Sponsored by The Tire Rack
Old 01-01-2007, 12:31 PM   #1
ssc5174
My Ride: 2001 330xi
New Tires/Wheels - Do I need to do anything else?
I just made the following changes to my 2001 330xi:
Wheels - changed from 17" to 18"
Tires - changed from 205/55/17's to 225/40/18's
A couple of people have recently asked me if I need to make "any changes to the computer?". I guess the theory goes that BMW sets the car up to run on 17" wheels/tires. Does anyone know if I need to make any other adjustments for the car to run at max. performance?
ssc5174 is offline   Reply With Quote
Old 01-01-2007, 01:21 PM   #2
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
make sure you get some Tire Pressure Sensors for the new wheels.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 01-01-2007, 01:58 PM   #3
dme330i
My Ride: e90 330i and 330CIC
No.
Current Rides
From the Past . . .
dme330i is offline   Reply With Quote
Old 01-01-2007, 03:24 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Nope you are ready to go. You keep the overall wheel diameter the same so there will be no issues
Old 01-01-2007, 03:30 PM   #5
BlackChrome
No more E46 :(
BlackChrome's Avatar
My Ride: 2001 3.0L Ci
Nope, you are all set.
Unless your factory wheels come with them, you won't need them.
BlackChrome is offline   Reply With Quote
Old 01-01-2007, 05:43 PM   #6
ssc5174
My Ride: 2001 330xi
If I moved from 17" to 18" wheels doesn't that mean I've changed wheel diameter?
Old 01-01-2007, 06:47 PM   #7
deafboy
My Ride: 2000 323Ci
well yes, by mm...but nothing significant... the amount gained by the larger wheel is corrected by the amount taken away from the tire...
note the sidewall is smaller on the new setup compared to that of the old setup.
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 01-01-2007, 06:50 PM   #8
BlackChrome
No more E46 :(
Wheels, yes.
Tires, not exactly.
2001 330Xi should have 205/50/17 as standard factory tire size. Not sure why you have 205/55/17...
Diameters:
205/55/17 = 25.9 inch
205/50/17 = 25.1 inch
225/40/18 = 25.1 inch
As you can see, the 18-inch set up has the same diameter as the factory. Your current tire size (if it wasn't a typo) is taller than factory.
Old 01-02-2007, 08:30 AM   #9
ssc5174
My Ride: 2001 330xi
Originally Posted by BlackChrome View Post
Wheels, yes.
Tires, not exactly.
Diameters:
yep, a typo...I had the origional factory tires on. Thanks for all of your help!!
