Sponsored by The Tire Rack
Old 01-18-2007, 09:45 AM   #1
captain_jim1
My Ride: 99 323i
Send a message via AIM to captain_jim1
What tires should and get and what size?
I'm picking up a set of 19x8.5 Breyton Visions replicas... it has been suggested I run 235/35/19 in the front and 245/35/19 in the back.. or just 235/35/19 all around.
How will this effect ride height, looks, etc. I also have no kept up with the tire game in a while so I'm a little clueless as to what tire to get. I'm an aggressive driver, but tend to work my tires until they're slicks... so I need performance and some decent mileage.
Thanks guys.
-Brad
2010 X5
99 323i - Sold
83 320i - 292k - Junked
captain_jim1 is offline   Reply With Quote
Old 01-18-2007, 09:49 AM   #2
JJR4884
My Ride: BMW
I THINK in the back should be 255/30/19 but don't quote me on that
JJR4884 is offline   Reply With Quote
Old 01-18-2007, 09:56 AM   #3
Erick Sermon
My Ride: 2000 323Ci
do 235 all round...unless your rim is wider in the back i don't see the point of using staggered tires, its better to be able to rotate which will give you more mileage...plus 235 to 245 is not a huge obvious staggering...different if its 225 and 245 or 255
Erick Sermon is offline   Reply With Quote
Old 01-18-2007, 10:31 AM   #4
Jeuprx-8
My Ride: rolls only Michelins
I recommend 235/35r19. That way you can rotate. Don't do a 235, 245.... because you can't rotate and your rear tire will be taller than the front. I would recommend the BFG KDW NT, or a Michelin PS2 if you have money to spend.
2006 Corvette Z06 Red/black
2006 BMW M5 Sepang/Sepang SMG III
2006 BMW M6 White/Black 6-speed
Jeuprx-8 is offline   Reply With Quote
Old 01-18-2007, 10:41 AM   #5
captain_jim1
My Ride: 99 323i
Thanks guys. I hadn't considered the ability to rotate, but that's a great reason to go 235 all around.
Any other suggestions on tires?
-Brad
2010 X5
99 323i - Sold
Old 01-18-2007, 11:11 AM   #6
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
if you have the money, spend it on Michelin PS2's, there's really no better tire.
As far as widths go, I see you have a sedan so keep it all the same all around. Sedan owners do stagger, but it needs to be a bigger difference between front and back. For stagger, you'd need 225 in the front and 245 in the rear. You can get away with 255 but that'll depend on the tire sidewalls. Toyo's are known to be good in that department with narrower sidewalls. Problem is sedans have narrower wheel wells in the back than coupes.
For simplicity sake though and if you're not too concerned with looks and want some practicality, stick to the 235s all around.
Tutankhamon is offline   Reply With Quote
Old 01-18-2007, 12:25 PM   #7
captain_jim1
My Ride: 99 323i
Thanks for the input. I'm def. going to stick with 235's all around. I'm thinking about getting Kuhmo ECSTA SP's for the summer and picking up Kuhmo ECSTA AST's for the remainer of the winter (on my 16s).
-Brad
2010 X5
99 323i - Sold
