Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 5.00 average. Display Modes
Old 01-22-2007, 03:54 PM   #1
desi
My Ride: E46 M3
Rear Bumper Removal : E46 Coupe (UK 2000)
Car : E46 Coupe (UK)
Year : 2000
Tools/Items Required
Flat head screwdriver
Torx T50 tool
Rag to use with screwdriver
A sheet to place the removed bumper on.
The car was not jacked up and wheels did no have to be removed to take off the bumper.
Figure A
The bumper was held on by two T50 bolts at the rear of the bumper (see fig.B and fig.D).
A clip on each wheel arch (see fig.G and fig.H) and a plug at the bottom of each wheel well (see fig.K).
Figure B
The B1 strip needs to be removed to allow access to the T50 bolts holding the bumper at the rear.
Different methods to get this strip off, but I found it easiest to remove the rectangular plastic cover at the bottom of the car towards the rear see B2. It's held on with 4 plugs (see fig.K). Then I unhooked one side of the strip from the interior of the bumper, by squeezing my hand in and then prized it out from one side to the other. It's not difficult. Some people don't bother removing the plastic cover under the car and magae to prize the strip off using a screwdriver. I guess if your changing bumpers then your not exactly going to be bothered about a few dents or scratches on the old strip as you take it off.
The two T50 bolts are roughly in positions B3 and B4, so once the strip is off (see fig.C), you can use the L shaped Torx tool to unscrew the bolts. Once loosened I managed to unscrew the remainder by hand.
The bolts drop down, but you can't fully take them out, because the bottom of the bumper is in the way.
It's a tight squeeze to pull them out and I had to pull on the bumper where the strip was removed to squeeze the bolts out. The bumper is a little loose now and only held on by a sort of clip on the top of the wheel arch and a plug at the bottom of the wheel arch, so be careful. I did everything on my own, but it's handy having someone else to help.
Figure C
Figure D
Figure E
Figure F
Figure G
Figure H
As you can see in figures G and H, there is a sort of clip holding the bumper at the top corner where it meets the wheel arch (G1 and H1). I firstly removed the plug at the inside bottom of the wheel arch on both sides (G3 and H3). Then I squeezed out the black rubbery wheel arch (G2 and H2) from under the edge of the bumper, where the bumper meets the wheel arch to on top of the bumper edge. Once done, I used the flat head screwdriver with some cloth on the end to try and avoid scratches on the body work to push down and in VERY carefuly to sort of unhook the bumper. Did the same on the other side. This bit is very tricky so be careful. Once unhooked on both sides, I just pulled the bumper off the car from the rear.
The whole process took approximitally 15 minutes.
Figure I
Figure J
Figure K
desi is offline   Reply With Quote
Old 01-22-2007, 03:59 PM   #2
clinique
clinique's Avatar
My Ride: 06 M3 Vert
thanks for sharing
do u know if its identical for sedans?
clinique is offline   Reply With Quote
Old 01-23-2007, 02:15 AM   #3
desi
My Ride: E46 M3
I believe it's different for Sedan's.
Checkout the following link as a starting point;
http://forum.e46fanatics.com/showthr...bumper+removal
Old 01-25-2007, 10:18 AM   #4
desi
My Ride: E46 M3
Found these general links on rear bumper removal;
http://www.openbmw.org/downloads/51%...r%20bumper.pdf
Old 04-20-2007, 09:54 PM   #5
Nick_in_Suffolk
My Ride: E46 M3
Anybody know how, if at all, the removal process for an M3's rear bumper is different from the information here?
I have managed to push a PDC sensor in slightly and I think I have to remove the bumper to sort out my mistake.
Nick_in_Suffolk is offline   Reply With Quote
Old 04-21-2007, 06:23 AM   #6
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Good info.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 03-08-2008, 04:48 PM   #7
GWU_Greek
Banned
My Ride: 325
awesome DIY
GWU_Greek is offline   Reply With Quote
Old 03-08-2008, 05:29 PM   #8
DBLAZE
My Ride: is Fern Green!
Send a message via AIM to DBLAZE
Nice DIY!
BMW F01 Alpine White 750i xDrive/Oyster Interior
[BMS Stage 1 Tuning | VRS Front Bumper Lip | AC Schnitzer Trunk Spoiler | AC Schnitzer Roof Spoiler | AC Schnitzer Pedals/Footrest | 45% SunTek CXP Tint]
BMW E63 Jet Black 645ci - Retired
BMW E46 Fern Green 323ci - Retired
DBLAZE is offline   Reply With Quote
Old 10-30-2008, 12:18 AM   #9
DJ RaMiN
My Ride: 02 325I,03 M3
Year : 2000
Torx T50 tool
Figure A
Figure B
Figure C
Figure D
Figure E
Figure F
Figure G
Figure H
Figure I
Figure J
Figure K
is this same for m3???or different??
DJ RaMiN is offline   Reply With Quote
Old 10-31-2008, 06:46 PM   #10
DJ RaMiN
anyone???
Old 01-31-2010, 11:56 AM   #11
Be.M.w.e46
My Ride: 323ci
kept
Be.M.w.e46 is offline   Reply With Quote
Old 01-26-2012, 01:15 AM   #12
new61n
My Ride: 2005, 325CI
"hook" bracket not needed?
Does anyone know if the attached image hook-like bracket is needed? Its the part #10 in this link http://www.realoem.com/bmw/showparts...11&hg=51&fg=17
I haven't seen it in any of the forum threads or online so maybe its not needed?
new61n is offline   Reply With Quote
Old 01-27-2012, 09:04 PM   #13
Shayn
My Ride: 325ci
If it's the same clip from OP pictures (G1) yes it's needed to keep the bumper tight with the wheel arc.
Shayn is offline   Reply With Quote
Old 01-28-2012, 03:42 AM   #14
new61n
Thanks Shayn,
Is this how you would attach that bracket to the bumper?
ID:	434283   Click image for larger version
Old 01-28-2012, 04:34 AM   #15
RKiepper
My Ride: 1999 E46 328I x2
Those stupid nuts that are part of the rear support like to break loose and spin in place, then your in trouble. You'll have to remove the rub strip from the bumper, cut a hole underneath and squeeze in a pair of channel locks to hold the nut so the bumper can be removed. You can't see the hole, but it's still a pain. Ask me how I know... Ugh.
RKiepper is offline   Reply With Quote
Old 01-28-2012, 05:14 AM   #16
new61n
Hahaha, I'm scared to ask how you know!
From the OP the G1 bracket looks like the hook part is up inside the metal body of the car with the other part clamped onto the bumper, does that sound right?
It's weird though, in the realoem site it says there is a nut as well but i don't know where that goes! - http://www.realoem.com/bmw/showparts...11&hg=51&fg=17 (nut #11)
