Old 01-18-2007, 07:26 PM   #1
D-Rock
My Ride: 1988 325is m50
Hid fogs HELP
HID i have xtech fogs i just put them on . Everything is well put and nothing is lose. The fogs only stay on for a min. When i left the car on just stitting there they stayed for a while. Does anyone know whats wrong ?
Thank you
Image Hosted by ImageShack.us
D-Rock is offline   Reply With Quote
Old 01-18-2007, 08:06 PM   #2
D-Rock
up
Old 01-19-2007, 10:13 PM   #3
D-Rock
any one please
Old 01-20-2007, 05:17 PM   #4
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
Contact Xtec - A lot of their components have failure issues.
If they don't resolve it call us we'll switch you to Prolumen.
Best of luck!
JL
Jlevi SW is offline   Reply With Quote
Old 01-20-2007, 05:25 PM   #5
JJR4884
My Ride: BMW
ballast issues?.....
you didn't touch the bulb did you?
my guess would be failure in the ballast....
JJR4884 is offline   Reply With Quote
Old 01-20-2007, 05:55 PM   #6
MysticDroptop
MysticDroptop's Avatar
My Ride: W211 E55 AMG
Prolumen FTW
03' E46 330i Topaz Blue/Black- Retired
03.5' E46 M3 Cabriolet Mystic Blue/Gray- Retired
06' W211 MB E55 AMG Bright Silver Metallic/Black- Current
Need top notch work done to your car?
Martino Auto Concepts
MysticDroptop is offline   Reply With Quote
Old 01-23-2007, 05:29 PM   #7
D-Rock
Man i thought xtech was the best . Thats why i got these
Old 01-23-2007, 05:32 PM   #8
schnitzer323ci
My Ride: 2000 323ci
Did you test them before installing? Was everything working?
schnitzer323ci is offline   Reply With Quote
Old 01-23-2007, 05:44 PM   #9
D-Rock
yeah they stay on but when i turn the car on they go out
Old 01-24-2007, 08:01 PM   #10
D-Rock
up
Old 01-24-2007, 08:16 PM   #11
bave46rider
My Ride: e46
D-rock,
Sounds like there is something mixed up in the wiring. If there was something wrong with the bulbs or ballasts, they would NEVER turn on (ie, a burnt-out bulb would never turn on, so if your fogs are turning on but turn off when you switch something else, then it looks like it may be wiring related). One thing to note is that the fogs always turn off when you turn on your high beams.
PS: In the worst case where there is something wrong with a bulb or ballast, DO NOT WORRY. You have a no-cost lifetime warranty on all parts, so all you need to do is email your vendor and they will send you brand new parts at no extra cost. No need to spend hundreds of dollars on other kits. XTECs are great kits.
bave46rider is offline   Reply With Quote
Old 01-26-2007, 04:30 PM   #12
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
I'm assuming you've wired the foglights power directly into the HID ballasts - the LCM may have an issue with the nature of the HID's current draw (starting out high and then tapering off). You could try using a relay and running them directly from the battery. If that doesn't solve the flickering I would contact your retailer.
Tyler@UniqueDesign is offline   Reply With Quote
Old 01-28-2007, 08:38 PM   #13
D-Rock
Well they are not flickering they just turn off when the car is on .
Old 01-28-2007, 08:59 PM   #14
Tyler@UniqueDesign
Car Junky
I dunno why I said flickering. I would run them on a separate harness to solve the issue, but I don't know what to tell you otherwise - I've never personally encountered that issue.
