Old 01-22-2007, 03:47 PM   #21
tiggaatl
My Ride: 05 330i ZHP
Send a message via AIM to tiggaatl Send a message via Yahoo to tiggaatl
So Today, I uninstalled every thing, and re installed them just to trouble shoot. Well, Now my passenger side Lights are working in ful force, however, the driverside isn't. Next I switch the the wires from the side that wan't working to the side that was, and the lights worked fine again. So now I know that it has to be that balast that's out that was causing all the trouble, as I directly soldered the rings to the balast. Anyone want to chime in on this hypothesis?
~"I mod, therefore I am"~
tiggaatl is offline   Reply With Quote
Old 01-23-2007, 04:58 PM   #22
schnitzer323ci
My Ride: 2000 323ci
This is why i always tap power for my halos to my fog lights. Not everyone likes running fogs + halos, but it keeps the systems separate. To test function of the halos themselves just run a wire from them directly to battery... cuts out the other systems... relays, etc. You might have blown inverters/ballasts or something.
schnitzer323ci is offline   Reply With Quote
Old 01-23-2007, 04:59 PM   #23
schnitzer323ci
My Ride: 2000 323ci
This is why i always tap power for my halos to my fog lights. Not everyone likes running fogs + halos, but it keeps other systems separate. To test function of the halos themselves just run a wire from them directly to battery... cuts out the other systems... relays, etc. You might have blown inverters/ballasts or something.
Old 01-23-2007, 05:35 PM   #24
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
If you swapped the ballasts and the problem switched sides, then you need a new ballast.
Old 01-23-2007, 08:20 PM   #25
nikkoo00
My Ride: BMW 330AWD
I checked my tap to the ecu and back to the relay but stil cant understand why they wont light when the ignition is on, is there maybe a fuse i can check or any other wires?
nikkoo00 is offline   Reply With Quote
Old 01-23-2007, 08:24 PM   #26
sillieidiot
My Ride: '06 AW 330ci
yea there's a fuse on the relay. the one that connects to the positive terminal
Old 01-23-2007, 08:29 PM   #27
nikkoo00
My Ride: BMW 330AWD
i checked that, i replaced it 2 weeks ago with a #5 orange fuse, and i changed the relay as well. thanks for the help though
Old 01-23-2007, 08:31 PM   #28
funkyman
My Ride: 330ci,Mazdaspeed3
You may need to hardwire or rather clamp the connecting wires from the ballast to the power supply.Thats what i did and my blinking problem and relay problem went away.
funkyman is offline   Reply With Quote
Old 01-23-2007, 08:37 PM   #29
nikkoo00
My Ride: BMW 330AWD
anyone try this, had any problems along the way from doing this?
Old 01-26-2007, 12:13 AM   #30
sillieidiot
have you tried it? was just curious if you ever fixed it
Old 01-26-2007, 12:19 AM   #31
nikkoo00
My Ride: BMW 330AWD
im probly keeping them connected the way they are intended to be, and just try to see what the problem is with the ecu tap. Ive tried playing with the Ecu tap wire but still nothing. Im clueless on what to try to get them to work woth the ignition any other ideas? thanks for asking tho.
Old 01-26-2007, 12:26 AM   #32
sillieidiot
do you still have the tap to the footwell? maybe take that out? or you could try rewiring everything again. but do it in steps and such i guess
Old 01-26-2007, 12:35 AM   #33
nikkoo00
My Ride: BMW 330AWD
if i was to take the tap out form the footwell wouldnt that disable the remote activation? Really appreciate the help in helping me find this problem. I might just end up reinstalling them when i get a chance.
Old 01-26-2007, 12:46 AM   #34
sillieidiot
yea it would, but that might be what's causing the problem. i've read somewhere that the vendors were having a problem with the remote activation and advised not to do it.
Old 01-26-2007, 12:50 AM   #35
nikkoo00
My Ride: BMW 330AWD
ill try that tomorow then. that suks if it does would there be anything you could replace to actually get the full functionality of the rings? thanks for the info.
Old 01-26-2007, 01:19 AM   #36
sillieidiot
i think there might be a remote add on kit that your vendor can give you or something
