Old 01-05-2007, 09:23 PM   #1
crosse46
Past Site Sponsor
Girodisc Two Piece Floating Rotors For E46
The primary purpose of the Girodisc system is to reduce unsprung and overall vehicle weight. The secondary purpose is to increase the ventilation and cooling capacity of the brake disc while retaining it's original dimensions.
This is accomplished by using two-piece disc construction. The central “hat” section of the disc is made from 6061-T6 aircraft specification aluminum.
The disc is made from cast iron, constructed in the USA and is made to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Please PM us for pricing
PS: our new location is up and running dyno services willbe avilable end of this month.
ID:	209213   Click image for larger version
crosse46 is offline   Reply With Quote
Old 01-06-2007, 11:42 AM   #2
elite53
My Ride: Twin Screwed 325Ci
Is this just for the M3 or will they fit all E46's?
elite53 is offline   Reply With Quote
