
yusufm786 is offline   Reply With Quote
Old 07-26-2011, 10:03 PM   #488
vitalik-seattle
My Ride: 2004 M3
What if I got a gps instead of the cd player in the dash... and when you open the gps monitor i got a cassete player and I do have the mode button.. Mine is 2002 325i
vitalik-seattle is offline   Reply With Quote
Old 07-26-2011, 11:02 PM   #489
saladin
My Ride: 2004 325ci
thanks a lot! got this worked out!
saladin is offline   Reply With Quote
Old 07-29-2011, 05:03 AM   #490
planetibo
My Ride: Z4 E85 3.0i 2003
Hello!
I have a Z4 E85 2003
I make my own cable TO: 1 resistors + 2 capacitors 0.22.
I compared a music on CD, and auxiliary input: Sound through the AUX lack of bass...
I wanted to like this cable: http://www.diymybmw.com/e46/aux-input-cable/
I have test without resitors and without capacitors: No AUX...
I have test with resitors and without capacitors: Aux appears, but, when i plug the iphone, I hear the sound half a second and AUX disappears.
I'm surprised because you does not use capacitors.
The sound is better without capacitors, more bass!
Why doesnt work with my Z4 '03??
Other Things:
I'm using a dock cable to USB + AUX. (By the way I have a ground loop problem, but that's another topic, I have to buy a Ground Loop Isolator ).
I discovered something yesterday I plugged the USB on the cigarette lighter, and to take, I'm the only right and left contact, not the ground of the Aux Cable, and voilą: the sound was much better ! The very powerful bass.
Cut the ground of the AUX cable is another solution?
planetibo is offline   Reply With Quote
Old 08-13-2011, 06:33 PM   #491
Javaldes
My Ride: 2003 330xi
AUX Quesiton
Is there any other connector I could use if i don't have the computer cable you used? If you could provide a part number from radio shack it would be greatly appreciated
Javaldes is offline   Reply With Quote
Old 08-13-2011, 08:43 PM   #492
florida2002m3
My Ride: 330 ZHP
The caps are work as high pass filters when in series. They absorb the lower frienquencies, just like a bass blocker. It also absorbs the electric noise created by the ground loop. The resistor is there to give resistance to the head. It also disipates the energy from the caps.
florida2002m3 is offline   Reply With Quote
Old 08-13-2011, 08:54 PM   #493
DSeyf
My Ride: b6s4
Recently did this, however it was really quiet. You can changed the gain of the AUX by going through the bass and treble controls at the very end. It goes form 1-6. Really increased the volume and made me enjoy this mod much more.
not sure if mentioned but doesn't hurt to do it again.
DSeyf is offline   Reply With Quote
Old 08-16-2011, 02:33 AM   #494
luc
My Ride: '04 325i
wow.. man this mod is so good. about an hour from random extra pc cables to listening to my ipod in my car. thanks so much youre a boss for sure.
one thing.. my car didnt seem to like it when i plugged in my charger too. it just switched the audio over to radio and wouldnt recognize my aux again until i restarted the car.
2004 325i sedan
3 pedals, ZSP, ZPP | bimmerbrakes headers | shark injector | AFE filter / swiss cheese | 17" TRMotorsports C2 | H&R suspension | CF sunroof delete | custom short shifter | clear lights | CDV delete | DIY aux audio in | lots of random $5 mods
gamertag: babyDriver29
luc is offline   Reply With Quote
Old 08-17-2011, 12:34 PM   #495
luc
My Ride: '04 325i
Sent from my DROID2 GLOBAL using Bimmer App
2004 325i sedan
Old 08-18-2011, 08:57 PM   #496
jjewett
My Ride: 2005 Z4 3.0i
Hi all, great thread here, I'm jumping in late but I have a very similar experience to what Planetibo mentions a few posts above. I have a 2005 Z4 with the OEM Aux In cable connected to an 1/4" to iPhone dock connection. I experienced the same lack of bass response noted by many others and tried removing the circuit board from the OEM Aux cable which contains the 2 capacitors and 1 resistor, however the AUX option wouldn't appear on the head unit. I added a 300k resistor between the left/right wires (still no capacitors) and the AUX option appears, but disappears as soon as I connect the iPhone.
Any help or insight would be greatly appreciated.
Many thanks!
jjewett is offline   Reply With Quote
Old 08-18-2011, 09:06 PM   #497
DSeyf
My Ride: b6s4
Why can you not charge and play?
Old 08-19-2011, 09:35 AM   #498
Robbski
My Ride: 2005 ZHP
The connections just carry signal not juice.
Older ipods can connect through the dock to to the aux connection if it is wired with a female connector (like the oem) but it still won't charge. If the newly wired aux connection has a male connection then it has to go into the earphone jack ipod or phone.
Newer ipods and iphones won't work with a dock to aux wire unfortunately. have to go earphone to aux. Shame because the quality is far superior with this method of connection.
Robbski is online now   Reply With Quote
Old 08-19-2011, 09:37 AM   #499
DSeyf
My Ride: b6s4
There's got to be a way to make it work with the newer iPods.
Old 08-19-2011, 11:40 AM   #500
Robbski
My Ride: 2005 ZHP
Hey if you find out let me know. I spent more than a little time fooling with mine. From what I can find out on the intraweb its a software thing on the newer ipods and phones.
bmw aux in, diy aux input, input cable
