Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 4.94 average. Display Modes
Old 09-09-2008, 03:03 PM   #81
ca1242
My Ride: 2003 330i
You can use diodes and do what is shown in post #22 or use a relay and do what is shown in post #13. If you go with a relay, instead of ignition source, use the ecu wire for both the relay trigger and relay power (relay terminals 87 and 85 tied together).
No fuse on light circuit, but need a fuse on ECU wire. I always use 3A fuses.
You can use 18 gauge, but make sure you protect it with the right size fuse (there are tables online that can give you current ratings vs. wire gauge vs. distance, but can tell you from experience that 3A is perfectly safe for what you are doing). I wouldn't use solid core wire. Get stranded wire. You can get a small spool of "hook up" wire from any auto parts store or local stereo shop.
Old 09-09-2008, 05:14 PM   #82
//TRD power
My Ride: 3.0 | 200hp | 214trq
Originally Posted by ca1242 View Post
Body control module, located behind the glove box.
I believe the wire is blue/red, but I could be wrong.
As I said before, although you might not have under-dash lights, the wires should still be there (black plug with two wires).
If you find a wire you suspect is the correct one, you could verify with a voltmeter or LED test light. If you don't want to go through the trouble of looking for it, just run it to a working light.
so i would have to take off the pillar and then how do i remove the roof cloth thing where the overhead lights are? wouldn't i find that same wire running to the overhead lights in the pillar somewhere because the wire can only go through there.
//TRD power is offline   Reply With Quote
Old 09-10-2008, 02:56 AM   #83
Ashhong
My Ride: 2002 325i
using that logic, couldnt you tap the wire in the fuse box and tap it there?
Ashhong is offline   Reply With Quote
Old 09-14-2008, 07:37 PM   #84
//TRD power
okay so my car doesnt have any footwell lights wire hanging around, what else can I tap my remote trigger into? wire colours and locations will be greatly appreciated.
Old 09-15-2008, 01:18 AM   #85
Ashhong
My Ride: 2002 325i
http://forums.bimmerforums.com/forum...d.php?t=987563
Old 09-15-2008, 08:03 PM   #86
//TRD power
Originally Posted by Ashhong View Post
You are a good man.
Old 09-15-2008, 11:38 PM   #87
Ashhong
My Ride: 2002 325i
i do what i can.
Old 09-16-2008, 01:07 PM   #88
//TRD power
quick question:
i noticed on the bimmer forums that someone mentioned using add a circuit to draw power from the interior lights fuse (fuse #49 - 5 amps)
ive used add a circuits before and they are great to avoid splicing and such but my question is, if i tap into this fuse will i get the fade in/fade out feature as tapping straight into the ceiling lights? ive noticed when i pull this fuse the interior lights + glovebox lights go out, putting it back fades interior lights on and glovebox light immediately on. does the interior lights have a seperate dimmer? glovebox light also has fuse 52 so i dont kno if that contributes to the immediate on?
Old 09-17-2008, 11:00 AM   #89
ca1242
My Ride: 2003 330i
Originally Posted by skittl3s View Post
quick question:
I don't like add-a-fuse. The cheap ones end up damaging fuse holders and end up causing trouble. Best thing is to splice and solder your connections.
The actual interior lights are controlled directly by the LCM. The LCM does the fade-in/out. If you tap into a fuse that powers the LCM, you will only get constant power.
Old 09-24-2008, 08:03 PM   #90
//TRD power
okay so big problem... the option of routing through the pillar to the ceiling lights is no longer available.... someone rounded the torx 15 heads
so is there a wire or anything under the glovebox that i can tap into? i tried the glovebox light itself but it stays on until i lock the car or leave it untouched for 16 mins...
Old 09-25-2008, 03:29 AM   #91
Atlas
My Ride: 320i
Send a message via ICQ to Atlas
How about driver's side? Or perhaps even the rear interior lights?
Atlas is offline   Reply With Quote
Old 09-25-2008, 06:16 AM   #92
//TRD power
that would require a lot of routing, couldnt i tap into one of the red/blue wires in the glovebox area? there a few with different sizes
Old 09-25-2008, 06:46 AM   #93
ca1242
My Ride: 2003 330i
You don't have to take the trim out, just tuck it in uder the edges.
Old 09-25-2008, 01:11 PM   #94
rickard123456
My Ride: 320i Touring
Can you do that whit the fogs to????? So both Angel Eyes and Fog lights will turn on or can it only be done whith Angel Eyes
rickard123456 is offline   Reply With Quote
Old 09-25-2008, 09:38 PM   #95
//TRD power
but i cant find the way down below the glovebox with the wire... is there a sure way of getting that wire up there?
Old 12-08-2008, 07:30 PM   #96
juslookin
My Ride: 05 330ci ZHP
if you wire the AE's up to your corner lights and do a corner delete would they still light up?
juslookin is offline   Reply With Quote
Old 12-09-2008, 08:50 AM   #97
ca1242
My Ride: 2003 330i
You can wire up the lights to whatever you want. Only issue about the corner delete mod is putting too much load on the side marker wires. You could damage the LCM if you overload it. If you do it, use led bulbs, or add a relay.
Old 01-20-2009, 12:10 PM   #98
francie
My Ride: m3
Originally Posted by 320de46m47 View Post
Thanks to Highvoltage
so just for explanation .. when the footwell lights are activated via the key power is supplied via 87a across the relay to 30 and then to the angel eyes. when the ignition is turned on (ie power supplied to pin 85) the coil in the relay is activated which pulls up the bar away from 87a to connect with 87 instead. the footwell supply is broken and power is supplied to the angel eyes via 87 and 30. the switch of course makes or breaks the circuit after the relay.
Ive wired mine up like this but when i put the fuse in the interior lights stay on, any help would be much apprecaited. thanks
francie is offline   Reply With Quote
Old 01-20-2009, 12:22 PM   #99
ca1242
My Ride: 2003 330i
Check the relay connections. Looks like you have the battery power tied to the lights.
Old 01-20-2009, 12:33 PM   #100
francie
My Ride: m3
thanks for replying, Ive swapped them round (no joy), the way i had them wired was(87s) the main power is going to the middle and the trigger from the footwell lighting to the other 87 but no joy. would i have the wrong relay? its a 5 prong.
