Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 04-09-2007, 11:02 PM   #141
magnusbaron
My Ride: BMW E46 and you ?
Yea thanks for that !
Chillin Chillin
magnusbaron is offline   Reply With Quote
Old 04-15-2007, 05:21 AM   #142
BlackOut330ci
My Ride: 330ci
I blew my shocks on my 330ci and can get m3 shocks/springs for really cheap just double checking to c if this will fit. I've read the post and it said it should but just need a 2nd answer thx.
BlackOut330ci is offline   Reply With Quote
Old 05-05-2007, 09:33 AM   #143
Venomzd330
My Ride: 330ci
Originally Posted by hi its me alec View Post
Since a lot of threads pop up about fitting OEM M3 parts on Non-M cars, I figured we might as well have a thread that explains everything. This will be a list, hopefully including part numbers, of everything you'll need to fit OEM M3 parts on a Non-M.
Front Bumper:
Difficulty: 4/10
DIY: Maybe.
Installation:
- Coupe: http://www.e46fanatics.com/howto/how...hp?howto_id=40
- Sedan: http://www.e46fanatics.com/howto/how...hp?howto_id=41
Part Numbers:
- Re-Bar: http://www.realoem.com/bmw/showparts...29&hg=51&fg=15
- Bumper: http://www.realoem.com/bmw/showparts...81&hg=51&fg=15
This will fit on okay, but will need some tinkering to fit flush with the stock non-m fenders. Without modification, the bumper sits about an inch and a half forward and the sides flare out an inch or so; on a sedan, it's a slightly bigger gap. To fix this, some people opt for the OEM CF reinforcement bar and stretch the sides in a little bit, while others simply shave down the stock bar to allow the bumper to sit farther back.
Safe Alternatives:
- OEM Mtech2 front bumper (available at your local BMW dealership)
- M3/ CSL replica bumper (available through many of the sponsors here at e46)
Front Fenders:
Difficulty: 5/10
DIY: If you're looking to save money, then a DIY would be nice.
Part Numbers:
FRONT LEFT 41357894337 $281.23
FRONT RIGHT 41357894338 $281.23
The OEM M3 Fenders will fit on nicely, but will be wider than the stock coupe front bumper. An M3-fitment front will fit perfectly flush with these.
Safe Alternatives:
- Racing Dynamics Tornado
Hood:
Difficulty: 4/10
DIY: Absolutely.
DOES NOT FIT SEDAN!
Part Number:
HOOD 41617894223 $558.00
Minor fender modification is needed for 100% fit. Most people do this by simply spacing the fenders out by using washers.
Safe Alternatives (for coupes/verts ONLY):
- Carbon Fiber (available from many aftermarket companies)
- Vorsteiner GTR
- Hartge-Style
Mirrors:
Difficulty: 2/10 (coupe/vert), 4/10 (sedan/wagon)
DIY: Yes.
Installation:
- Coupe: http://www.e46fanatics.com/howto/how...php?howto_id=6
- Sedan:
... Assembly: http://www.e46fanatics.com/howto/how...hp?howto_id=27
... Base Plate Modification: http://www.rogueengineering.com/Merc..._Code=E46M3MIR
Part Numbers:
RIGHT PRIMED EL.EXTER.HEATABLE MIRROR 51167893468 $232.13
LEFT PRIMED EL.EXTERIOR HEATABLE MIRROR 51167893597 $232.13
ACTUATOR LEFT 51167895273 $169.63
ACTUATOR RIGHT 51167895274 $169.63
MIRROR GLASS HEATED PLANE LEFT 51167157247 $46.59
ADAPTER LEAD, MIRROR HEATING 51167836442 $6.58
MIRROR GLASS HEATED CONVEX RIGHT 51167157244 $58.31
On coupes and convertibles, they're a direct bolt on. For sedans and wagons, the bases have to be modified slightly.
Safe Alternatives:
- M3 Replica Mirrors (M5-look) (available through sponsors)
- Hammann/Hagus (available through sponsors)
- AC-Schnitzer (available through sponsors)
- e36 M3-style (available on ebay)
- Hartge
Side Skirts:
Difficulty: 2/10
DIY: Yes.
Direct bolt on. No modifications needed. On sedans and tourings, the skirts will be a couple millimeters too long. No biggie though...
Safe Alternatives:
- Hammann GTR
- Hammann Competition
- OEM Mtech2
- AC-Schnitzer
- OEM Aero Kit (a.k.a. 'Mtech1')
Rear Quarter Panels/Fenders:
Difficulty: 9/10
DIY: NO!
