Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 01-09-2010, 07:15 PM   #461
Mayo
My Ride: CBR600RR
So from what I can tell H&R Race springs from a 330Ci will fit an M3?
TopasBlau 330Ci
M-Tech II || Borla Catback || Bilstein PSS || K&N CAI ||Shark Injected || eBay headers ||
DICE Silverline || Smoked LED Tails/Sidemarkers || Clear Corners || 18" x 8.5/9.5 Forgestar F14's on Kumho
Mayo is offline   Reply With Quote
Old 01-09-2010, 10:54 PM   #462
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Probably, but nobody has done it to my knowledge. I'd like to see someone try though, the rears would fit for sure, and I don't know why the fronts wouldn't.
The only problem is that an M3 is heavier, so the spring rates will be too soft. I think.
hi its me alec is offline   Reply With Quote
Old 01-14-2010, 10:53 AM   #463
shwagon
My Ride: 325it 5-speed
Has anyone put oem m3 control arm bushings on a reg e46? The m3 bushings are soild (rubber) and offset (I think for caster reasons). Im trying to stay away from poly bushings as much as possible.
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 01-14-2010, 10:30 PM   #464
330inthe330
My Ride: TiAg 330cic
I'm thinking about one of the eom m3 hoods. This thread will help many members.
330inthe330 is offline   Reply With Quote
Old 01-19-2010, 11:55 PM   #465
gldtn
My Ride: 99 E46 328i M52
Originally Posted by klv611 View Post
Thanks Alec but no thanks. I'll keep moding!!
Pics to come soon
Any luck with this?
Originally Posted by hi its me alec View Post
You don't need fender work, you need narrower tires.
I heard that with my fender being rolled and if I put a 245 zy tires it wont catch! What is your opinion on this?
gldtn is offline   Reply With Quote
Old 01-20-2010, 09:47 AM   #466
Be.M.w.e46
My Ride: 323ci
is there any how tos for rear bumper?
Be.M.w.e46 is offline   Reply With Quote
Old 01-26-2010, 01:56 PM   #467
BM Dubbz
My Ride: e46 325i
Do you think the M3 heated sport seats fits a sedan? My sedan dont have heated seats but planning to install. THanks
BM Dubbz is offline   Reply With Quote
Old 01-26-2010, 08:29 PM   #468
hi its me alec
Yes. I put heated M3 seats in my sedan, but I already had heated seats, so they were just plug and play (you just have to swap the outer rails so the seatbelt mount is still there, which is the rule with swapping any coupe seats into sedan.)
So you'll just have to do the heated seat retrofit on top of that. Should be pretty simple.
Yeah, that sounds pretty good to me. If it was my car, I would try a 235/35 rear to start, just to make sure it doesn't rub too intensely. 245 on a 9.5" would be a close call if you don't have a lot of camber, since it's a normal tire for that size wheel.
This is what a 235/35 looks like on a 9.5", this is a good middle ground to start.
and here's a 225/35 on a 9.5". You won't need to go this narrow if you roll the fenders well, but you can see what narrower tires do on wide wheels.. bump the size down and the clearance increases quite a bit.
Old 01-26-2010, 10:56 PM   #469
gldtn
To be safe, I'll go with the 235/35..
This doesn't look bad.. but I hope the 235/35 do me fine *fingers crossed*
Alec, my front tires says 225/40! Should the front be 40 or should I drop it down to 225/35?
Thanks once again for the great help Alec! Lol your lucky your not my neighbor I would be randomly knocking on your door for help w/ my bimmer
Old 01-26-2010, 11:18 PM   #470
hi its me alec
On a 19" wheel, it should definitely be a 225/35. Never heard of anyone running a 40, I assume there would be intense rubbing when the wheel is turned to full lock. 225 front - 235 rear is a good setup, I have it on my e46 right now and it looks pretty good and performs like a champion.
Old 01-27-2010, 07:42 AM   #471
gldtn
On to the mirrors..
