Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 4.94 average. Display Modes
Old 04-19-2008, 08:54 AM   #61
Spidey12
My Ride: 2000 328i 4DR
Originally Posted by ca1242 View Post
Don't you guys have to jump start people in the er or wire pacemakers and stuff?
Diagram above shows pretty much what you have to do. If you want to make your life easier, buy a kit from someone like Umnitza or Jlevi. Their kits come with all the parts you need and instructions with details and pictures.
We sure do, but we're requured to understand the effect of the shock on the human body in detail down to the microscopic level...that alone is enough it would be inhuman to also make us understand how that shock is created and how it is wired. there are specialists for that.
Spidey12 is offline   Reply With Quote
Old 04-19-2008, 06:49 PM   #62
ca1242
My Ride: 2003 330i
dude, I was kidding!
Old 04-22-2008, 12:55 AM   #63
Shayn
My Ride: 325ci
what is the SPST button ? is that another relay ?
Shayn is offline   Reply With Quote
Old 04-22-2008, 06:33 AM   #64
ca1242
My Ride: 2003 330i
On/off button. Could be a push button or toggle. SPST just means it has a single set of contacts.
Old 04-24-2008, 12:42 AM   #65
Shayn
My Ride: 325ci
Thanks, do i really need that button to successfully install the angels eyes and remote start?
Old 04-24-2008, 06:54 AM   #66
ca1242
My Ride: 2003 330i
No. Purpose of the switch is to be able to turn them off.
Old 04-27-2008, 04:43 PM   #67
mikethebomb415
My Ride: 2002 BMW M3
i have the angel eyes and i have them all hooked up... don't know what i did wrong but when i hit unlock they don't come on... any help
mikethebomb415 is offline   Reply With Quote
Old 05-01-2008, 01:27 PM   #68
*James*
My Ride: hates being dirty.
EDIT: Dont worry now, silly idea..
James
*James* is offline   Reply With Quote
Old 05-24-2008, 01:59 PM   #69
kikokbg
My Ride: e46 coupe
Hi folks, I'm wondering is there a way to use a remote function only when the unlock button is hit? I mean I don't like to have angel eyes lights on every time I open my door. I think there will be some way to wire them to the lock system of the car and only when the unlock key is hit to have them on, but I'm not sure how it will be made! Any Idea? Is it possible?
kikokbg is offline   Reply With Quote
Old 05-24-2008, 05:39 PM   #70
ca1242
My Ride: 2003 330i
Anything can be done with a little ingenuity. You can use a timer and relay. You can use something like a PAC-TR& timer, set it to be triggered by the unlock and program whatever delay you want.
Old 05-25-2008, 03:25 AM   #71
kikokbg
My Ride: e46 coupe
Yes, thanks a lot , that is a great idea! If I have understand right that "thing" will receive signal from the unlock like the footlights receive it right? Where can I find that thing? Is it expensive? Thank you man. Can you make me a simple diagram of it's wiring to the angel eyes?
Old 05-25-2008, 03:50 AM   #72
kikokbg
My Ride: e46 coupe
What kind of relay con I use instead?
Old 05-25-2008, 10:36 AM   #73
ca1242
My Ride: 2003 330i
For the TR-7, check www.pac-audio.com
As far as a relay, any single-pole (automotive-type) relay will work.
You need both the timer and relay.
Old 09-08-2008, 05:31 PM   #74
//TRD power
My Ride: 3.0 | 200hp | 214trq
what about if you dont have footwell lights? only ceiling lights. is there a wire to tap into in the a pillar? if so, what colour is it?
//TRD power is offline   Reply With Quote
Old 09-09-2008, 07:58 AM   #75
ca1242
My Ride: 2003 330i
Wires should still be there. If not, you can go to the BCM or overhead lights or c-pillar lights.
Old 09-09-2008, 01:13 PM   #76
//TRD power
whats bcm? and for the overhead lights do i have to go all the way up there or is thre a wire in the a-pillar that runs to it, shud be right or how else is the power supposed to get there. if you kno the colour of the wire that would be much appreciated as i dont want to tap into the wrong wire. thanks
Old 09-09-2008, 01:31 PM   #77
ca1242
My Ride: 2003 330i
Body control module, located behind the glove box.
I believe the wire is blue/red, but I could be wrong.
As I said before, although you might not have under-dash lights, the wires should still be there (black plug with two wires).
If you find a wire you suspect is the correct one, you could verify with a voltmeter or LED test light. If you don't want to go through the trouble of looking for it, just run it to a working light.
Old 09-09-2008, 01:33 PM   #78
chop999i999
My Ride: e46 M3
Hey guys, I just installed new orion V2 angels eyes no ballasts. I read the whole thread and see you guys are fusing the trigger wires, correct? Is this nesesary? I am going to connect one trigger to the light under the glove box and the other i connected to the fog light. I am thinking I am going to connect to the assessory wire in the ecu box with a switch in between instead of the fog light. Would this work? so it would be
{Harness}---Trigger---[Switch]---ECU---
Carbon Black/Black. Mods: 19" iforged swifts, Borla Catback, JVT Headers, Depo smoke corners, Orion V2 angel eyes, Viper 2way alarm, Full Alpine speakers, sub in custom box and double din Alpine DVD with mybimmer.net bezel, H&R RSS Coilovers, Vorsteiner Double sided carbon fiber hood. More to come...
chop999i999 is offline   Reply With Quote
Old 09-09-2008, 01:58 PM   #79
ca1242
My Ride: 2003 330i
So you are going to have 3 sources? light, ecu, fog lights? Can be done, but you need to isolate all 3 to avoid feedback from one source to another.
Reason for fusing depends. For example, I don't normally fuse the line coming from the done lights. Power is current-limited by the LCM (and LCM is fused), so a short in this wire would not cause any issues.
Fog light power is already protected by a fuse, but if you use a small gauge wire for the DDEs, then if the wire is shorted, it would melt before the fuse pops.
Actually, the "ECU" wire is not power to the ECU. It provides power to the radiator fan. I ALWAYS add a fuse in this wire for two reasons, one to protect a smaller gauge wire from catching fire, but also for redundancy. If the wire shorts out and is large enough that the fuse will protect it, you would loose your fan and the car would overheat.
Old 09-09-2008, 02:47 PM   #80
chop999i999
My Ride: e46 M3
No fog connection, Just light under glove and assesory light in ecu box(see pic). So I should definitly fuse the trigger wire going from ecu to switch? 10amp inline correct? When I hooked up my angel eyes I went to radio shack and the only wire they had was solid 18g not the one with many small wires in them, is that ok? I used this wire to extend trigger wire and soldered connections.