Heavy modifications are needed for these to work. In short, a body shop will need to cut your existing quarter panels to smithereens and weld the M3 ones into place. This will require many hours of labor and lots and lots of money. This process is also irreversible. Only do this if you're absolutely certain that your pocket can take the hit.
(Not-so-safe) Alternatives:
- Custom widebody
Rear Bumper:
Difficulty: 6/10
DIY: Probably not.
Part Numbers:
- Re-Bar: http://www.realoem.com/bmw/showparts...06&hg=51&fg=15
- Bumper: http://www.realoem.com/bmw/showparts...19&hg=51&fg=15
This has only been tried a handfull of times, but this mod is usually accompanied by a widebody. Since there's such a difference between M and non-M rear fenders, this bumper is a good inch or two too wide. To fit this correctly, you'll either need to do some hardcore molding and reshaping of the bumper, or a custom widebody in the rear. If you can deal with the bumper flexing and creating numerous noticeable gaps, then I guess you could do it without modifying anything (and only stretching the sides of the bumper in). Again, this mod isn't highly recommended unless you're serious about modifying your car.
Safe Alternatives:
- Hammann GTR
- Mtech2
- OEM Aero Kit (a.k.a. Mtech1)
- Various rear addons
Trunk (including CSL trunks):
Difficulty: 3/10
DIY: Yes.
DOES NOT FIT SEDAN!
Part Numbers:
- M SPOILER REAR, PRIMED 51717893671 $139.50
- TRUNK LID 41627065260 $430.78
Some people (for whatever reason) want OEM trunks on their cars. The trunks are the exact same dimensions for M and non-M cars, therefore this is a direct bolt-on. No biggie.
Safe Alternatives:
- M3 Trunk Lip (yes, it fits fine)
- CSL Replica Trunks (Vorsteiner)
- CSL Addons (eh)
- Bimmain CSL-Style Addons (very nice looking IMO)
- ACS 3-Piece Race Wing
- ACS 3-Piece Trunk Spoiler
- ACS 1-Piece Trunk Spoiler
Muffler:
Difficulty: 4/10
DIY: No. (leave it to any reputable muffler shop)
Despite what many people think, this mod isn't very hard to do. Here's what you'll need to do:
- Either cut the spare tire well ($100ish) or get an OEM M3 one put on ($150ish) in order to allow room for the muffler box.
- Get a new rear bumper to accomodate the sexy, center-exiting, quad tailpipes.
- Go to a muffler shop and have them weld it on. Just the welding and bracketry shouldn't cost more than $100 in total.
Safe Alternatives:
- Custom quad exhausts
- Remus/Eisenmann quad exhausts
Wheels/Tires:
Difficulty: 4/10
DIY: Sure.
To get a set of four to fit, you will need to do some hardcore fender rolling and buy some smaller tires. To ensure proper fitment and to avoid a headache, I'd probably just find a set of four front wheels. These will fit just fine with no rubbing or modifications or anything.
Safe Alternatives:
- Anything
Gauges/Instrument Cluster:
Difficulty: ?/10
DIY: ?
Part Number: INSTRUMENTS COMBINATION UNCODED MPH 62117837972 $504.43
This has not been successfully done yet. People have plugged these in, and here are the results:
WORKS 100%:
- MPH
- RPM
- OnBoard Computer Functions
- Lights
- Indicators
- Engine Temp.
- Gas Info
DOES NOT WORK:
- Oil Temp. Needle
- RPM Warmup Lights
- Little orange ODO Tamper Light comes on...which is bad
This is a DIRECT PLUG AND PLAY, but will not work 100%. You be the judge...
Safe Alternatives:
- Bimmian M3-Style Gauges
- UUC Whiteface Gauges
- Silver Gauge Rings w/ Red Sharpie'd Needles
Steering Wheel:
Difficulty: 3/10
DIY: Yes
Part Number: M SPORTS STEER.-WHEEL, AIRBAG, LEATHER, BICOLOR 32348022322 $700.29
As long as you have the round airbag, this will be a direct bolt-on. The airbag, horn, radio buttons, cruise control, and everything else will work. Yay!!
More to be added later....
lots of good info,i just wanna let you know that it is possible to fit a m3 on non m3 car,i did on mm 330ci,pain in hte butt but its possible,maybe you seen a laguna seca blue bmw with chrome 19's,had you use some parts from my old bumper fo form it,heat gun andlots of clamps i did it,so just wanna let you know
Venomzd330 is offline   Reply With Quote
Old 05-06-2007, 09:35 PM   #144
LeftCoastBias
My Ride: alpine white hotness
wait, what the **** did you say?
