Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 12-30-2006, 04:10 PM   #1
smarra325
My Ride: 2002 325I
What Is THE ATF Oil Only Cap For ?
Under the hood of my 2003 325i with steptronic transmission, there is a cap that says ATF oil only. What is it for? I am reading that the transmission fluid needs to be checked and changed at the transmission. ??????
smarra325 is offline   Reply With Quote
Old 12-30-2006, 04:44 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
Read your manual to be sure. But that sounds like the Power Steering Fluid reservoir.
Old 12-30-2006, 05:23 PM   #3
ThE GrEAt OnE
My Ride: has a 3 pointed star
yea its the power steering reservoir
The 2 mods I did on my e46:
H&R Cupkit
UUC Stainless Steel Brake Lines
ThE GrEAt OnE is offline   Reply With Quote
Old 12-30-2006, 05:35 PM   #4
Commander FAT
Network Analyst
My Ride: 2002 330Ci
The ATF Oil Only resevoir is for ATF oil only. Duh.
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 12-30-2006, 05:35 PM   #5
smarra325
My Ride: 2002 325I
ATF fluid for the p[ower steering???
Does that make sense? or is it a reservoir for the transmission?
Old 12-30-2006, 05:38 PM   #6
smarra325
My Ride: 2002 325I
ATF Fluid?
Why not power steering fluid?
Old 12-30-2006, 05:53 PM   #7
GIO_21
My Ride: Active HKS Blown
Send a message via AIM to GIO_21
thats for the power steering fluid...the tranny has a sticker on it that is for the ATF in the tranny...same fluid on both but under the hood refers to the power steering
GIO_21 is offline   Reply With Quote
Old 12-30-2006, 06:04 PM   #8
smarra325
My Ride: 2002 325I
Thanks for clearing up my confusion. I couldn't figure out why ATF fluid is used for power steering fluid. I am all set now. Thanks again.
Old 12-30-2006, 06:20 PM   #9
Alex323Ci
it's a different grade hydraulic oil. they just want you putting in the normal type of power steering fluid in, our bmw's take the same automatic tranny fluid grade. although you can use Redline's synthetic brand.
Old 02-20-2007, 03:47 PM   #10
beefy6969
My Ride: 2000 323CI TiAg
I accidently put 1/2 quart of motor oil in here. Is that Ok? I must have lost my mind when I was checking my oil. Should I be worried?
SP,PP,ICE,VGA LCD,DvD,
P46 w/HID, FOG HID (6000K), Clears,
Brembo Rotors, Replica CF GruppeM Intake, ACS Pedals, OEM 19" M3 rims
beefy6969 is offline   Reply With Quote
Old 02-20-2007, 04:36 PM   #11
shall36
My Ride: 325ci
Yes.
You need to drain the system, including removing the lines from the rack and moving the rack back and forth to pump out all old fluid. Refill and burp the system. Run it for a little and repeat. I'm surprised the unit is still working properly (if it is).
shall36 is offline   Reply With Quote
Old 02-20-2007, 05:05 PM   #12
beefy6969
Originally Posted by shall36 View Post
Yes.
Thanks for the info shall36, I will go ahead and take it to a mechanic.
Old 02-20-2007, 05:13 PM   #13
GIO_21
yes take it to mechanic asap motor oil is alot thicker than the power steering fluid and will damage the system....the power steering lines might be clogged from the thick oil which will be a good thing until its drained
Old 02-20-2007, 06:50 PM   #14
D.Hendrickson
My Ride: 2001 325i (sold)
well they probably won't be clogged just because it's there, it's diluted into the ATF. they could clog because of a chemical reaction with the ATF. not likely though.
what is more likely is a chemical reaction with the rubber seals in the PS system. seals are made to work with a specific fluid. you've just introduced another...
dave
D.Hendrickson is offline   Reply With Quote
Old 05-03-2010, 04:48 AM   #15
lionblade
My Ride: 320d
hi guys. Im new to this forum. I have also blundered in this area. I have a 320d msport bmw. 2003. And i have put engine oil in the atf part. However the amount i put in was about a capful as it was alredy topped up. Is this enough to be concerned about or will it still be ok?
lionblade is offline   Reply With Quote
Old 05-03-2010, 05:01 AM   #16
paraklas
My Ride: ESS TS2 320ci
I'd just do a flush, why even leave the slightest possibility to create problems? PS pumps are not cheap!!!
Old 05-03-2010, 05:54 AM   #17
lionblade
My Ride: 320d
ok thnks
Old 05-03-2010, 06:33 AM   #18
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Lion,
Para is almost always right...and I'm sure he is this time too...but, if it's not too late, meaning you haven't driven the car or tried the steering with car on, then you could just use a turkey baster (don't know what it's called in the UK) and remove the stuff in the reservoir and replace with what's called for in your manual (doublecheck bmw na online to be sure there isn't a new fluid)--I use Dex III. That means car has not been driven and you use another car to get the proper fluid for PS system.
Anyway, that'd probably be a decent alternative if you otherwise need to drive this car soon...but once you drive it, you just need to flush and bleed...think everyone here just removes a hose from PS pump...honestly not sure which one, but check the diys...many around.
Even if it'd actually do little harm, it's not worth the risk for the 1 hour of work it'd take to be sure.
HTH
Doug
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 05-03-2010, 06:42 AM   #19
Kringkily
My Ride: e46 m3 convertible
id flush it why risk having it in there since the motor oil is probably thicker and sunk down beneath the atf fluid...
Kringkily is offline   Reply With Quote
Old 05-03-2010, 07:35 AM   #20
nk_zhp
My Ride: ZHP / E30 M3
Important: Always use the fluid type noted on the power steering reservoir cap. Steering racks designed to run on the pentasin fluids (usually green sticker that says 11S or something to that effect) will get damaged with ATF and vice versa. The fluid type is key to making sure the steering component seals function properly.
nk_zhp is offline   Reply With Quote
