Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 05-17-2012, 01:47 AM   #621
Ballistic325
My Ride: slow and steady
If the CD changer works without a problem and the problem is that there is no sound, I would suggest that there is a break or a loose connection from the HU to the speakers. Most likely that a connector which carries sound from the changer to the speakers is loose and therefore while the CD changer works, the sound it not getting through to the speakers.
Check the rear of the HU and ensure that everything is connected. Same with connections back in to the CD changer. Buying a Blizsafe or similar product that connects in place of the CD changer will not solve the problem.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 05-17-2012, 01:38 PM   #622
JuvE46
My Ride: 02 M3 Manual
I don't think I did a good job explaining. The problem isn't that there is no sound. The sound comes out when playing the radio, its when trying to use the CD changer that the sound won't come out. It has been like that since I bought the car a month ago..The display on the HU even shows which CD and track is selected, but no sound. The reason this is an issue for me is that I'm trying to add an aux input using a blitzsafe through the CD changer input, and before buying the blitzsafe and attaching it to the CD changer input (I don't even want to use a CD changer and am planning to take it out) I was trying to make sure that the line to the HU works so I'd be able to add a aux input. VERY ANNOYING problem considering my GF's ford focus has a factory aux input
JuvE46 is offline   Reply With Quote
Old 05-17-2012, 09:30 PM   #623
Ballistic325
Yep, I get what you're saying. It is possible for the CD changer to be connected and show the correct display on the HU without actually pushing out any sound.
That's why I recommended that you check your cables. I had previously used a hack posted on the forum where I could bypass my CD changer and DIY an aux input. The CD changer would still swap discs etc and the display would show the disc info.... the sound would come from my MP3 player. So, check your cables and ensure that everything is connected and matches up.
Fitting a Blitzsafe without further diagnosis will not fix your problem.
I can help with
* RTABs
Old 05-18-2012, 04:55 PM   #624
BMWboi
My Ride: 04 330ci 6spd
Hey guys,
what is that computer cable called.
This is the one I have, it doesn't look like the right one is it? It's 3 wire, 4 pin but it's flat.
BMWboi is offline   Reply With Quote
Old 05-18-2012, 05:21 PM   #625
BMWboi
Is this what I need.. the ATX 4pin
http://pcsupport.about.com/od/inside...in-12v-psu.htm
Old 05-21-2012, 11:28 AM   #626
trj
My Ride: 325Ci
Originally Posted by BMWboi View Post
Hey guys,
You need 2 of those. File it to fit. One on the top row one fir the bottom.
Old 05-21-2012, 08:28 PM   #627
JuvE46
Hi guys need some help. I'm trying to take out the navigation HU from my dash (2002 M3). I've already removed the AC/heater ventilation and a couple of visible screws on the head unit but am kind of stuck. I couldnt find any decent link that explains the process. Is there a special tool thats needed just to take the Navi HU out? Anyone have a link? Thanks in advance.
Old 05-23-2012, 12:42 AM   #628
M3JetBlack
My Ride: 2002 M3
Alright, pretty much have my AUX cable complete but i have a quick question...
I used an old pair of headphones that were about 1 year old. This is what it looks like when cut... Click image for larger version
Now, i know i have to connect the two ground wires together, but i am sort of worried/confused about the input wires. Both the left and right wires are separated by being in separate rubber tubing, but the ground wires are also touching the wires. Will this short anything out? Better safe than sorry
2002 JetBlack ///M3
CCW Wheels / GC coilovers / Alcon / Eisenmann / SuperSprint / Vorsteiner / HPF Stage 2
Instagram: @somuchcalitis
M3JetBlack is offline   Reply With Quote
Old 05-24-2012, 08:07 PM   #629
a2puri
My Ride: BMW 325i
hey guys, ive made the DIY cable with the 2 caps and the resistor installed, but Im having a ground loop problem. I know that this MAY be solved by a ground loop isolator, but the one I picked up form The Source (equivalent to Radio Shack) didnt work.
