Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 01-23-2012, 05:57 AM   #561
stemn
My Ride: E46 320d
Hi!
I have 09/2003 business cd with mode button and software is 510 shown in menu.
But if I put these wires as the DIY says my radio says right after power on "disabled" and AUX input does not work.
Is there any advice anybody??
stemn is offline   Reply With Quote
Old 01-23-2012, 07:28 AM   #562
florida2002m3
My Ride: 330 ZHP
I had to put in a resistor of higher value in order for mine to recognize the input.
florida2002m3 is offline   Reply With Quote
Old 01-23-2012, 08:29 AM   #563
stemn
My Ride: E46 320d
What do you mean by higher value resistor?
I did it by the DIY:
1/4W resistor across right and left channels.
0.22microFarad Cap in series with ground cable.
0.22microFarad Cap in series with left or right channel.
So what should i change to what?
Old 01-23-2012, 08:50 AM   #564
florida2002m3
My Ride: 330 ZHP
I think i tried the 300Kohm resistor and it didnt work, so i then put in a 350Kohm and it recognized the input. I did it about a year ago so i could be off on the numbers. But i do remember i had to go up in resistance.
Old 01-23-2012, 01:20 PM   #565
trj
My Ride: 325Ci
its 1/4 Watt 300~350Kohm resistor across L and R channel.
0.22 microFarad caps in series with L and R channel each.
Leave the ground alone.
Old 01-23-2012, 01:25 PM   #566
florida2002m3
My Ride: 330 ZHP
I would increase to a 400Kohm resistor. I believe this is for two reasons. One to replicate the resistance of "BMW input/and or cable". Second is to absorb the noise from the ground loop, as this circuit acts as a high pass filter.
Old 01-24-2012, 02:16 AM   #567
stemn
My Ride: E46 320d
I have 300Kohm resistor and 0.22 microFarad caps in series with L and R channel each. Also there is nothing in ground. And I got it to work yesterday. The connection was bad. Thanks for great DIY!
Old 01-24-2012, 02:45 AM   #568
trj
My Ride: 325Ci
350 should be ideal to make the radio think that there is load on the aux. +-50 should be fine.
mine is 300, i soldered 3 100Kohms in series. Couldn't find a single 300Kohm in local rdioshack.
Old 01-29-2012, 08:37 PM   #569
Cheechman7
My Ride: 2003 325xi
DIY success. Thanks for the guidance on wire selection!
Presently I have the cable running out of the back of the head unit (temporarily), I plan to run it under the center console and place a headphone jack in the rear seat cigarette lighter space. Anyone else place theirs there?
Cheechman7 is offline   Reply With Quote
Old 01-30-2012, 12:11 AM   #570
E46723
My Ride: 2003 BMW 325i
Ive read this thread like 5 times and i finally had the time this weekend to do it perfect instructions plus great pics !!! Thanks for saving me money!!!
Sent from my E46 using Bimmer App
[/SIGPIC]
E46723 is offline   Reply With Quote
Old 02-01-2012, 03:13 PM   #571
t.bird
My Ride: '04 330i ZHP
This is absolutely driving me crazy. I revisited this today on my car and still no luck after initially trying it 6 months ago. I had a 300k resistor so after reading a few more recent posts in this thread, added a 100k resistor in series...but still no luck. My CD player is from '06, I have tried without caps and resistors, with both, with only caps, with only resistors, I have even soldered the wires directly to the pins on the back of the CD player thinking maybe I had a bad connection there....still aux does not show up on the CD player.
I give up!
I'm guessing my CD player is messed up.
t.bird is offline   Reply With Quote
Old 02-01-2012, 03:22 PM   #572
Many330i
My Ride: e90 M3
I give up!
You bought the radio used? Prolly it was refurbished and they buggered up the aux links.
Sell the radio and get another one...if aux is really important to you! Otherwise, go dice or usa-spec and route the aux wire from the trunk to wherever you want it. Th OEM aux though is much cleaner and better sound quality. Good luck.
