Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 12-28-2006, 04:04 PM   #61
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by swervin22 View Post
Anyone have a problem of a high pitched squeeling sound coming out of speakers when connecting something to the auxillary. Do you think it's a bad aux wire or is the input screwed?
Could be any of the two, or both.
tom @ eas is offline   Reply With Quote
Old 01-04-2007, 02:15 PM   #62
jinthekoreankid
My Ride: 2013
on my Z4 the sound is VERY quiet. and there is no input level to adjust on the "music note" button...
what do I do i wanna listen to some music
2003 BMW Z4 2.5i Sport
jinthekoreankid is offline   Reply With Quote
Old 01-04-2007, 08:58 PM   #63
Striker169
My Ride: 2003 BMW 330i
Send a message via AIM to Striker169
Can I do this with nav? Or what would it require?
Striker169 is offline   Reply With Quote
Old 01-06-2007, 12:14 PM   #64
michelito
My Ride: 2003 325ci SP
Gotta look into this more closely - I just checked, and BMW in Canada want over $100 for the aux input cable... they're completely nuts!!!! And I don't think Pacific or Circle ship to Montreal... arghhhh
Thanks whote46 for the write-up!!!
Edit: has anyone tried to do something similar, but with the CD changer connector in the trunk? I just verified that I have it in there, and it is easier to access than removing parts of the dash to get to the HU...
Also, I Checked my HU - I have "SV 35-02 50".
Which is SW? the 35 or 50??
Thanks!
Also,
michelito is offline   Reply With Quote
Old 01-06-2007, 02:30 PM   #65
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
NAV-equipped vehicles (2003+) have a 3-pin receptacle for the AUX connector to plug into behind the NAV screen.
Old 01-06-2007, 02:35 PM   #66
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
You can go directly into the radio tuner in the trunk on NAV-equipped vehicles. You will have to insert the wires into the correct pin locations
Thanks!
Also,
50 is your SW version.
Old 01-06-2007, 02:54 PM   #67
Striker169
Is it on the acctual nav screen or on my nav harness? I dont see the same pins as on the normal radio.
Old 01-06-2007, 02:58 PM   #68
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
It's behind the NAV screen. You can use a e39-specific (non NAV) AUX kit and extract the pins if you would like to go directly into the tuner in the trunk.
Old 01-06-2007, 03:06 PM   #69
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
We have an interface that will convert the CD Changer input to an AUX port, this is plugged into the trunk.
We haven't placed the devices on the site yet, but I do have them in stock. Feel free to contact me interested.
Just to follow up - the AUX device is now on the site:
eas Auxiliary Audio Input
http://www.europeanautosource.com/pr...roducts_id=630
Old 01-09-2007, 03:35 AM   #70
Limited_Slip
Banned
My Ride: e30
Originally Posted by Staszek View Post
82110149389
E46
Installation of this kit provides a direct audio input into the radio for MP3 - CD player etc
For model year 2003 and newer. E46 w/o nav
w
i List: $ 39.95 *
Sale: $ 31.96 *
At Circlebmw
I bought mine from CircleBMW. Works Great. David Morrow is the man at CircleBMW
Limited_Slip is offline   Reply With Quote
Old 02-19-2007, 12:45 PM   #71
drkangldc
My Ride: 2003 BMW 325Ci
I made an aux input using this thread's directions. Mine is a little different, DSC panel has the aux input and I use a male to male cable to connect ipod to aux plug. I bought the plug from radio shack and use the cables from computer (audio cables, power switch cable). if you guys have any questions feel free to ask me. i would probably be more responsive via e-mail (docorona@gmail.com)
drkangldc is offline   Reply With Quote
Old 02-19-2007, 08:16 PM   #72
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
drkangl^^^
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 02-20-2007, 10:05 AM   #73
chrismiros
My Ride: E45 316TI SE Compact
with this little mod will the cd changer still work?
chrismiros is offline   Reply With Quote
Old 02-20-2007, 10:06 AM   #74
chrismiros
Oh and i'm hedging as to whether i have an Aux in on my headunit, i have the Mode button, but its a tape deck, is this less likely to support AUX in?
Old 02-20-2007, 10:27 AM   #75
chrismiros
I just tried to check the SW version on my cassette unit and it says SV 10 02 500 - is that any good? i notice everyone is talking about CD headunits, so i'm gonna figure that this is nt applicable or doiable on the cassette head unit?
Old 02-20-2007, 11:44 AM   #76
vids_blk323Ci
DFW
Just check to see if you have the pins for the "SoundSystem" which are below the large pins (15, 13, 16). If so, you should see pin 4, 8, 9 which are ground, Ext In R+, Ext In L+ respectively. You have to pull your cassette unit out and look at the large black plug. If you do post a picture of what you saw for benefit of others.
Note dont confuse the above with the pins for the CD-changer which are under the large pins - 11, 14, 12. See post #10 for the diagram.
Old 02-20-2007, 02:48 PM   #77
chrismiros
ok, that will be a weekend job then, i'll try and see if i can this weekend
Old 02-20-2007, 06:26 PM   #78
white46
My Ride: e46 323ci
i think i heard somewhere that tape deck is not compatible with aux input even though its built date is 09/02.
white46 is offline   Reply With Quote
Old 02-20-2007, 06:43 PM   #79
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Business Cassette (even post 09/02) does not support AUX.
Old 02-21-2007, 03:18 AM   #80
chrismiros
bugger
bmw aux in, diy aux input, input cable
