Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 05-14-2009, 03:21 AM   #421
kevinterkelsen
My Ride: 328 ci (TS 3)
Weight saving - oem hood vs. m3 oem hood
Hi guys,
been searching and the best I can come up with is that the oem m3 hood should weigh 32 lbs (a Vorsteiner price and weight comparison) - is the 32 lbs the right number for a oem m3 hood? what is the weight of a 3 series prefacelift (non-m3) hood? anybody know how much weight can be saved?
Kevin
kevinterkelsen is offline   Reply With Quote
Old 05-14-2009, 11:34 PM   #422
325i project!!
My Ride: 02 325i, 5 speed
Originally Posted by hi its me alec View Post
Yes, it will fit. Here are the mods that need to be done.
- M3 transmission
- M3 engine
- M3 DME
- M3 cluster
- M3 LCM
- M3 shifter parts
- M3 engine harness
- M3 body harness, adapted for non-M sedan (rear windows (???), sport button, etc.)
- Traction control??
- Speed sensors?
- all necessary brackets, etc. etc.
All of which, you have to find and do yourself. Your best bet would be to find a wrecked (in the rear) M3, strip both cars down, and swap all the M3 parts into the 325... we're talking every single part here. This will end up costing you a fortune of money and time, especially on the research end of things.
I thouhgt it would be easier,you know, like swaping a honda civic
you only need the engine ,tranny,ecu,motor mounts,harness and the conversion from obd2 to obd1.So I guess it would be better,easier and cheaper to supercharge it right? let me know!! thanks
325i project!! is offline   Reply With Quote
Old 05-15-2009, 05:01 PM   #423
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Exactly! My best friend's e46 has an ASA blower and it's wicked fast, eats M3s. He got the kit for around 3500 I think it was.
The e46 is so hard to do crazy engine swaps on because it starts out as OBD2. In the future, I really want to attempt an OBD1 conversion. I'd love to do an S52B32 in an e46 sedan and turbo the sh!t out of it.
hi its me alec is offline   Reply With Quote
Old 05-15-2009, 11:29 PM   #424
325i project!!
sorry what's an s52B32?? newby here!!
Old 05-16-2009, 12:21 AM   #425
hi its me alec
e36 M3 (euro, which has stock independent throttle bodies) engine... this one has an ASA blower
or maybe an S38B38 from an e28 M5.. although it might not be an easy fit. But by logic, you should be able to use the engine. e46 engines work in e30s, and the S38 works in e30s, so hopefully the S38 will fit in an early e46. all of these engines would be especially tough in a late e46 because you'd have to ditch the whole drive-by-wire system and convert to drive-by-cable... i guess i just don't know how that works, so it sounds intimidating lol.
here's a list of 'common' engines for you... lol
e30:
325i = 2.5L (Inline 6) = M20B25
325e = 2.7L (Inline 6)= M20B27
M3 = 2.3L (Inline 4) = S14
e36:
325i = 2.5L = M50B25
Early US M3 = 3.0L = S50B30
Late US M3 = 3.2L = S52B32
Euro M3 = 3.2L = S50B32
e46:
323i = 2.5L = M52B25
325i = 2.5L = M54B25
328i = 2.8L = M52B28
330i = 3.0L = M54B30
M3 = S54B32
the S54 is a seriously porn'd out engine too.
Old 06-06-2009, 09:50 PM   #426
Fidget
My Ride: BMW
any of you guys know what the part numbers for the rear quarters on an e46 m3 are? kinda curious about the cost of them
Fidget is offline   Reply With Quote
Old 06-07-2009, 01:00 AM   #427
BMW_Matt
My Ride: 135
Rear quarter panels on a '02 m3?
http://www.realoem.com/bmw/showparts...64&hg=41&fg=25
41217890689
Realoem is the bmw catalogue online. Search around there and you should find the part # and price for anything you ever need
BMW_Matt is offline   Reply With Quote
Old 06-17-2009, 03:33 PM   #428
kevinterkelsen
Weight
If anybodys interessted here is what I have been able to find out on the weight of different hoods
Stock non M: 47 lbs
Mhood: 32 lbs
Vorsteiner/Seibon OEM: 16 lbs
have a nice day :o)
Old 06-17-2009, 03:37 PM   #429
stb5151
My Ride: 04' 330i Dinan ZHP
Send a message via AIM to stb5151
Great thread!
subscribed!
stb5151 is offline   Reply With Quote
Old 06-21-2009, 02:00 PM   #430
njoni007
My Ride: 330Ci ESS TS2
The oil temp gauge works without a problem on 330Ci
njoni007 is offline   Reply With Quote
Old 06-22-2009, 07:02 AM   #431
Safar
My Ride: comes with blow
Where does it pick up the signal from then? Are you sure it's not showing coolant temperature?
