Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 02-13-2012, 02:09 PM   #581
eu teo
My Ride: 330xi
Originally Posted by ActionGoat View Post
Just tried it myself with a modified IDE cable and it works perfectly. One of my favorite DIYs so far. Thanks.
What year is your headunit made?
eu teo is offline   Reply With Quote
Old 02-13-2012, 07:19 PM   #582
Crispy3M
My Ride: 325i
Aux Input Jack
Here is where I installed my Jack - Now you see it... Now you don't!
ID:	436937   Click image for larger version
Crispy3M is offline   Reply With Quote
Old 02-14-2012, 07:11 AM   #583
TSorinD
My Ride: BMW
SW: 11222387
aux ?
TSorinD is offline   Reply With Quote
Old 02-14-2012, 07:12 AM   #584
TSorinD
My Ride: BMW
Sw: 1122387
Old 02-14-2012, 07:13 AM   #585
TSorinD
My Ride: BMW
aux input work my sw: 1122387 ?
Old 02-15-2012, 09:59 PM   #586
socal_snowsports
My Ride: '04 325i
triple post!
i reckon the last two digits are your software version.. it has to be 43 or above in most instances in order for your HU to support an auxiliary input.
I just installed mine with the oem aux cable even though my 2004 325i's HU is SW version 40.
socal_snowsports is offline   Reply With Quote
Old 02-16-2012, 01:08 PM   #587
Cheechman7
My Ride: 2003 325xi
Help!
My iPod n iPhone work fine. I tested Sirius portable, cig powered, antenna cable coiled on passenger seat and up through sunroof for test purposes, 12inch headphone male male wire. Worked great.
Ripped apart backseat and trunk liner, ran antenna line concealed from trunk to driver area.
Now my radio will not recognize Sirius as an aux source. iPhone still works fine as aux. I even start with aux and try to switch as fast as I can, but there's no tricking the radio - it does not recognize Sirius as an equal!!!
Thoughts? I hate to rip the car apart to pull the antenna. Nor does that make sense as the reason to me.
Ps. I tried a different cable jic. No luck with that either.
Cheechman7 is offline   Reply With Quote
Old 02-17-2012, 11:06 PM   #588
Cheechman7
My Ride: 2003 325xi
UPDATE: interestingly tonight I was listening to iPhone with aux cable, when the battery started to get low. I plugged in my cigarette lighter iPhone charger and the radio no longer recognized the aux input and defaulted to CD! I tried to select AUX- no go. Unplugged the iPhone from the charger, hit mode, went back to AUX no problem.
Why/how do the aux input and cigarette lighter have anything to do with each other? Can't just be dumb luck, right?
Is it possible the aux cable is touching the cig lighter wires and that is the effect?
Old 02-17-2012, 11:45 PM   #589
Crispy3M
My Ride: 325i
Take a look at Post #547.
Cheers,
Chris
Old 02-18-2012, 05:08 PM   #590
Cheechman7
My Ride: 2003 325xi
Cheers,
Chris
Thanks man, resistor it is. Such a long thread I had read 14-16 pages and called quits. Strange that it had worked successfully at one point at all...
Old 02-18-2012, 10:46 PM   #591
Crispy3M
My Ride: 325i
Don't forget the capacitors!!!
Old 02-20-2012, 03:40 AM   #592
konvctd
My Ride: 2005 E46 M3
does anyone know if it is different for the MK4 head units?? (sat nav)
konvctd is offline   Reply With Quote
Old 02-20-2012, 12:41 PM   #593
trj
My Ride: 325Ci
My version:
My long awaited shots for my aux in.
My Setup:
-regular aux in with caps and resistors with the port in the glovebox.
-cigarette lighter to USB adapter(or you can use BMW flashlight USB kit) tapped in the fuse box for switched power and placed in the glovebox.
-iPhone dock cable with aux out and USB connections.
Advantages:
-Charge and use the aux in with the iPhone using a single dock cable.
-Sound quality is much better since the output is line level from the dock connector.
-Only One cable, so less clutter.
-Can you different device in aux port and charge a different device in the USB port if need be.
-Can just buy a cable to do the same for any other device just like I did with the iPhone to use a single cable to charge and aux out.
-Cable sits inside the glovebox when not in use.
-Looks very OEM.
-Spares your cigarette lighter port and the ashtray.
Disadvantage:
-Cant control the volume with the iPhone (but I do it from my steering anyway).
-Kind of time consuming because you have to take out the glovebox and make holes for the aux in port and wires for USB adapter.
Bottom line:
I am very happy, because I use my iPhone as GPS with tom tom app and it kills the battery very fast. So its nice to use one cable to charge and work as aux out. OT: also the tom tom app allows you to play your iPod music while the GPS is not talking and fades out the song when giving verbal directions.
PICs:
Old 03-04-2012, 04:50 PM   #594
sna77
sna77's Avatar
My Ride: BMW
looks nice
sna77 is offline   Reply With Quote
Old 03-05-2012, 01:12 AM   #595
MrEmitter
My Ride: 2002 330ci
hey guys. I've been wanting to add an aux input on my car but I'm having trouble finding the right stuff that would work on my car. I drive an 02/2002 330ci with no cd changer in the back. I hope you guys can help me out. I'm new to this forum. I've only been a member for about a week. Thanks
Update: I talked to a DICE rep asking the same question, and he recommended me this product http://www.amazon.com/GROM-Audio-BMW...1012256&sr=8-2 which isn't theirs. I was wondering if anyone here have used this in their e46.
Cheers!
MrEmitter is offline   Reply With Quote
Old 03-08-2012, 06:25 AM   #596
taurus_tem
My Ride: Bmw 318 M Sport Conv
Thank you for thisss!! right! time to gid out the old tech and find me some wires!
taurus_tem is offline   Reply With Quote
Old 03-10-2012, 12:43 PM   #597
royalrebel
My Ride: 330i
would this work in an 05 HU or only in an 03?
royalrebel is offline   Reply With Quote
Old 03-10-2012, 01:11 PM   #598
MrEmitter
My Ride: 2002 330ci
03 and later. but 02 and older will not work.
Old 03-18-2012, 05:07 PM   #599
luc
My Ride: '04 325i
I have an addition to this thread that might be useful for anyone whos done the mod. I ussually put my ipod just above my shifter resting on the ashtray thing.. but everytime i pushed a button on my ipod i opened the ashtray. So i opened everything up and put some strategically placed zipties that keep it from opening.. i made a video afterwards but ill take a pic of the actual mod when i get off work
2004 325i sedan
3 pedals, ZSP, ZPP | bimmerbrakes headers | shark injector | AFE filter / swiss cheese | 17" TRMotorsports C2 | H&R suspension | CF sunroof delete | custom short shifter | clear lights | CDV delete | DIY aux audio in | lots of random $5 mods
gamertag: babyDriver29
luc is offline   Reply With Quote
Old 03-22-2012, 04:24 AM   #600
DanielJames
My Ride: Estoril 320d Sport
Going to have another go at this soon.
The last time I attempted, I made 2 cables and neither would enable the "Aux" on my 2003 E46. The SW etc was good, it just wouldn't enable the Aux mode.
Any tips?
flickr
IG: @DannyDC2
DanielJames is offline   Reply With Quote
bmw aux in, diy aux input, input cable
