Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 02-22-2007, 01:04 PM   #81
'busa
'busa's Avatar
My Ride: E90 335i (sold)
Looks like I'll be revisiting this thread before the weekend's over. Any feedback/suggestions from people who have done this DIY?
'busa is offline   Reply With Quote
Old 02-23-2007, 10:05 PM   #82
'busa
'busa's Avatar
OK, so I did this and I plugged in my MP3 Player and everything works great. I adjusted the audio level, the sound is awesome. Everything.
I plug it into the XM Player and nothing. Doesn't even know it's there. It switches back to CD. WTF?
Old 02-23-2007, 10:25 PM   #83
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
There's a ground loop that's happening and your radio is shutting down the AUX port. Try using another power source or a ground loop isolator on your power wire to fix the issue.
tom @ eas is offline   Reply With Quote
Old 02-23-2007, 10:31 PM   #84
'busa
'busa's Avatar
Isolate the XM Player power wire? The AUX wire? Either? Both?
Old 02-23-2007, 10:32 PM   #85
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
The XM Device wire.
Old 02-23-2007, 10:38 PM   #86
'busa
'busa's Avatar
The XM Device wire.
Any quick way of doing this? Aluminum foil comes to mind...
EDIT: I just googled it and it seems aluminum foil won't work. I think I'll try powering the XM with batteries first, then see what I can do about the power? Unless... maybe there is a simple solution?
Old 02-23-2007, 10:45 PM   #87
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Just install a ground loop isolator into the power wire, here's a link to the version we carry. You should be able to find a similar unit at a local audio shop.
12 Amp Power Noise Filter
http://www.europeanautosource.com/pr...roducts_id=309
Let me know if you have any further questions!
Old 02-23-2007, 10:58 PM   #88
'busa
'busa's Avatar
Very nice! It seems you know what you're talking about. When it's not plugged in, the radio detects it, but of course, since it's not plugged in there's no sound. As soon as I plug in the power wire, the radio goes back to CD.
Is a ground loop isolator the only solution?
Old 02-23-2007, 11:12 PM   #89
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Yes - the radio is sensing power through the AUX port, and turning it off as a safety.
Old 02-24-2007, 11:32 AM   #90
'busa
'busa's Avatar
So, I'll have to cut the cigarette lighter adaptor apart and tap into each of the wires with it?
Old 02-26-2007, 12:54 AM   #91
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
If this is your power source, yes.
Old 02-26-2007, 11:53 AM   #92
'busa
'busa's Avatar
Sorry about all the questions. I just want to make sure I'm on the right path. With the headphones, I had to cut both wires, take the groundwires out of each and combine them into one for the connection to work.
On the cigarette lighter adapter, I'm guessing I'll pretty much have to do the same thing, since I don't see a separate ground wire just by looking at it.
Also, how does the fact that I want to tap into a power source in the car, instead of the lighter, change things? Do I still have to do this? Would it be easier if I do that first?
Thanks, Tom! You're a great help.
Old 02-26-2007, 12:45 PM   #93
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
With a light tester/multimeter test for a +12V signal and tap the noise filter into it. The fact that you're using a powered source is causing the AUX to drop from the bus - so the filter is needed.
Old 03-03-2007, 09:00 PM   #94
'busa
'busa's Avatar
OK, I didn't get get to do anything yet. I was wondering. If I tap into the car's power source, will I still have this issue??
Old 03-25-2007, 01:47 PM   #95
srle
My Ride: BMW 330cd
hallo hallo!
help needed! i made my own aux input cable. it works fine with my player and headphones but when i connect it to the HU and press mode button i can't find AUX. just FM and CD appears like before. i have checked my SV and 07-02-540 is written there. so what's wrong?
thakns!
srle is offline   Reply With Quote
Old 03-25-2007, 01:50 PM   #96
'busa
'busa's Avatar
Djesi Srle!
For me AUX only shows up when I actually have something connected to the cable, AND when it powered by an external source (batteries in my case). My Satellite Radio won't show up because it's powered by the lighter.
Hope that helps.
Old 03-25-2007, 04:36 PM   #97
srle
My Ride: BMW 330cd
Cao majstore! :-)
could it be that i had my macbook used as a sound source? it shouldn't i thing, or am i wrong?
Old 03-25-2007, 04:46 PM   #98
'busa
'busa's Avatar
I don't think that should be a problem. It works with every other sound source?
Old 03-25-2007, 07:38 PM   #99
srle
My Ride: BMW 330cd
http://kaiser-media.de/bmw/aux-in/
mabye i have found the answer....
Old 03-25-2007, 09:33 PM   #100
'busa
'busa's Avatar
Wow, that guy really got into it. What are those, resistors? And why?
bmw aux in, diy aux input, input cable