Vehicle history
1999 BMW E46 328Ci TS2
1992 BMW E36 316i Sold
1987 Suzuki VS1400
1996 Suzuki LS650 Sold
1984 Kawasaki 305CSR RIP
Went from 305cc > 650cc > 1400cc > 2800cc
No prizes for guessing what my next engine will be...
Safar is offline   Reply With Quote
Old 07-16-2009, 04:33 PM   #432
SKIPPY PB
My Ride: YZ125
Whats the difference between the M3 tire well and non M. Is it location or is the m3 one smaller?
SKIPPY PB is offline   Reply With Quote
Old 07-16-2009, 05:09 PM   #433
hi its me alec
Are you talking about the spare tire well? The M3 one is way smaller, about 8" deep and the shape of a half-circle, impossible to fit any kind of wheel in there. Basically, the M3 well is made to clear the huge center-exit muffler out back.
Old 08-15-2009, 09:16 AM   #434
coopV2
My Ride: 1990 E30 coupe
Originally Posted by Solo118 View Post
what about smg/ssg paddles same plug and play with the steptronic?
Fitted an M3 paddle shift to my 2000 330ci , requires a new slip ring (got mine off Pelican) and a small 2 pin computer plug for the 2 wires to run down to the shifter micro switches, so in sport mode there are 3 wires feeding the micros 1 is power to make them active in the system the others are for up and down the gears, so 1 of each to each paddle, easy really, no problems, computer sorts out which one was first if you hit both.
Coop
coopV2 is offline   Reply With Quote
Old 08-16-2009, 06:05 AM   #435
morgan_g
My Ride: 2005 325ci
I've read through all 22 pages ...
I've just bought a 2005 325ci facelift coupe. Is it in any possible to install M3 xenon headlights in them? The 325 does not have auto-levelling.
morgan_g is offline   Reply With Quote
Old 08-16-2009, 10:18 AM   #436
hi its me alec
Yes, but you need all the parts necessary to switch from facelift to pre-facelift. So that's fenders, headlights, and headlight trim pieces underneath the headlights. Not worth it
Old 08-17-2009, 05:16 AM   #437
morgan_g
My Ride: 2005 325ci
Thanks for the reply - much appreciated.
Old 08-20-2009, 06:54 PM   #438
gldtn
My Ride: 99 E46 328i M52
Hello, I have a set of 2006 M3 rims on a 99 E46 pre-facelift 328i and the back is catching badly.. For now I just took them off. The back is 265/35/19.. What tire profile would you guys suggest I get so I can make it better? What do u mean by fender rolling? Another idea I had, but I'm not sure if it's possible.. What if I get an adjustable shocks/struts to raise it a bit?
Thanks in advance!
gldtn is offline   Reply With Quote
Old 08-20-2009, 11:50 PM   #439
hi its me alec
Thanks in advance!
You should probably be running 225/35 all around, maybe a 235/35 in the back but it would probably rub.
Fender rolling means taking a big rolling device (attaches via lugnuts) and rolling the inner lips of the rear fenders flat. That's probably what the tires are rubbing on now. Either way, 265 is outrageous for how far the M3 wheels stick out. Here's what it looks like:
Your new shocks/struts to raise the car idea is... well.. bad. lol
Happy first post, enjoy the forum!
Old 08-21-2009, 06:14 PM   #440
gldtn
Thanks for the fast reply Alec.
Well, I went down to this local shop that does some custom work and had them roll the fender for me. It seems they couldn't do much with the passenger side, because they said it is much thicker then the driver side. So they did as much as they could.. Now as far as the tire size.. According to the tire shop I went to, the smallest size I could put on that wheel(9 1/2 width?) is a 235/35/19. Is this true or these people don't really know what they're talking about? I didn't really check but are the m3 wheels staggered?
Thanks once again guys!
