Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 01-01-2007, 08:19 PM   #1
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
BMW e46 amp wiring with pictures
just had them on my computer from my install... and i know some people would like to do this as easy and straight forward as possible. just thought id share
hope it helps
REMOTE
RCA'S TO LINE OUT CONVERTER LOCATED ON MY REAR RIGHT SPEAKER
POWER RIGHT ABOVE THE BATTERY IN THE TRUNK
GROUND of course there are other options.
BreakMyWallet is offline   Reply With Quote
Old 01-01-2007, 10:45 PM   #2
jade46
jade46's Avatar
My Ride: 2003 M3,2006 Cat
NIce thanks
jade46 is offline   Reply With Quote
Old 01-02-2007, 05:00 AM   #3
mharv
My Ride: 318 ci sport convert
Did u use only one speaker connection for pos and neg... (right speaker)
to the LOC for both channels on the input side of the amp for right and left; do you not need to use the left speaker signal pos and neg aswell on the car then to the LOC?? or did you use a rca 1 male to 2 female Y splitter from the right speaker to the inputs on the amp for both....
As i would like to try this for a ed 9.4 amp as it only has rca inputs A B C D channels.... would a Y splitter work...
Your input greatly appreciated or anyone elses ....
mharv is offline   Reply With Quote
Old 01-03-2007, 03:50 PM   #4
BreakMyWallet
only came off of the right speaker.
Old 01-22-2007, 11:16 PM   #5
BreakMyWallet
bump for anyone that hasnt seen it
Old 01-25-2007, 07:36 PM   #6
engineering46
My Ride: e46
does it matter if the car has hk or just hi-fi.
engineering46 is offline   Reply With Quote
Old 01-26-2007, 02:35 AM   #7
BreakMyWallet
dont think it matters
Old 01-26-2007, 09:16 AM   #8
Halston@BSW
My Ride: E30 X5 TJ
Everything looks good. However I would recommend changing from the "T" connections that you are using. They are notoriously poor when used on BMWs. When I worked at two different shops I fixed 25 sets of "flickering/broken" Angel Eyes and HID systems because companies supplied those type of connectors with their installation kits.
Just my opinion
Halston Pitman
rhp@bavsound.com | ext. 104
BSW | Audio Solutions for YOUR BMW
www.bavsound.com | 404-963-8857
iPod Integration | Plug & Play Speakers | Subwoofer Solutions | Satellite Radio | HD Radio | Bluetooth
Halston@BSW is offline   Reply With Quote
Old 01-26-2007, 09:58 AM   #9
Tknojnky
My Ride: 99 323i, K1200S, R71
Did you tap the speaker wires before or after the factory amp? You are only going to get marginal performance if you tapped them after the factory amp. I am dealing with that right now
Mods: H&R Cup Kit, TMS RSMs, Edge Motorworks RTAB shims, UUC reinforced transmission mounts, 3.46 Rear Diff, Brembo x-drilled rotors, TMS SS brake lines and caliper bushings, UUC TSE3 Exhaust, ECIS CAI, Shark Injector, HID Projector46s w/Predator Chromium + remote kit, Smoked turn signals, OEM alarm, Custom iPod hookup, 18" CSLs w/Goodyear Eagle F1 DS-G3s.
Tknojnky is offline   Reply With Quote
Old 01-26-2007, 03:07 PM   #10
BreakMyWallet
Just my opinion
any other suggestions? im going to put my system back in the day i get my car.. maybe cut/solder?
hmm.. which one is before and which is after? lol.. i tapped them literally right off of the speaker. i took the back speakers out to get some air in the cabin
i dont think i was suffering any performance because my 2 alpines absolutely pounded.. when they were both wired at 4 ohms.
i just wired em down to 2ohm and hooked them up bridged to the amp.. so hopefully it will be looooud 1000rms @ 4 ohms bridged
anyone else have any knowledge with this? any alternatives? i sold my pop out screen so i cant run the rca's straight to the brain
Old 02-07-2007, 07:30 PM   #11
spoonboi
My Ride: 328i CI Coupe
Hi,
Can You give me more details about where you got your remote signal? I'm doing the same but cant tell from the photo.
TX
spoonboi is offline   Reply With Quote
Old 02-07-2007, 11:54 PM   #12
BreakMyWallet
try and get a multimeter and check for remote power.. theres a couple white wires.. its one of them.
Old 02-08-2007, 10:16 AM   #13
Halston@BSW
My Ride: E30 X5 TJ
I would definitely cut/solder or butt connectors would still be better. Not the best but still better.
The "t"s are not terrible on most cars. But BMW uses thick insulation and sometimes you are just barely touching the wires inside and as you hit bumps or over time it just stops working.
Let me know if you need any other help!
Halston Pitman
Old 02-08-2007, 01:45 PM   #14
mharv
Spoonboi it depends if you have Hifi or HK in your setup come with amps... or standard audio have no amps... if so you will have to use the oem head unit
or if you have standard audio like me with sat nav the bm54 radio plug in the boot has the all the wires to utilise.....
Old 02-08-2007, 03:34 PM   #15
BreakMyWallet
i didnt have hk
Old 02-08-2007, 04:16 PM   #16
Halston@BSW
My Ride: E30 X5 TJ
For you this is true. For BreakMyWallet this is not true.
In the US there are two audio system:
Standard - 10 speaker with amplifier
Harmon Kardon - 12 speaker with HK amplifier and two 6x9 "subwoofers"
Both have a factory amplifier.
Anywhere outside the US there are three audio systems:
Standard - 6 speakers no amplifier
"HiFi" AKA US standard - 10 speaker with amplifier
The Euro Standard is run off the factory head unit and does not have a factory amplifier. This setup is not available in the United States.
Halston Pitman
Old 02-09-2007, 06:35 AM   #17
mharv
Spot on Halston that is the case for us Europhiles...
Old 03-01-2007, 07:24 AM   #18
birdsley14
My Ride: 2003 325i
hope it helps
REMOTE
Am I looking at this wrong or what, where are the pics?
birdsley14 is offline   Reply With Quote
Old 03-01-2007, 02:01 PM   #19
BreakMyWallet
pics are still showin up for me
Old 07-01-2008, 06:00 PM   #20
hexadecim8
My Ride: '04 ///M3
Post resurrection!!!!
For HK system..... where do you get 12 speakers? You must be talking about the e36. 10 total in e46 w/ HK.
For OP,
Hey bro, did you have any issues running speaker line-outs when you first set it up? I'm trying to run line-outs from the wires that fed the now history factory sub/sub amp (), ie the same wires that fed the signal to the sub and I'm not getting a signal for some reason. After seeing your post I think I'm gonna just run leads from the right rear as well.
How does it feel to know that you didn't get blindsided by the HK sucker punch upgrade??? Cos I wouldn't know.
hexadecim8 is offline   Reply With Quote
