Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 11-04-2012, 03:31 PM   #601
Arpee
My Ride: E30 M3/ 323ci
Will M3 vert side skirt fits 2000 coupes?
Arpee is offline   Reply With Quote
Old 11-04-2012, 04:05 PM   #602
w0w
My Ride: '02 M3 Vert
did u not read the first post?
daron
w0w is offline   Reply With Quote
Old 11-05-2012, 02:29 PM   #603
Alex323Ci
My Ride: M3 & 323Ci (sold)
the M3 convertible and the M3 coupe have the same part number for the sideskirts. So it's the same question as if E46 M3 sideskirts will fit a E46 Coupe which is on the first page of the thread.
Yes
Old 11-05-2012, 09:05 PM   #604
Arpee
Old 11-14-2012, 09:55 AM   #605
ecfrankyboy
My Ride: 325ci 2005
Interesting thread !
ecfrankyboy is offline   Reply With Quote
Old 11-19-2012, 11:25 AM   #606
gselsidi
My Ride: 2005 325i M56
Can I use my stock 2005 325i foglights with an mtech II bumper or are they shaped differently? If so what can be done and brackets or anything?
gselsidi is offline   Reply With Quote
Old 11-19-2012, 12:18 PM   #607
jabela
My Ride: 2002 325ci
Will complete M3 coilovers, including camber plates (from Ground Control, TCK, etc.) fit directly onto a non-M?
thanks.
2002 BMW 325ci /// Sport Pkg /// 5 spd
Modern Apothecary
jabela is offline   Reply With Quote
Old 11-19-2012, 03:08 PM   #608
Alex323Ci
How To Fit OEM M3 Parts To A Non M
thread is "How To Fit OEM M3 Parts To A Non-M"
you're talking "OEM" but not "M3".
wrong thread
thanks.
you're talking "M3" but not "OEM"
wrong thread
Old 12-07-2012, 11:35 AM   #609
Andrew99328i
My Ride: 328i 99
maybe wrong thread as this stuff is mostly body kits and suspension
question:
what about changing ASC throttle body on m52tub28 for a m3 TB????
tnks
Andrew99328i is offline   Reply With Quote
Old 12-08-2012, 12:45 PM   #610
SweTurbo
Big Pimpin'
My Ride: 323i -98
thanks.
They do
Originally Posted by Andrew99328i View Post
question:
tnks
No , M52 uses a throttle cable but the S54 uses an electric motor.
Aswell as you'd have lots of physical problems fitting it the performance boost isnt that much, the head is where the S54 makes its power.
Old 12-08-2012, 02:58 PM   #611
bmwmck
My Ride: '00 328i 5spd
So, swapping M3 coupe seats into a sedan requires the transfer of the sedan seat outer rails onto the M3 seats. But can you transfer both the inner and outer rails from the sedan seat on to the M3 seat? I've got a chance to buy some M3 coupe seats but the rails aren't included. Thanks
bmwmck is offline   Reply With Quote
Old 12-08-2012, 05:07 PM   #612
nckash055
My Ride: 323i
Hey how can I get the steering wheel to fit my 2000 e46
nckash055 is offline   Reply With Quote
Old 12-08-2012, 10:11 PM   #613
SweTurbo
Big Pimpin'
My Ride: 323i -98
Unbolt current, bolt in m3
If your car has MF then the M3 wheel controls will work from what i know.
If not then you cant expect it to with the M3 one(since it's often not prewired).
Old 12-18-2012, 10:12 PM   #614
halla330
My Ride: E46 330Ci
got a question for ya..
would the Eisenmann M3 Quad system (LeMans version) fit my 330Ci which has had its wheel well welded shut.
halla330 is offline   Reply With Quote
Old 12-27-2012, 09:32 PM   #615
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
If I remember right, the inner rails are the same, which is why the outers are the only ones that need to be swapped.
hi its me alec is offline   Reply With Quote
Old 12-31-2012, 04:21 AM   #616
e46hovsep
My Ride: 2003 E46 M3 Smg
can it be done the other way around? i have an E46 M3 and i need a front bumper and the one for the M3 is a lot more expensive then the one for the normal E46 coupe, would i be able to retrofit the bumper onto my car?
e46hovsep is offline   Reply With Quote
Old 01-09-2013, 01:32 PM   #617
The_W_95
My Ride: 2003 330i
Does anybody know if m3 end links will fit a non m? Sedan in my case
The_W_95 is offline   Reply With Quote
Old 01-21-2013, 08:01 PM   #618
SB_RavenE46
My Ride: 330CI ,06 R6, S1000
Send a message via Yahoo to SB_RavenE46
Ok so i have a 02 330Ci and i have a OEM m3 bumper from a 02 M3 ( this is the m3 bumper with the foam stuck inside of it). My question is what is the best way to get my stock rebar to fit onto the m3 bumper. I have already started to shave down the foam bar with my dremel and it seems like its gonna take years to do as the dremel only can do so much at a time i was gonna shave this down and jb welb it to my rebar.... I am wanting to to just take the whole foam part out but then im left with a bumper cover and rebar and i dont (think) jb welding them togather would work or would it? . I know im gonna cut my rebar on both ends down a inch or so to get it flush with the fenders.
HAS ANYBODY DONE THIS? IM SURE SOMEONE HAS AND I JUST NEED SOME INPUT IM STARTED TO GET PISS3D HAHA.
M0ney = P0w3r "THEN" I = A G3nerat0r
SB_RavenE46 is offline   Reply With Quote
Old 02-18-2013, 01:17 AM   #619
tiag_$edan
My Ride: tiag $edan
Nice... Hmu if anyone has a m3 front kit in tiag for sale
tiag_$edan is offline   Reply With Quote
Old 02-18-2013, 03:06 PM   #620
hi its me alec
Not a good idea, you would be spending a lot of money to do a 'reverse retrofit' from OEM M3 bumper to Non-OEM/Non-M3 bumper. Get a used one on craigslist or the forum for a couple hundred bucks.
They should, as long as they're shorter. e36 M3 front endlinks are equivalent to the shorter ones that come with KW V2 coilovers, which is what I have in my car. Endlinks are very very similar between all the e46 3 series and e36 M3, plus probably e39s and more. The key is the length, they can't be longer than the e46 links or they'll hit the control arm. Shorter endlinks help the sway bars function better when the car is lowered, less preload.
You're using a dremel on the re-bar? Damn. That's a lot of work when a sawzall or cutoff wheel can zip it apart in a minute or two. Yeah you have to cut it down quite a bit and use glue if you stick with the non-M rebar.
