Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 12-15-2006, 05:33 PM   #41
white46
My Ride: e46 323ci
Originally Posted by mircle View Post
where can I find the plug for the rear of the head unit?
it is rear of HU, right beside where CD changer connects to.
Originally Posted by silvscorp View Post
I was trying to wire it up using a headphone plug and noticed there are only 2 wires coming out from a regular stereo cable. (L + R signal) How do I get the ground wire to connect? What kind of cable did you use? (you have 3 wires coming out from it)
you must have used mono headphones. You can either use stereo headphone or get cable like mine from any local radioshack, etc for less than $5.
i just happended to find it at home.
For stereo headphone, if you cut the wire, you will see this.
sorry for the bad picture.
Each wire inside is coated with special protectant to prevent interfering each other. You can burn the wires little with lighter to remove the coat. From there it is all the same. Just make sure you connect grounding wire togeter from each side and put it into pin 4.
Originally Posted by lethan7 View Post
so now for us that have a 2001 that does not have with the mode botton .... what can we do to get aux in put ??
sell old HU through ebay. you can get easily over $150.
and buy new one.
i bought mine Feb/06 built date HU from fellow fanatic for $230.
white46 is offline   Reply With Quote
Old 12-15-2006, 10:26 PM   #42
silvscorp
My Ride: 03 CB M3 Coupe
Just got the cable installed and it works great. I do have one "problem", the aux input's sound level is a lot lower than other modes. Is this normal or there is something wrong with the cable?
silvscorp is offline   Reply With Quote
Old 12-15-2006, 10:34 PM   #43
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
While its not documented, press CDs 1-6 to change the gain voltage.
tom @ eas is offline   Reply With Quote
Old 12-15-2006, 11:06 PM   #44
white46
My Ride: e46 323ci
have to try push the music note button? button between "-" and "+".
While aux is connected, press music note button. it will show input level which will control input volume level.
Old 12-15-2006, 11:11 PM   #45
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Ah, you're right - I stand corrected (trying to post from memory).
Old 12-15-2006, 11:16 PM   #46
white46
My Ride: e46 323ci
No worries.
BTW, Thank you Tom.
You have given so many answers that I couldn't have. ie)SW version.
Great support from sponsor although it is not their product.
ps: i''m not being sarcastic. you are truly being helpful.
Old 12-15-2006, 11:26 PM   #47
MPossible
MPossible's Avatar
My Ride: track star
Doesn't the OEM kit come with a panel that you would plug into or is that an extra upgrade?
MPossible is offline   Reply With Quote
Old 12-15-2006, 11:49 PM   #48
white46
My Ride: e46 323ci
yes. BMW offers OEM aux input kit.
i just found myself that not worth spending $50 for the simple wire though.
Old 12-15-2006, 11:57 PM   #49
jinthekoreankid
My Ride: 2013
someone on the Z4um said I needed some resistors for my z4...
i don't understand why you guys don't need em and I do?
jinthekoreankid is offline   Reply With Quote
Old 12-16-2006, 12:02 AM   #50
white46
My Ride: e46 323ci
i'm not sure. i never played with z4.
Old 12-16-2006, 12:24 AM   #51
silvscorp
Thanks! well it only goes up to level 5 and it is still a little lower compare to the radio and CD output level. I guess this has to do with the individual mp3 player since some might not have a greater output due to the earphone protection may be?
Old 12-16-2006, 12:32 PM   #52
Gir
My Ride: .
I did something similar a couple years ago, couple thoughts:
In the OEM aux cable there were two resistors and a cap that bridged them. When I did it I was off by a little bit of capacitance, didn't work out too well so I went ahead and bought the OEM cable.
I searched for 30 minutes trying to find the diagram but I can't find it anymore.
Anyway, to take the DIY one step farther, you can use this wiring to hookup your Ipod (and charge it too) for far less than ICElink or BMW by canabalizing a Belkin Ipod charger.
The detailed site is gone but from these two links it should seem pretty easy:
http://www.bimmerfest.com/forums/showthread.php?t=56089
http://forum.e46fanatics.com/archive.../t-151857.html
Happy modding.
Gir is offline   Reply With Quote
Old 12-27-2006, 09:30 AM   #53
swervin22
My Ride: 325i finally modded
Send a message via AIM to swervin22
Does anyone know what the name of that computer wire is?
swervin22 is offline   Reply With Quote
Old 12-27-2006, 05:02 PM   #54
thadon1883
My Ride: M3
yea that seems to be the only missing link...what's the name of that computer wire and end piece?
thadon1883 is offline   Reply With Quote
Old 12-27-2006, 09:07 PM   #55
white46
My Ride: e46 323ci
i don't think there is name to it.
This is a cable that I found from my old computer I was about to throw away. This pin connects to motherboard for power switch, reset switch, hdd led, power led, etc.
Old 12-27-2006, 09:49 PM   #56
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
Not bad.
My Aux input only cost me $30, its also a little more then just a cable. I think it was worth the $30 it gives you a nice plate that says aux input on it and looks very professional not after market at all. At $50 probably not worth it but at $30 its not bad.
Euro Delivery Thread
///M3-6MT:dance:
Staszek is offline   Reply With Quote
Old 12-27-2006, 10:18 PM   #57
jinthekoreankid
My Ride: 2013
yea i ended up buying a e46 aux kit and plug and play for my z4.
$32+tax with bmwcca discount
worth it
2003 BMW Z4 2.5i Sport
Old 12-28-2006, 01:15 AM   #58
Limited_Slip
Banned
My Ride: e30
Originally Posted by Staszek View Post
Not bad.
do you have the p/n??
Limited_Slip is offline   Reply With Quote
Old 12-28-2006, 02:31 AM   #59
Staszek
Are we there yet??
Staszek's Avatar
82110149389
E46
Auxiliary Audio Input
Installation of this kit provides a direct audio input into the radio for MP3 - CD player etc
For model year 2003 and newer. E46 w/o nav
w
i List: $ 39.95 *
Sale: $ 31.96 *
At Circlebmw
///M3-6MT:dance:
Old 12-28-2006, 03:58 PM   #60
swervin22
Anyone have a problem of a high pitched squeeling sound coming out of speakers when connecting something to the auxillary. Do you think it's a bad aux wire or is the input screwed?
bmw aux in, diy aux input, input cable