At this point, I dont mind paying $50 bucks for the retrofit cable, as long as I know that I wont have any issues with ground loop on the OEM cable. Can someone verify that if I have something plugged into the car cigarette lighter charger, and also the aux, that there will not be engine whine or ground loop noise with the OEM cabl?
a2puri is offline   Reply With Quote
Old 05-26-2012, 03:55 PM   #630
ltx325i
My Ride: 2004 325i
I used an old pair of headphones that were about 1 year old. This is what it looks like when cut... Attachment 452793
They will be fine. It looks like one wire is Red and the other is Blue. Correct?
This is common on most headphone wires. Even though it looks like the wire is bare, it is coated. You will see the coating burn and bubble when you go to solder them. If you are not soldering the wires, when you go to put connectors they may not work as the wire will be insulated with the coating still. Make sense?
"My formula for success is rise early, work late, and strike oil." - J.Paul Getty (1892-1976)
ltx325i is offline   Reply With Quote
Old 05-26-2012, 09:26 PM   #631
M3JetBlack
My Ride: 2002 M3
I will try this out. I wasn't planning on soldering it, but after looking closely, i think you are right! When i get home, i will try this out. Thanks!
2002 JetBlack ///M3
Old 05-30-2012, 05:28 PM   #632
andysbeema
My Ride: 325ci
hi
i juat bought a 3.5mm jack , which has aux input leads 3 off them , red, white &another 1. to put in pins 8,9 & 4. i tried today , but nothing a tool.
1 is earth, then the others are internal speakers l & r.
help
andysbeema is offline   Reply With Quote
Old 06-01-2012, 11:56 AM   #633
a2puri
My Ride: BMW 325i
Bought the BMW OEM cable, still has the EXACT same issue. I will try to remove the cigaretter lighter and ground it at the same location as the radio today and see if that changes things. But fark, i wasted $50 bucks on that cable and it was just as good as my DIY.
Old 06-10-2012, 07:51 PM   #634
yenghead
My Ride: 325i Msport
Your Da Man!!!!!
This is not how to install aux input cable rather how to make it.
Seriously, I don't want to spend about $50 for a stinking cable.
I'm in Canada and usually BMW parts are more expensive than US.
Thats What I Call A Post!! Just 1 question do you or any1 else know if the connectors are the same on the back of a standard BMW tape player. Any replies would be appreciated..
yenghead is offline   Reply With Quote
Old 06-10-2012, 09:11 PM   #635
Ballistic325
I don't believe that you can do this with a tape player.
Sent from my V9 using Bimmer App
I can help with
* RTABs
Old 06-10-2012, 09:12 PM   #636
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
Very curious, I have a tape deck as well.
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 06-11-2012, 03:08 PM   #637
yenghead
I just see it online about 5mins ago and there is some1 claiming that they have done it, when I find the link I'll post it...
Old 06-11-2012, 03:24 PM   #638
yenghead
Here's the link below;
http://www.e46zone.com/forum/topic/3...-in-lead-l199/
People let me know what you think and if it works!!!
Old 06-11-2012, 08:01 PM   #639
pilotpk
My Ride: 2000 BMW 323i
I read this ^ earlier today and literally just got done and it sounds amazing!! I have a 2000 with a tape deck, followed the directions on the link in the previous post (#638) It cost me zilch, nadda as I had all the stuff already at home and total time with testing and running the wire through my dash took maybe an hour! Very happy with the sound quality as well! I was using a cassette auxiliary adapter and the first thing I noticed with the mod... noticeably higher treble and an amazing increase in bass, hands down sounds better than the CD player (in trunk) and even the radio.
I suggest if you have the older stereo with a tape deck to do this mod if you want good beats in your car!
pilotpk is offline   Reply With Quote
Old 06-12-2012, 02:47 PM   #640
yenghead
Good 2 hear it works!! Do you still have the cd changer plugged in?? And I wonder if we can get power from anywhere,(hardwired) so we could charge up our iPods and etc
bmw aux in, diy aux input, input cable