-JP
LeftCoastBias is offline   Reply With Quote
Old 05-06-2007, 11:25 PM   #145
Venomzd330
My Ride: 330ci
lol sorry i forgot to put the word " rear bumper"
Old 05-15-2007, 11:13 PM   #146
mike greco
My Ride: M3
awesome thread
mike greco is offline   Reply With Quote
Old 05-18-2007, 11:40 PM   #147
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
so just making sure. it is okay to fit an oem front bumper to a sedan or touring?
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW service at the dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro dealership.
Eurobahn BMW is offline   Reply With Quote
Old 05-19-2007, 12:16 AM   #148
Eurobahn BMW
Eurobahn BMW
bump for answer
Old 05-26-2007, 01:11 PM   #149
homervins
My Ride: 2004 325xi
I'm a NooB and this is definitely very helpful. Thanks!
homervins is offline   Reply With Quote
Old 05-26-2007, 01:21 PM   #150
jlcool007
My Ride: E46 330ci Smoked Out
im still trying to find a diy for the fenders... as my shop says it won't work...f*cking retards
at least a pic of where to shim w/ washers would be nice
thanks much in advanced
-jl
_FOR SALE_ (below)
***staggered style #68 330ci spt. pgk. wheels w/ PS2's***
***full set amber 2001 330ci lights***
***99-01 coupe smoked corners***
Jason Le Blanc's Facebook profile
jlcool007 is offline   Reply With Quote
Old 06-01-2007, 02:19 AM   #151
mike greco
My Ride: M3
Awesome Thread Very Useful
Old 06-04-2007, 10:30 PM   #152
Pocketfisherman
My Ride: 330ci & 325XI
M3 Sideskirts on my 2003 330CI
Hello,
I am a newbie here but I have been driving BMWs for about 10 years. I am true BMW nut. Between my other half and I we have 3 e46 models. 1999 323i a 2004 325xi and my new toy a mint 2003 330ci that I am doing some tasteful upgrades with.
My question is regarding the sideskirts for the M3. I understand that the skirts will fit but to they just clip on? When buying the M3 skirts what year M3 E46 part should I ask for? Should I ask for 2003 m3 skirts? what ones look the best? I have added the trunk lip spoiler and I am just updating the wheels and tires this week.
Thanks,
Shawn
Pocketfisherman is offline   Reply With Quote
Old 06-05-2007, 12:05 AM   #153
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by Pocketfisherman View Post
Hello,
Thanks,
Shawn
They just clip on. I can't think of why any E46 M3 year wouldn't fit. You might need a few extra clips, the ones at the rear of the M3 sideskirts aren't on the regular Coupes.
Old 06-07-2007, 08:33 AM   #154
chrisbostonusmc
Banned
My Ride: audi e46 being sold!
I just talked to my body shop and they told me that if they put that M3 front bumper on, then the air ducts that go to my brakes wont fit or go in??
chrisbostonusmc is offline   Reply With Quote
Old 06-27-2007, 05:31 PM   #155
miamiblair
My Ride: 2001 330Ci, 2004 M3
Great site for E46 M3 installs on non-M cars: http://www.importmodifications.com/bmwe46.html
The site used to be a members only site but it is completely free now.
** sig removed by tim330i **
miamiblair is offline   Reply With Quote
Old 07-03-2007, 09:14 AM   #156
chrisbostonusmc
Banned
So my car has been in the body shop for a month now. They are putting on M3 fenders and an M3 front bumper. Heres the pics. It was pretty much all bolt right on. Now I have a question. This is where Im confused a bit. I wanna drop some 19's on my car now. probably M3 rims. Now that my fender has been modified can I run these on my car. This wasnt a cheap job either
ID:	233387   Click image for larger version
ID:	233388   Click image for larger version
Name:	front bumper.JPG
ID:	233389   Click image for larger version
Old 07-03-2007, 09:19 AM   #157
zhan
I screwed up and can't post
My Ride: 330xi
Send a message via AIM to zhan
u got a 323 not a 332
zhan is offline   Reply With Quote
Old 07-03-2007, 09:27 AM   #158
rohde88
rohde88's Avatar
My Ride: S2000
did you know he didn't swap a 3.2L in?
-Ron
rohde88 is offline   Reply With Quote
Old 07-03-2007, 09:29 AM   #159
chrisbostonusmc
Banned
actually i put the 850csi v12 in it. but i had to get rid of my back seats
Old 07-03-2007, 05:12 PM   #160
Alex323Ci
NO.
I thought you were Banned.
I remember distinctly you being the one calling everyone names and saying how you were going to beat Fanatics faces in.
