Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
Tail light warning fuse???
Does anyone know which fuse to pull to get the lights out warning for the tail and headlights to disappear? I have an 04 sedan......both headlights and both tail light lights-out warnings are appearing on my dash.
#2 |
Thanks for the loads of support guys.... ...does anyone know if pulling fuse 32 will take care of both sets (headlight and tails) or just the headlight warning? |
#3 |
1.888.JLEVISW
Fuse 32 is only related to the headlight out warning system, it will not prevent the tail light out warning./
#4 |
^^^ Thanks...
Do you know if there is any way other than using resistors to get that warning to go away? The reason I can't really use resistors is because I have aftermarket tails with a different connector...I would need to add a resistor for each bulb in the tail light. |
