Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 07-31-2008, 07:59 PM   #321
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by 02m3csl325 View Post
Alec, not sure if you know but I'm getting ready to do my brakes on my 325i and I've got a buddy who is willing to practically give me his M3 parts since he's just upgrading everything. I was originally going to do the 330 upgrade but this would even be better and cheaper if it could work. Anyway, I know now the suspention isn't compatible but what about the brakes? If he gives me his full set of brakes including the carriers, will those bolt on fine? Also will the ebrake still work correctly or is that the part that's not compatible? Thanks for shedding any light on this subject.
I'm not Alec, but...
M3 and 330 brakes are the same diameter in front. You'd have to professionally machine off mm of metal to begin to get it to fit. Ask Alec what happens to a front caliper when there is something amiss in the fastening. You really don't want to mess with that way of getting it to fit. I've read of one guy years ago who said he did it. But never EVER anything as far as updates on how it turned out. So that makes me think it took a dump and he was embarrassed to admit it or worse. Rear parking brake is a PITA. Reason why many leave the rears alone. Is the saving of a few dollars worth having the brakes go out when you need them the most?
Old 08-14-2008, 09:52 AM   #322
Desertium
My Ride: 2000 328i
Send a message via AIM to Desertium Send a message via Yahoo to Desertium
great post
SUCH A PRETTY SMILE.....
Desertium is offline   Reply With Quote
Old 08-14-2008, 02:07 PM   #323
LeeT
My Ride: 1999 328ci
Hi Guys, another new member from The UK here. Let me just start by saying that this is an excellent forum and this thread is extremely helpful. I am currently getting together the parts i need to do an M3 front end conversion. And before anyone says it i plan on filling the fender gills as i am not an m3 wannabe. I just love the styling of the M3. My car is a 1999 328ci which already has the Mtech2 bumper retrofitted as well as the rest of the Mtech kit. I have read this whole thread many times but am still a little unsure on which reinforcement bar i need to use for the front bumper? I will be fitting the M3 front fenders and i have the M3 bonnet and OEM front bumper. The M3 front bumper has the foam insert already in it. Can i use my existing rebar or do i need to get the c/f M3 rebar? I am confused here as i am fitting the OEM fenders too. Will i still need to shave the foam insert or cut down the existing rebar etc etc.
Thankyou for any help on this
LeeT is offline   Reply With Quote
Old 08-14-2008, 06:59 PM   #324
TopasBlau46
My Ride: 2001 E46 325ci ZSP
Throwing an M3 or M-tech bumper of any kind on your car is not being a "wannabe". Plenty of enthusiasts go this route, in an effort to make their cars look less boring and stock, and more sporty. It's when you stick the fake side grills or M3 emblems all over that it becomes a "wannabe."
In addition, make sure you get an M3 REPLICA bumper, NOT the real M3 bumper. Although the M3 bumper will fit the coupe better than the sedan, it will not perfectly fit, and as a result, stick out and overhang a little. A replica bumper is an M3 bumper that is made to fit a car other than the M3. Plenty of vendors sell them.
TopasBlau46 is offline   Reply With Quote
Old 08-15-2008, 01:43 AM   #325
Alex323Ci
He said he also has M3 fenders and the M3 hood. So no way should he be doing a copy of the M3 bumper. It wouldn't line up with the wider and taller fenders or the M3 hood aligned to the fenders.
Old 08-15-2008, 10:08 AM   #326
LeeT
My Ride: 1999 328ci
Thanks for the replies. I already have the genuine M3 bumper and as Alex said i will also be using the genuine M3 fenders with the gills welded up. So with this set up do i still need to buy a genuine M3 c/f rebar? Or can i mod the existing one? Also as i mentioned above, the m3 bumper came with its foam insert
Old 08-18-2008, 10:43 PM   #327
freshprince2421
My Ride: 325ci
wow
freshprince2421 is offline   Reply With Quote
Old 09-04-2008, 11:59 AM   #328
kevinterkelsen
My Ride: 328 ci (TS 3)
Thumbs Up M3 front sway/anti-roll bar - will it fit 328coupe
Hi Alec,
great thread that I have enjoyed reading - thanks man! in post 235 a guy asks if he can use the front sway from an m3 - and in post 237 another guy says yes - could you confirm fitment to a 328 coupe from 99 (only interessted in the front because of the weight of the TS kit from ESS + cast iron block to take the punishment of added boost). I have a TMS setup for sways and it is just not cutting it for me - i need more stiffness in front.
