Sponsored by The Tire Rack
Old 12-13-2006, 03:45 PM   #1
msandalis
My Ride: 2003 BMW 330i
Better tires front or back
I have 4 Winter tires but two seem to better than two others. Do I put the better ones in the front or back?
Halifax, Canada
2003 330i
msandalis is offline   Reply With Quote
Old 12-13-2006, 11:24 PM   #2
doubleloseven
Slave of Barbri
My Ride: 2002 330i
back, you want traction on your drive wheels
doubleloseven is offline   Reply With Quote
Old 12-14-2006, 04:36 PM   #3
StylGryCi
My Ride: looks fast but isn't
+1^^^^
*back on stock 17s, so sad.
StylGryCi is offline   Reply With Quote
Old 12-15-2006, 03:32 PM   #4
mf9point8
My Ride: Mother ****er
^^^^+1
2002 325i TiAg.
mf9point8 is offline   Reply With Quote
Old 12-16-2006, 11:04 AM   #5
msandalis
Not sure what the last two responses are. The mechanic suggested that better on the front for better steering. I am starting to doubt this guy.........
Halifax, Canada
2003 330i
Old 12-16-2006, 05:32 PM   #6
oserx
My Ride: 320d
i think you should put the better ones in the front... better handling...
if u put them in the back.... better traction .... but not good handling...
oserx is offline   Reply With Quote
Old 12-16-2006, 06:08 PM   #7
Lucas
LinuxGeek
Lucas's Avatar
My Ride: 328CI
Send a message via ICQ to Lucas
With better tires in the front you are able to reduce stopping distance.
"Carputer" project progress meter [Completed]
Lucas is offline   Reply With Quote
Old 12-16-2006, 06:16 PM   #8
deafboy
My Ride: 2000 323Ci
why not just buy two more good ones and call it good?
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 12-16-2006, 06:47 PM   #9
nevin
My Ride: 08 AA m3
I'd go with back so i can have better traction in the snow/ice. If you have no traction then you may end up ditch if you can steer or not, not easy to steer on ice.
But then again the mechanic would know better then me
I suck at speling!
Originally Posted by Bim Growl View Post
Get out of the pool. It's adult swim time, and you are in way over your head...
nevin is offline   Reply With Quote
Old 12-16-2006, 08:07 PM   #10
EIAlfonso
My Ride: 2011 535xi M Sport
I would go with the fronts just because their primary purpose is to steer the car.
EIAlfonso is offline   Reply With Quote
Old 12-16-2006, 08:53 PM   #11
Jojo@DPE
www.dpe-wheels.com
Jojo@DPE's Avatar
My Ride: is on 20s, 22s, 24s
always put the good tires in the front as your steering is controlled there. furthermore, in event of a blow out or something, your rear will just fishtail with the bad tires. if you have them in the front, you could lose control in event the bad tires blow out.
since it is winter and there is snow etc in your area, you may lose steering in ice or snow with the bad tires up front.
to be safe, you should get all good tires and keep the bad ones for the summer.
Jojo@DPE is offline   Reply With Quote
Old 12-17-2006, 12:04 AM   #12
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
Put them on the back. This is from personal experience. That back needs to stay planted.
MysticBlau330Ci is offline   Reply With Quote
Old 12-17-2006, 12:39 AM   #13
nevin
My Ride: 08 AA m3
thats what i'm sayin but i think we're gettin out numbered.
I suck at speling!
Old 12-18-2006, 11:30 AM   #14
DoubleApexCa
My Ride: A car
Put them on the back... For a RWD car you want them on the back for traction. Putting the more worn tires on the back end will increase the tendency of your car wanting to swap ends when the roads get slippery.
In any event... even if you had a FWD, you'd still want to put them on the back. ALthough for a FWD car the rear wheels are doing different work, but the principle is the same.
Cheers
Glenn
DoubleApexCa is offline   Reply With Quote
Old 12-18-2006, 11:54 AM   #15
msandalis
Thanks everyone great feedback. The tires are only about 10%-15% max in the difference and more of a curiosity than anything else.
But when I think about it, when I was driving (albiet in all seasons) a couple of weeks ago it was the back that was moving around the most and those tires are the same all around.
Thanks again,
Michael
Halifax, Canada
2003 330i