On the first post you put down the parts #'s.. I need to buy all these parts Part Numbers?
RIGHT PRIMED EL.EXTER.HEATABLE MIRROR 51167893468 $232.13
LEFT PRIMED EL.EXTERIOR HEATABLE MIRROR 51167893597 $232.13
ACTUATOR LEFT 51167895273 $169.63
ACTUATOR RIGHT 51167895274 $169.63
MIRROR GLASS HEATED PLANE LEFT 51167157247 $46.59
ADAPTER LEAD, MIRROR HEATING 51167836442 $6.58
MIRROR GLASS HEATED CONVEX RIGHT 51167157244 $58.31
That's almost $1000.00/us
Also I have a 99 328i sedan.. if they ask what year m3 I need them for what should I say? or would any e46 m3 mirrors fit?
Fenders, will a 2003 m3 fenders fit a pre-facelift e46 sedan?
Old 01-27-2010, 06:57 PM   #472
QuoteWarz Insurance
Past Site Sponsor
My Ride: M3
Yes, I agree that a 35 series tire is definitely what you are going to need. I have heard of people putting a 40 or even 45 series tire on, but it will always rub unless you do some inner fender modifications. If you run that size tire and don't modify the fender then it will get damaged in no time and then you will need to replace it which is never fun.
QuoteWarz Insurance is offline   Reply With Quote
Old 01-27-2010, 07:46 PM   #473
gldtn
I bought the wheels off of ebay.. the tires was pretty warn out, so I'm guessing the guy put it on just to sell the wheels! but yeah the fronts are currently 225/40, but I didn't notice anything catching/rubbing while doing turns, go figure. When I take it to put on new tires I'll pay close attention to it.. just to see if they were catching or not.
My new ones will definetly be 35 all around!
Thanks!
Old 01-27-2010, 09:28 PM   #474
hi its me alec
On to the mirrors..
that's not the actual price, just the realoem.com retail. i got mine from the dealership (when i worked there last year) for around 500.
tell them you need 6 or 12 pin connectors, depending what you have in your car. if you don't know already, you need to take your door panel off and find out how many pins are in the mirror connector. you can also choose whether they're autofolding or not, and maybe heat was an option too. mine are the whole she-bang in 6 pin.
Old 01-29-2010, 07:45 AM   #475
gldtn
I haven't taken the door panel apart yet, due to extremely cold weather :/, but from the looks It's heated w/o memory! Now can I get the she-bang even if mine doesn't have it, will it work? I'm not interested about memory, but auto folding would be nice. If I can how can I get the auto-folding to work, will I need anything extra?
Sorry for all these question and Thanks!
Old 02-20-2010, 07:43 PM   #476
wetdragon
My Ride: sammy
sweet post. thanks bro
wetdragon is offline   Reply With Quote
Old 03-05-2010, 07:38 PM   #477
pudermcgavin
My Ride: 02 325i
does not fit on sedan?
so if it doesnt fit on the sedan what hood to sedan owners need or are we screwed? and if so can i convert to the coupe front end or is that a hood issue as well?
pudermcgavin is offline   Reply With Quote
Old 03-11-2010, 05:28 PM   #478
Sevenevez
My Ride: 325Ci vert
Great Post!
80% of the time, im Fresh ALL of the time
Sevenevez is offline   Reply With Quote
Old 05-26-2010, 11:53 PM   #479
ntempy101
My Ride: Audi S4
Originally Posted by ShiftyGerman View Post
+1
Great thread
I like what i see[img]https://www.fitnessphreaks.info/workout/upload/51*************[/img].. The cars pretty nice too
ntempy101 is offline   Reply With Quote
Old 07-29-2010, 06:30 PM   #480
carsos
My Ride: '03 325Ci
if they're both coupes, will the interior door panels and rear seats from an m3 fit in my non-m? i can't think of a reason why they wouldn't, but want to make 100% sure before i go ahead.
carsos is offline   Reply With Quote