kevinterkelsen is offline   Reply With Quote
Old 09-04-2008, 12:18 PM   #329
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Originally Posted by kevinterkelsen View Post
Hi Alec,
Yep, OEM M3 front sway bar will fit fine. The only reason the rear doesn't is because the entire subframe/rear axle is different between M3 and non-M.
hi its me alec is offline   Reply With Quote
Old 09-05-2008, 08:02 AM   #330
kevinterkelsen
Thumbs Up Thanks!
Excellent -thanks!!!!
Old 09-05-2008, 02:35 PM   #331
Alex323Ci
Hi Alec,
TMS/H&R use a 27mm front bar. The M3 uses a 26mm front bar. I'm not sure why you'd swap? Seems you may be going down depending on linkage points. The bushing will certainly be firmer with the TMS bar.
If you need more stiffness in the front that sounds like springs and/or dampeners.
Old 09-06-2008, 09:19 PM   #332
kpd1999
My Ride: Begins with an ///M
Originally Posted by Ga3er View Post
Had to put stiffer springs on rear to work. No scrub. but tight end not much bounce.
Ok, he did this without rolling the fenders and used stiffer rear springs. I have an '04 325Ci. Its my understanding that the '01+ coupes come standard with a sport suspension. My question is will '02 M3 wheels (18x8 and 18x8.5) fit on my car without MAJOR modifications? Thx
///M3 <---Adopted by a new owner. E60 535i coming up!
kpd1999 is offline   Reply With Quote
Old 09-07-2008, 08:51 PM   #333
gra_2472
My Ride: 2005 BMW 330CI
Is it really that difficult to fit M3 wheels on a non M3 vehicle; for instance a 2005 330CI?
gra_2472 is offline   Reply With Quote
Old 09-08-2008, 04:35 AM   #334
tuscan1205
My Ride: e46 325CI, w212 E550
Nah, you can just use spring spacers like i did.
ID:	283986   Click image for larger version
Name:	DSC00537sm blank.jpg
ID:	283987   Click image for larger version
Name:	DSC00539sm blank.jpg
ID:	283988   Click image for larger version
tuscan1205 is offline   Reply With Quote
Old 09-11-2008, 09:15 PM   #335
JV805///M
My Ride: 2005 M3 ZCP
Send a message via AIM to JV805///M
Lets say I want to install these rims on my car ('05 330Ci ZHP)...
http://www.wheeldude.com/catalog/pro...oducts_id=5646
What will I need to get to make them work? What size spacers (I have s-tech springs)? Fender rolling?
-Jim
2005 ///M3 ZCP IR/IR
Instagram: @jimvon
JV805///M is offline   Reply With Quote
Old 09-11-2008, 09:39 PM   #336
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
they have non ///M (regular E46) staggered fitment - just buy the correct ones for your car (but you wont get the 10")
/_________\
O==[][]==O
Old 09-11-2008, 09:40 PM   #337
330i ZHP
330i ZHP's Avatar
http://www.wheeldude.com/catalog/pro...oducts_id=5630
/_________\
O==[][]==O
Old 09-11-2008, 09:50 PM   #338
JV805///M
yeah I guess you're right, I kind of just wanted an aggressive offset!
-Jim
Instagram: @jimvon
Old 09-11-2008, 10:18 PM   #339
330i ZHP
330i ZHP's Avatar
look at mine - you can run the 9.5's with TIGHT fender rolling and pulling the fenders....although mine are the OEM BBS with 32et (not the 25et 10")
/_________\
O==[][]==O
Old 09-12-2008, 02:45 AM   #340
natty99
My Ride: 2005 BMW M3
Hey guys, I'm new to the forum and currently looking to buy a ZHP. Being a newb, I'm sorry if this question is answered elsewhere, but I have not been able to find it:
Why, exactly, do the LED tail lights not 'fit' the sedan? Is it a physical problem (the tails are simply shaped differently) and/or electrical? If it is only an electrical problem, couldn't something be done to make the LEDs work on the sedan?
Thanks!
natty99 is offline   Reply With Quote
