Old 01-14-2007, 12:33 AM   #1
4rwheeler
My Ride: 2000 323i
OEM xenon problem
I posted a month of so ago about this problem. I thought I fixed it but it cam back a few days later. Probably never fixed it.
At times while the car is running, both xenons will turn off for a split second similtainiosly, then re-ignite. Can be parked of driving. Bumbs don't do it, just random. Took it to the dealer yesterday for regular service, and had them look at it. To my suprise(not), they couldn't find anything wrong. On the hour drive there, it never happend. The 10 mile drive home from work the other day was so bad, I turned the xenons off and just drove with fogs(was getting light out). I am guessing the light control module or the switch itself. Since they are turning off and on together, I am figuring it's farther up-stream than the ballast or bulbs. No other lights flicker. I have factory xenons, and have added DDE's (2yrs ago). Other than that, all factory stuff. Also, if anyone thinks I might be right, does anybody have the part #'s and know of a good place to order other than dealer? Sorry this is so long, but lots of details to put in to cut down on questions later. Thanks. Jason
4rwheeler is offline   Reply With Quote
Old 01-14-2007, 12:57 AM   #2
sillieidiot
My Ride: '06 AW 330ci
try resetting your car. it might help with the problem.
Old 08-24-2007, 03:27 AM   #3
tonythetiger
My Ride: 2000 323ci
Send a message via MSN to tonythetiger
sillieidiot...
reset your car? how are you supposed to do that?
and what would that do as far as fixing the problem?
Just curious.
tonythetiger is offline   Reply With Quote
Old 08-24-2007, 03:54 AM   #4
sillieidiot
take off the negative terminal on the battery for like 30 seconds. sometimes that helps to reset things.
i just noticed that this was awhile back. and in case you haven't fixed it, it could be that the ground wire on the angels isn't secure or getting a good connection. i noticed that on some cars that i've worked on, if the ground isn't secure the xenons don't work correctly.
Old 08-24-2007, 10:35 AM   #5
n2Bimmer
My Ride: Loves Corners
where is the groung for the xenon. tnx.
Old 08-24-2007, 10:35 AM   #6
n2Bimmer
you mean the negative for the battery in the trunk or under the hood.
Old 08-24-2007, 12:21 PM   #7
jbcritch
My Ride: 2005 Steel Blue 325i
There is also a recall on xenons. I dont recall what years it effects, but had 1 of my bulbs and both ballast replaced under the recall. My lights would flicker off and on and then one went out for a moment..which should throw a fault that the dealership can see when they run your key.
Do a quick search for the recall number. good luck.
2001 330Cic AW/Sand- ret.
2003 330i SB/Grey - ret.
2005 545i 6spd BLK/Black - ret.
2005 325i SB/Grey - ret.
2007 550i Grey/Black
Mods: M5 mats, M5 spoiler, tint....for now.
jbcritch is offline   Reply With Quote
Old 08-24-2007, 06:15 PM   #8
sillieidiot
the battery is in the trunk.
