Old 01-03-2007, 03:58 PM   #1
MadeInGermany
My Ride: e46 m3
Jack Stands E46 M3
Okay just want the best way to do this.
Basically Jack up the car from the rear on the frame where the differential sits inside..
then put the two jack stands where you would jack up the car to change the tire??
Or would you guys drop it on the trailing arms.. They are rounded and angles so it doesnt seem like the greatest spot..
Looking for the best spot to put these jack stands. That would be again in front of the rear tires just underneath the side skirts??
Thanks...
MadeInGermany is offline   Reply With Quote
Old 01-03-2007, 07:42 PM   #2
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
You should use the factory jack points - where you would use the factory jack when changing a tire.
Good luck, and be safe.
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 01-04-2007, 08:31 PM   #3
Slawless
My Ride: 2003 M3 / 2008 M3
I have used the factory jack points twice. Once for coilovers, once for RTAB. no problems.
2003 M3
Slawless is offline   Reply With Quote
Old 01-04-2007, 08:34 PM   #4
Rdizzle
My Ride: '00 328Ci
I have a subframe brace the sits right in front of my differential that I use to jack up my entire rear with (recommended jack point by a BMW tech friend). I then place the jack stands under the jack points. Your M3 might be different than my 328Ci so you may have to look for a different spot. But just make sure you don't jack it up on the differential!
I also have a "button" up front where my triangle brace comes together as a central jacking point up front. I have to roll up on 2x6's first to reach that point with my jack. But after I get it up using that central point, I put the jack stands under the designated jacking spots as up front.
'00 328Ci Step + Sport & Premium Packages
Mods:
BMP Design Front Strut Bar | K&N 63 Series Intake | LED Interior Lighting | M3/H&R Sway Bars | OEM Bi-Xenons + CCFL Angel Eyes | Smoked Turn Signals | UUC SS Brake Lines | ZHP Shocks & Springs
Rdizzle is offline   Reply With Quote
Old 01-04-2007, 08:36 PM   #5
Rdizzle
My Ride: '00 328Ci
Hey, check out htis site: he has pics of the jack points that I was referring to:
http://m3.madrussian.net/diy_jacking.shtml
Mods:
Old 07-28-2011, 11:52 AM   #6
RockM
My Ride: M3
Has anybody seen this? Where can we buy this?
RockM is offline   Reply With Quote
Old 07-30-2011, 08:47 AM   #7
voidopolis
My Ride: 2004 M3 SMG Vert
google says: http://shop.jackpointjackstands.com
but holycrap are those expensive? ...or is it just me?
voidopolis is offline   Reply With Quote
Old 07-30-2011, 09:35 AM   #8
rcsummers
My Ride: M3
wtf thats a rip off, $315. For one jack stand.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
