Old 01-18-2007, 10:32 PM   #1
gTkidrokin330
My Ride: Bemdub
Condensation in Headlight
Okay guys so ever since i put my 6000K bulbs in my right side headlight is continuously fogging and i see a little water. I have taken the lense out 5 times now just to clean it and resecure it. it KEEPS on fogging.
What can i do to fix this?
gTkidrokin330 is offline   Reply With Quote
Old 01-18-2007, 10:49 PM   #2
james2538
My Ride: Sold
Be sure you re-secured the headlight properly, espcially the bulb socket that you switched out.
james2538 is offline   Reply With Quote
Old 01-28-2007, 04:49 PM   #3
gTkidrokin330
My Ride: Bemdub
alright i had it un-fogged for a week and then poof, fogging again.
any more suggestions?
Old 01-28-2007, 05:00 PM   #4
Zeppelin420Fan
My Ride: '98 M3 & '06 ZCP M3
yah dude same thing with me. I put in my own p46s and every now and again they will fog up inside the housing. Went thru the car wash today and they fogged. When its really wet n humid out they will fog.
Ive also been getting drops of water in my right rear oem clear corner brake light.
Zeppelin420Fan is offline   Reply With Quote
Old 01-28-2007, 05:02 PM   #5
2001bmw330
My Ride: 2003 bmw 330ci
that has happened to me and what i did was use some silicone on the rubber gasket between the clear lens and the black housing part it has worked for me
2001bmw330 is offline   Reply With Quote
Old 01-28-2007, 05:11 PM   #6
Zeppelin420Fan
That for the p46's or the back lights?
Old 01-28-2007, 07:51 PM   #7
johndddd
My Ride: 02 m-3
there is a rubber seal that goes around the plastic headlight lense. replace that rubber seal with a new one. This will solve your problem. About 14.00 dollars at your dealer.
johndddd is offline   Reply With Quote