Many330i is offline   Reply With Quote
Old 02-01-2012, 04:02 PM   #573
t.bird
I guess the previous owner changed it out at some point...
Old 02-03-2012, 03:05 PM   #574
ZkansasZ
My Ride: a horse
I just want to say THANK YOU
Using this DIY, I've completed my AUX cable wiring and all.
Costed me more than 10 bucks but it's worth a lot to me.
So,
THANKS!
02AccordV6(sold) 03350zMT(sold) 04E46///M3MT(sold) 06RSXauto 07G35auto
ZkansasZ is offline   Reply With Quote
Old 02-08-2012, 11:11 AM   #575
Crispy3M
My Ride: 325i
Originally Posted by pyrocrickett View Post
0.22 uF is definitely the correct value for the caps, w/a 300k Ohm resistor. Make sure you have the resistor on the HU-side of the caps, too.
Has anyone else noticed that the BMW schematic shows .22F capacitors and NOT .22uF?
I stumbled onto this thread yesterday and read most of it but couldn't tell where the .22 Farad Cap got turned into a .22 Micro Farad Cap. I'm going to whip up a cable today but think I'll use the 220mF (.22F) caps as per the BMW schematic unless someone here knows different.
***Disregard*** 220mF Cap is pretty beefy... I used the .22uF and the Aux Input works great!
Cheers,
Chris
Crispy3M is offline   Reply With Quote
Old 02-08-2012, 08:59 PM   #576
cobra989
My Ride: 2003 BMW 325ci
Stupid question I know im sorry... I looked at my door sill and it says that my build date was 09/02... I know from reading the posts that my factory head unit wont work with the aux in mod (bought mine from bavauto), but I am little confused because according to carfax my car wasnt registered until 09/03 in florida where it was first bought at. I looked at the software and it is the SW 43 that it needs to be. What is really odd is that when I plugged in my cable and went through the mode options aux flashed for literally a second then went away... Did I do something wrong? I am lost... My paperwork says that some cars need to have the aux option activated at the stealership so should I do that? Have I lost my mind? Thanks in advance for any help you all can provide!
cobra989 is offline   Reply With Quote
Old 02-09-2012, 02:45 PM   #577
eu teo
My Ride: 330xi
Im having issues, i have a 2002 e46 face lift sedan with the mode button stereo, i have done this aux cable and put the resistor and capacitor just like the diagrams above and flowed this dyi http://sftf.wordpress.com/2010/02/21/e46diyaux/
i installed the cable but it still dosent work, do i have to enable the aux feature on my unit in order to work? or it just dont work cuz its a 2002?
some one please help
thanks
eu teo is offline   Reply With Quote
Old 02-09-2012, 07:09 PM   #578
Crispy3M
My Ride: 325i
From another thread...
From all the information available, radios built after 09/03 will work with this setup. Some 9/02 radios will have the mode button but AUX input won’t work.
Here’s an easy way to check:
1. Turn Radio Off.
2. Turn Radio On.
3. Press and hold the “m” button for about 10 seconds.
4. Press to navigate, you will need to go to the 2nd screen to look for the SW Verison which is in a SV xx-xx xx format.
5. To be Sirius/AUX or XM compatible, the radio must be SW 43 or higher.
6. Turn radio off to exit.
The MODE button is not a good enough indicator to check if a radio is AUX or Sirius compatible. It needs to be manufactured 09/02 or later.
Hope this is of some help.
Chris
Old 02-09-2012, 10:48 PM   #579
eu teo
My Ride: 330xi
so if its 09/02 or earlier it will not work? not even with the oem cable?
Old 02-13-2012, 01:17 AM   #580
ActionGoat
My Ride: 330ci
Just tried it myself with a modified IDE cable and it works perfectly. One of my favorite DIYs so far. Thanks.
01 330i TiAg
01 330i Orient Blau
02 330ci Sapphire Black Metallic
ActionGoat is offline   Reply With Quote
bmw aux in, diy aux input, input cable
