Old 12-04-2006, 06:27 PM   #1
hitmanxx00
My Ride: '02 330i
car shakes after revving engine in park
as the title states
The car has been in the garage now for a couple of weeks.
I started the car up and left it running for about 3-4 mins
when i came back i revved the engine while it was still in park.
when the revs would start to drop the engine/car would shake.
is this normal?
hitmanxx00 is offline   Reply With Quote
Old 12-04-2006, 06:31 PM   #2
Dan04E46
My Ride: '04 S54B32 Coupe
It isn't normal.Bad motor mounts maybe?
DAN WAS HERE
2001 330Ci= Sold :(
2004 M3 coupe= Mine! :D
Dan04E46 is offline   Reply With Quote
Old 12-04-2006, 08:07 PM   #3
e46nj325
My Ride: E46 325i
is it still doing it? or was it only that once?
e46nj325 is offline   Reply With Quote
Old 12-04-2006, 08:12 PM   #4
jkalex05
My Ride: fast cars
if it was only once it could have still been warming up, my car usually takes 5-10mins to fully warm up just being off 10 hours.
If it keeps shaking, it could be your motor mounts are going. or another engine issue.
jkalex05 is offline   Reply With Quote
Old 12-04-2006, 09:58 PM   #5
driftinsequence
My Ride: waiting to be modded
Send a message via AIM to driftinsequence
what about a misfire? car is running rich when you warm up.
only a fault code check could tell you if that happened.
if engine mounts were broken, then the entire car would vibrate at idle as well. how high did you rev the engine for reference.
driftinsequence is offline   Reply With Quote
Old 12-04-2006, 10:08 PM   #6
hitmanxx00
My Ride: '02 330i
im about to go check if it is still doing it
Old 12-04-2006, 10:09 PM   #7
hitmanxx00
My Ride: '02 330i
i only revved up to about 3k rpm
mind you this was the first time i started the car in a little over a week
Old 12-04-2006, 10:11 PM   #8
eku017
My Ride: BMW 325i
similar thing happened to my 2004 325i, i took it to the dealer and just couldnt repeat the shaking and it just disappeared
eku017 is offline   Reply With Quote
Old 12-04-2006, 10:20 PM   #9
clinique
clinique's Avatar
My Ride: 06 M3 Vert
it happens once in a while. always on a cold start. instead of letting it sit and warm up, i just take off (gently) and let it warm up that way. doesnt happen to me anymore.
i never figured out why it happened tho.
clinique is offline   Reply With Quote
Old 12-04-2006, 10:21 PM   #10
clinique
clinique's Avatar
My Ride: 06 M3 Vert
but it wasnt shaking violently. just enough to notice.
Old 12-04-2006, 10:29 PM   #11
hitmanxx00
My Ride: '02 330i
i think i tripped out
i let the car warm up for about 10 mins
this time nothing happened
it must have been due to a cold start
the temperature in vancouver the last few days has been pretty cold too
thanks for everyone's input
Old 12-04-2006, 11:04 PM   #12
PromethWill88
My Ride: 04 Dinan S M3
Did you get your coil packs changed with the recall several months back? My car started shaking while in park when I started it, took it in, found out BMW NA issued a recall on on 99-05 3-series on faulty coils, which causes misfires.
Check with your local dealer.
PromethWill88 is offline   Reply With Quote
Old 12-04-2006, 11:05 PM   #13
e330zhp46
e330zhp46's Avatar
My Ride: (SEE SIGNATURE)
just a wild guess, does your car have a manual transmission
_______________________________________________Has Three Pedals__________________________
** sig size and layout changed by tim330i to reduce side scroll ** sorry my monitor is 1680x1050 so there is no side scroll for me
e330zhp46 is offline   Reply With Quote
Old 12-04-2006, 11:23 PM   #14
driftinsequence
wait a second: does the rpm kinda dip below the normal idle of 700? sometimes the car when started when its cold and after a while, i notice the RPM needle dip down below 500, and this is after i reved it. feels like, if your car is a stick, that you have a noticable amount of vibration from the engine.
is this what your experiencing.
Old 12-04-2006, 11:36 PM   #15
e46nj325
My Ride: E46 325i
yeah mine dips when its cold i think all the manual trans do it if it was just that once i wouldnt be to worried about it just cold start/motor has sat for a while type of thing if it begins to happen all the time thats when you should worry
Old 12-04-2006, 11:52 PM   #16
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
dudes, this is a very well known and documented problem for the e46. search 'cold idle' or 'cold start' in the general forum and you should see well over 100 threads covering this.
^ (that is, if i'm understanding the OP correctly)
hi its me alec is offline   Reply With Quote
Old 12-04-2006, 11:58 PM   #17
flat6
My Ride: 05' E46 318i Sports
Happens with my car on real cold mornings and if i havent started it in a few days, as soon as i start it i feel the vibrations through the steering wheel, it sounds kind of irregular at first but sorts its self out..
I think its a bmw trait as a lot of people notice it.
flat6 is offline   Reply With Quote
Old 12-05-2006, 03:04 AM   #18
kameleon
My Ride: various
Send a message via MSN to kameleon
coils are a issue yes. but it isn't always the case. the engine lifters is my guess as youve mentioned the vehicle had sat around for "x" amount of time.
kameleon is offline   Reply With Quote
Old 12-06-2006, 10:59 AM   #19
hitmanxx00
My Ride: '02 330i
i was at the dealer in mid october ... they told me then that all recall work is done on my car
Old 12-06-2006, 11:00 AM   #20
hitmanxx00
My Ride: '02 330i
no, it's step
