Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 03-27-2013, 01:23 PM   #741
sjacoby112
My Ride: 2002 325ci
so i just tried installing me and nothing is happening. i have the business player with mode button, have the open slot in the back of the head unit. plugged it in per the diagram, 2 wires on top one on bottom. the plug can only go in one way. no aux comes up... am i missing something???
EDIT: nvm just found out i have a 40 SV code not 43, wish i knew that was necessary to find out before i ordered the cable... oh well.
sjacoby112 is offline   Reply With Quote
Old 06-08-2013, 06:27 PM   #742
MrSlacker
My Ride: E46 330xi, E30 318iS
Would like to bump this thread with a huge THANK YOU! Did this mod and it works awesome.
I had an 8 pin connector for computer's front audio ports so I cut it in half and was left with a nice 4 pin connector. I removed 1 pin that was not needed and soldered the rest. This allowed me to easily plug it into the back of HU. THANKS!!!!
MrSlacker is offline   Reply With Quote
Old 06-08-2013, 06:27 PM   #743
MrSlacker
Old 08-04-2013, 05:41 PM   #744
Calebsayshi
My Ride: Dinan 3 (330i)
I had ordered the cable on ebay for $10 but 4 months later and it still isn't here. So I went ahead and put together this cable, works great! thanks for putting up all of the information for it!
Calebsayshi is offline   Reply With Quote
Old 08-15-2013, 01:32 PM   #745
evo7
My Ride: 330i
Is there a fix for not being able to charge your phone while using AUX? I have this problem with my android phone and it's very annoying.
evo7 is offline   Reply With Quote
Old 08-22-2013, 12:57 PM   #746
Zpzp96
My Ride: BMW E46 330i
Let's DIY aux input cable.
Hello!
I just bought 330i 2004 two weeks ago, and I'm trying to make the aux cable for fun if I fail, I will just buy one
Anyways, I followed step 1 to 3 fairly well, but I can't do the step 4. Whenever I try to put those wires together, they fall off.
Can you explain how you put those wires together and hold them?
Zpzp96 is offline   Reply With Quote
Old 09-25-2013, 12:09 PM   #747
MattVa
My Ride: 325ci 330ci
Works great, sound is very clean and clear, better than the MP3 cd53 HU I think
Now i can listen to most any media, without burning to disk.
Just make sure you hit play.
I use a ribbon cable and cut it down, just soldered on the wires to a 3.5 min jack and worked perfect. Took 30 min. I put a little plug in my ashtray near the light, looks like stock.
02 BMW 325Ci 5spd x2
01 Bmw 330Ci 5spd
99 Camaro Z28 1LE
95 Mustang Cobra Dart 363 18psi Vortech
99 Corvette FRC
01 Superformance Cobra
Ultima Can-Am 355 G50/50 Yellow
Ultima Can-Am 350 G50/50 Orange
MattVa is offline   Reply With Quote
Old 09-26-2013, 10:25 AM   #748
aberrant
My Ride: 2003 330i ZHP
Question about Bass and Capacitors
I just completed my cable last night and everything works as expected except when I plug in the charger for my phone at the same time. I've read about the resistors and capacitors and I plan on purchasing those to integrate them into the cable today. My question is regarding the issues with the bass frequency. A lot of people are complaining about the bass after adding the capacitors in series. Has anyone looked into a way to resolve this? Would adding a larger capacitor (maybe 1uF instead of .22uF) help restore some of the lost bass from the capacitors acting as filters? Is there any other way to by-pass the capacitors and still allow me to charge my phone and use the AUX input at the same time?
aberrant is offline   Reply With Quote
Old 09-26-2013, 05:44 PM   #749
CK325
My Ride: 323Ci, 325xi
So after removing some PO aftermarket radio aux input that wasn't working, I hooked it all up but the it goes into aux mode for a second then goes back to cd. I made sure I have the right software version and everything. The red and white wires are audio cables, right? While the one without a separate cable around it is the ground...but it won't work right...weird :/
CK325 is offline   Reply With Quote
Old 09-26-2013, 08:47 PM   #750
CK325
nevermind, it turns out the left and right input actually matter
Old 12-06-2013, 08:20 PM   #751
DaglazBMW
My Ride: 2003 330i
Just did this mod! I love it, took me about 15 min and sounds great. Thanks for the info! If anyone knows a quick fix for the charging issue let me know thanks!!
DaglazBMW is offline   Reply With Quote
Old 12-07-2013, 03:53 PM   #752
CK325
you just need to add a resistor to the cable as far as I'm concerned.
Old 12-08-2013, 02:40 AM   #753
2005blackm3
My Ride: s2000
is this DIY work on the navigation unit too?
2005blackm3 is offline   Reply With Quote
Old 01-13-2014, 06:21 PM   #754
Cheechman7
My Ride: 2003 325xi
Originally Posted by Ballistic325 View Post
For anyone who has trouble finding info about the resistor / condensors mentioned in this thread and to alleviate the problem of charging whilst playing audio from your device, have a read of this thread by GTRaptor. He has also included instructions in a PDF:
http://forum.e46fanatics.com/showthread.php?t=427248
2years later and it's time to get a charge. Thanks for the linked summary!
Cheechman7 is offline   Reply With Quote
Old 01-14-2014, 01:16 AM   #755
andrewlu
My Ride: E46 325i
If some body need help, please contact me
Hi guys,
If you need some help about the AUX cable, you can contact me or send me e-mail, I will try to reply you ASAP, my e-mail address:
Andrew_ziyu@hotmail.com
andrewlu is offline   Reply With Quote
Old 02-04-2014, 09:27 PM   #756
smyoung52
My Ride: 2004 325i
Just did this and it works awesome! I did't have any computer parts laying around, so instead I figured while I was at this I'd switch my automatic shift boot and plate, for the better looking manual boot design. And it deletes the shift position indicator light next to the gear shift. So I cut the two connectors off from the indicator light and connected the aux cable to both of the indicator connectors and they fit in the prongs perfectly together! sounds confusing but once you look at the indicator connectors you'll see what I mean. Hope this helps anyone with the same problem I had!
smyoung52 is offline   Reply With Quote
Old 02-09-2014, 03:45 AM   #757
ade555
My Ride: e46 330i touring
I'm trying to get this to work on 05 plate UK car and just don't work I tried with resistors ect. and with out, nothing, what am I doing wrong?
SV 09-05 630
Can you help?
ade555 is offline   Reply With Quote
Old 02-09-2014, 03:46 AM   #758
ade555
SV 09-05 630
Can you help?
Old 02-09-2014, 05:48 AM   #759
KingBee
My Ride: IR '03 M3
Just did this to my 2nd bmw...super easy mod and the sound is great as well.
AA exhaust, PSS10, TMS sways, 5mm rear spacers, more to come!
KingBee is offline   Reply With Quote
Old 02-09-2014, 12:01 PM   #760
TheMagicalHindu
My Ride: '99 323ci +'00 328i
Oops
I am not a smart man.
Last edited by TheMagicalHindu; 02-09-2014 at 12:02 PM. Reason: I need to read better.
TheMagicalHindu is offline   Reply With Quote
bmw aux in, diy aux input, input cable
