Old 05-06-2002, 01:27 AM   #1
chopstik
My Ride: 07 G35S
call me retarded but...
i have a 2002 330ci....i'm trying to install my silvervisions in the front, and when i look in that oval hole, i don't see a notch, but a little cylinder with a screw in it.......am i supposed to unscrew that???? for something that's supposed to be easy, i'm sure having a hard time with this....help please....:sad:
chopstik is offline   Reply With Quote
Old 05-06-2002, 01:34 AM   #2
-Ryan-
Registered Abuser
My Ride: E92 335i
Unscrew that screw then use the screwdriver to push the indicator out.
For more help look in your instruction manual under replacing bulbs or something like that.
** NWS removed - tim330i **
-Ryan- is offline   Reply With Quote
Old 05-06-2002, 02:42 AM   #3
presario
My Ride: 330ci
No, you don't need to unscrew anything. Look into that oval hole and with your screw driver, push down the plastic arm that locks the clear corner into place. It's a little tricky because the arm is located under some other junk so get a flashlight and look for it
Sig by Jojo//Celsius One
presario is offline   Reply With Quote
Old 05-06-2002, 02:51 AM   #4
soheilm3
bored.
My Ride: definitly not an m3
Send a message via AIM to soheilm3
if i remember correctly the 2002 models have a redesigned front blinker housing, and as stated do have screws... i dont know the details on it, but im 99% sure u do unscrew a screw:thumb:
--soheil
Women are:
Taken
Smart
Beautiful
(pick 2 of the three only)
soheilm3 is offline   Reply With Quote
Old 05-06-2002, 02:53 AM   #5
chopstik
My Ride: 07 G35S
new problem....
ok, i figured out how to get the light out...i unscrewed it and the clears popped out...changed the bulbs....now my new problem....the lenses won't sit flush anymore....i've been struggling to get it in right, but it won't go in flush with everything else....is there some science to this that i don't know about???
